Optimize GCode from Makercam?
ArtFaks
Post by ArtFaks » Sun Feb 14, 2016 6:38 pm
Hi, after some problem with Chilipeppr...
How to optimize my "gcode" created with Makercam?
I try the software which is indicated on the shapeoko wiki but I can't use it with Windows 10.
I would like a software compatible with Windows10 or OS Maverick. What do you advise me?
I ask this question because the exported gcode by Makercam cause some problem with Chilipeppr. Too many error because too much zero pointless!
Shapeoko2 - Homemade CNC Control box - 400W/48V Chinese Spindle - Protoneer V3 Shield + DRV8825
Process - Illustrator > Makercam > UGCS
Re: Optimize GCode from Makercam?
Post by WillAdams » Mon Feb 15, 2016 12:53 am
If I understand correctly, you’re experiencing difficulties w/ too long lines from MakerCAM.
Surprised Chilipepper doesn’t have an option for this.
I just use the text editor SciTE, and a GREP find-replace:
http://www.scintilla.org/SciTE.html
http://www.shapeoko.com/wiki/index.php/FAQ#MakerCAM
Search for:
\.\(\d\d\d\d\)\d*
replace w/:
.\1
ArtFaks
Post by ArtFaks » Mon Feb 15, 2016 2:16 am
Thanks a lot @WillAdams, you correctly understand ;-) (sorry, i'm not proud about my double dutch language)
This is that i need --> http://www.shapeoko.com/forum/download/file.php?id=1610
Post by WillAdams » Mon Feb 15, 2016 3:00 am
Your English is far better than the Korean which was one of my cradle tongues, and which I spent a year in the Air Force relearning.
As I noted, I just process the files by hand w/ a text editor.
The file which you linked to is a .html page w/ Javascript which should open in your web browser --- double-click on "index.html" and allow it to run code.
ArtFaks
Post by ArtFaks » Mon Feb 15, 2016 12:29 pm
Ok, thanks
By hand, line by line, I'm sure with the good result.
With the html/jquery code, this is done automatically and i can be sure with the result?
Post by WillAdams » Mon Feb 15, 2016 1:04 pm
I don't do it line-by-line (if I did, I'm sure I'd mangle something, somehow) --- the GREP code I provided will let one do it as a global replacement, in a single step for a file.
The HTML file should work well --- ISTR testing it, I just find using a text editor more convenient.
ArtFaks
Post by ArtFaks » Mon Feb 15, 2016 2:16 pm
Ok @WillAdams, thanks for all these informations. ;-)
