Magnetic Linear Encoder - pcb/kit
Posted: Tue Oct 09, 2012 9:06 pm
Makerbot has a nice, simple linear encoder solution, but it's $50/unit/axis! Check it out here:
http://wiki.makerbot.com/mle
Note that the magnet is just magnetic tape. This solution can scale to whatever size Shapeoko you've built for a few dollars. This is really nice for us.
I'm considering having a batch of boards made for people who aren't afraid of the soldering iron. If interest is low, I'll just use batchpcb.
If I can get commits for enough boards, I'll have an entire panel made.
I think I can kit these up for under $20 with PCB and encoder chip. I suppose I'm willing to build them (one time only offer to get enough interest) for an extra $10/board. (I have hand reflow gear and a microscope) I'm putting the cost ceiling at $20 per kit and $30 built (plus shipping). I will reduce the price depending on actual parts costs at order time. I'm not sold on the connector/cable they use, so expect that to change to a normal header.
Alternatively, you can just buy a board and populate it yourself. I estimate the board cost to be under $10/unit. I plan to alter the board layout to fit certain handy Shapeoko mounting holes. I'll post the layout here for review. Please indicate your interest with quantity(X) and description below:
X - PCB
X - PCB/kit diy soldering (all parts in a baggie ready for you build)
X - PCB/kit presoldered (all SMD parts mounted) Header will be loose for you to attach as you prefer.
I will handle payments via paypal. I'm not taking money at this time.
X - PCB
