sell your stuff here
Forum rules
Todd Bailey
Post by Todd Bailey » Wed Oct 10, 2012 1:19 am
Just order the ACME screw upgrade for Shapeoko Z-axis!!! Looking forward to the upgrade!
Todd Bailey and ShapeOko - 413
Owner and Creative Designer
4m3D Creative Design
http://www.4m3d.com
Skype Call - todd.4m3d
Phone - 443-450-4633
Newsletter - Subscribe - Free model every issue
Post by Improbable Construct » Wed Oct 10, 2012 11:15 pm
Update:
I only have a couple more kits left in stock right now.
Once they sell out it will be about 2-3 weeks before I have more ready to go.
Todd,
I sent yours out today. Hopefully it will not take to long to cross the border.
Todd Bailey
Post by Todd Bailey » Thu Oct 11, 2012 11:22 am
I'll let you know when it arrives!!!!
Thanks for getting it out so fast!
This is going to be great.
http://www.4m3d.com
Post by Improbable Construct » Mon Oct 15, 2012 7:06 pm
There is only one kit still available from the first batch!
Second batch ETA 2-3 weeks.
Thank you for your support.
CptanPanic
Post by CptanPanic » Tue Oct 16, 2012 3:07 pm
I will get one of the next batch if you can test out the 2 nut idea.
northbear
Post by northbear » Thu Oct 18, 2012 1:08 pm
How does the standard nema 17 motor hold up with the ACME screw and a large spindle (ie DW660 or a trim router). What I am wondering is if there were no other tradeoffs (price was no object, mounting the different size motor was not an issue, etc) would it be better to have a more powerful nema 23 motor? Or would it not gain you anything by doing this change?
Another way to ask my question is if there was some mythical nema 17 motor that was exactly the same in every way but twice the amount of torque (for example), would it practically make any difference in the performance with a larger then standard spindle (ie DW660)?
My buildlog is here
Post by Improbable Construct » Thu Oct 18, 2012 4:16 pm
My machine is 1000 mm X 1200 mm with all NEMA 17 69 oz/in motors and I am using a DW660 for the spindle.
So pretty much the scenario you describe.
As far as I can tell a larger motor would not offer any real world performance gains.
I have pushed my Shapeoko to the limits many times and the ACME Z-Axis has never been the limiting factor.
The weak points in my setup are the flex/bounce/twist in the X axis, followed by lack of torque from the DW660.
During testing I was running ramp cuts with a 1/4" 4 flute end mill into 3/4 MDF.
There was no problem with the Z axis plunging into the stock but the DW660 bogged down severely.
So you could use a bigger motor but I don't see it as necessary.
Todd Bailey
Post by Todd Bailey » Thu Oct 18, 2012 11:15 pm
Just got my upgrade in the mail today!!!! Thanks!
http://www.4m3d.com
northbear
Post by northbear » Fri Oct 19, 2012 2:43 am
Thanks for the reply IC!
I had done a rough calculation with numbers from an equivalent Nook ACME screw and plastic nut and it seemed like there should be **plenty** of force with the standard NEMA 17 motor, but I thought I may be missing something. Thanks so much for giving a "Real World" experience!
Out of curiosity, could you expound on what you found were the limits on your system? Was it the flex/twist in the x-axis makerslide itself, in the aluminum carriage plate or something else, (or maybe unknown)?
Thanks again!
My buildlog is here
Post by Improbable Construct » Sun Oct 21, 2012 3:19 am
I have found that there is flex/twist in the X to Z Axis in four places.
1. The X-axis makerslide.
2. The V wheels.
3. The universal plate.
4. The spacers on the Z-axis V wheels.
Solutions:
1. Double X-axis makerslide - helps a lot, but not a comprehinsive solution.
2. V-wheels - some of them are bad - out of round or out of spec - dont roll smoothly or bearings don't fit tightly.
3. The universal plate has some flex - I tried double universal plates - did not seem to make a difference.
4. The nylon spacers on the Z-Axis can flex - replaced with aluminum spacers - recomended upgrade.
I still have flex in the X to Z axis but with careful settings in your CAM program most backlash can be eliminated.
