sorry to make something so simple complicated, but I have tried opening in inkscape, fusion, autocad and its not opening right in any of them. it opens but the whole thing is scaled by 10. only reason i know this is because i'm able to measure one and only one dimension on the dxf correctly which is the 50mm length.
is there any way you could just provide a drawing with the dimensions or something like that?
Forum rules
Sure, here you go:phinsil6 wrote:sorry to make something so simple complicated, but I have tried opening in inkscape, fusion, autocad and its not opening right in any of them. it opens but the whole thing is scaled by 10. only reason i know this is because i'm able to measure one and only one dimension on the dxf correctly which is the 50mm length.
With the GRBL 0.9g is it still the $2 setting that gets changed when doing this upgrade?
Shapeoko 2 #8233
Type $$ to display the list of parameters.mikenmel08 wrote:With the GRBL 0.9g is it still the $2 setting that gets changed when doing this upgrade?
Next to each parameter will be a description.
Change the parameter for number of steps per mm for the z axis.
Are these in stock?
Shapeoko 2 #?? w/Makita RT 0701C
