G-code format
aldepoalo
G-code format
Post by aldepoalo » Sat Sep 22, 2012 5:56 pm
Hello Everyone! My name is Al DePoalo and I am the Partner Products Manager at BobCAD. I have some questions about the G-code format that is required by the shapeoko controller. If someone could provide sample(s) programs that run on their shapeoko I would really appreciate it.
Information I need to know:
What controller software are you using?
What codes are needed at the start of the program?
What codes are needed at a tool call or change?
What cods are used to cut line moves?
What codes are used to cut arc moves?
What codes are used at the end of the program?
Using this information I can build a post for the BobCAD CAM software that will work with the shapeoko controller.
Here is a sample using a generic fanuc style post:
Sample Engraving Program:
G90 G80 G40 G20 G17
(FEATURE ENGRAVE)
(TOOL #1 0.25 V Tip Engraving Tool)
T1 M06
M00
S5000 M03
G54 X3.0974 Y0.9387
G00 G43 H1 D1 Z0.1 M08
G01 Z-0.05 F5.
G17 G03 X3.1664 Y0.8699 I0.1281 J0.0594 F10.
X3.2097 Y0.8567 I0.0694 J0.1504
X3.2393 Y0.8534 I0.0504 J0.317
X3.3077 Y0.8558 I0.0224 J0.3448
X3.3514 Y0.866 I-0.0307 J0.2288
X3.3928 Y0.8873 I-0.0517 J0.1516
X3.441 Y0.9505 I-0.0782 J0.1095
X3.4507 Y0.9891 I-0.1769 J0.0648
X3.4528 Y1.0429 I-0.2654 J0.0373
X3.4485 Y1.0757 I-0.2409 J-0.0148
X3.4355 Y1.1146 I-0.1608 J-0.0323
X3.3886 Y1.1678 I-0.1187 J-0.0572
X3.331 Y1.1923 I-0.0978 J-0.1504
X3.2856 Y1.1989 I-0.0632 J-0.2752
X3.207 Y1.1936 I-0.0193 J-0.3038
X3.1598 Y1.1776 I0.037 J-0.1859
X3.106 Y1.1296 I0.0606 J-0.1223
X3.0942 Y1.1068 I0.107 J-0.0695
X3.0875 Y1.0864 I0.1796 J-0.0705
X3.0801 Y1.0382 I0.2124 J-0.0572
X3.0847 Y0.9778 I0.2588 J-0.0105
X3.0974 Y0.9387 I0.168 J0.033
G00 Z0.1
X2.3006
G01 Z-0.05 F5.
G03 X2.3696 Y0.8699 I0.1281 J0.0594 F10.
X2.413 Y0.8567 I0.0694 J0.1504
X2.4425 Y0.8534 I0.0504 J0.317
X2.5109 Y0.8558 I0.0224 J0.3448
X2.5547 Y0.866 I-0.0307 J0.2288
X2.5961 Y0.8873 I-0.0517 J0.1516
X2.6442 Y0.9505 I-0.0782 J0.1095
X2.6539 Y0.9891 I-0.1769 J0.0648
X2.656 Y1.0429 I-0.2654 J0.0373
X2.6517 Y1.0757 I-0.2409 J-0.0148
X2.6387 Y1.1146 I-0.1608 J-0.0323
X2.5918 Y1.1678 I-0.1187 J-0.0572
X2.5342 Y1.1923 I-0.0978 J-0.1504
X2.4889 Y1.1989 I-0.0632 J-0.2752
X2.4102 Y1.1936 I-0.0193 J-0.3038
X2.3631 Y1.1776 I0.037 J-0.1859
X2.3092 Y1.1296 I0.0606 J-0.1223
X2.2974 Y1.1068 I0.107 J-0.0695
X2.2907 Y1.0864 I0.1796 J-0.0705
X2.2833 Y1.0382 I0.2124 J-0.0572
X2.288 Y0.9778 I0.2588 J-0.0105
X2.3006 Y0.9387 I0.168 J0.033
G00 Z0.1
X0.8707 Y1.1812
G01 Z-0.05 F5.
Y0.8698 F10.
G02 X0.8695 Y0.8588 I-0.0512 J0.
X0.8671 Y0.8528 I-0.0203 J0.0045
G01 X0.9821
G02 X0.9786 Y0.8601 I0.016 J0.0122
X0.9773 Y0.8696 I0.043 J0.0106
G01 Y0.9994
X1.084
Y0.8696
G02 X1.0824 Y0.8591 I-0.0402 J0.0008
X1.0792 Y0.8528 I-0.019 J0.0056
G01 X1.1942
G02 X1.1916 Y0.86 I0.0199 J0.0113
X1.1907 Y0.8701 I0.0555 J0.0101
G01 Y1.1815
G02 X1.1918 Y1.1929 I0.0556 J0.
X1.1942 Y1.1994 I0.0244 J-0.0051
G01 X1.0792
G02 X1.084 Y1.1817 I-0.0358 J-0.0192
G01 Y1.0528
X0.9773
Y1.1811
G02 X0.9821 Y1.1994 I0.0373 J0.
G01 X0.8671
G02 X0.8698 Y1.1917 I-0.0241 J-0.0125
X0.8707 Y1.1812 I-0.0595 J-0.0105
G00 Z0.1
X0.7834 Y1.184
G01 Z-0.05 F5.
G03 X0.6803 Y1.1994 I-0.097 J-0.2975 F10.
X0.6429 Y1.1953 I0.0042 J-0.2133
X0.6088 Y1.1838 I0.0273 J-0.1375
X0.5685 Y1.1493 I0.0461 J-0.0945
X0.5493 Y1.0867 I0.0884 J-0.0615
X0.5657 Y1.0309 I0.0972 J-0.0016
X0.5782 Y1.0167 I0.062 J0.0416
X0.5956 Y1.0039 I0.0791 J0.089
X0.6295 Y0.9871 I0.1148 J0.1898
G02 X0.6699 Y0.9707 I-0.6163 J-1.5733
X0.6796 Y0.9661 I-0.0537 J-0.1274
X0.6927 Y0.9535 I-0.0145 J-0.0281
X0.6959 Y0.9399 I-0.0253 J-0.0132
X0.6828 Y0.9146 I-0.0295 J-0.0007
X0.6682 Y0.9079 I-0.0241 J0.0332
X0.6532 Y0.9061 I-0.0157 J0.0664
X0.6162 Y0.9121 I-0.0012 J0.1096
X0.5882 Y0.9256 I0.0441 J0.1272
X0.5603 Y0.9446 I0.2591 J0.4095
G01 X0.5428 Y0.8751
G03 X0.5789 Y0.8631 I0.1575 J0.4135
X0.6182 Y0.8551 I0.0703 J0.2462
X0.668 Y0.8529 I0.0396 J0.3254
X0.7058 Y0.8572 I-0.0072 J0.2306
X0.7423 Y0.8698 I-0.028 J0.1406
X0.7854 Y0.9105 I-0.0466 J0.0924
X0.8026 Y0.9765 I-0.1114 J0.0642
X0.7989 Y1.0055 I-0.1087 J0.001
X0.7879 Y1.0304 I-0.0843 J-0.0225
X0.7771 Y1.0433 I-0.059 J-0.0382
X0.7593 Y1.0569 I-0.0728 J-0.0772
X0.7245 Y1.0736 I-0.1015 J-0.1672
G02 X0.6832 Y1.0896 I0.3389 J0.9361
X0.6706 Y1.0952 I0.0844 J0.2042
X0.6638 Y1.0993 I0.0152 J0.0333
X0.6579 Y1.1069 I0.0122 J0.0154
X0.6559 Y1.1176 I0.0246 J0.0102
X0.6668 Y1.1393 I0.0261 J0.0006
X0.6893 Y1.1461 I0.0212 J-0.0295
X0.7081 Y1.144 I-0.0007 J-0.0916
X0.7308 Y1.137 I-0.0303 J-0.139
X0.7684 Y1.1182 I-0.0952 J-0.2371
G01 X0.7834 Y1.184
G00 Z0.1
X1.3588 Y1.1821
G01 Z-0.05 F5.
X1.2545 Y0.8701 F10.
G02 X1.2449 Y0.8528 I-0.0461 J0.0142
G01 X1.3076
G03 X1.3086 Y0.8571 I-0.0172 J0.0064
G02 X1.3115 Y0.8711 I0.0545 J-0.0041
G01 X1.3342 Y0.9461
X1.432
X1.453 Y0.8711
G02 X1.4553 Y0.8571 I-0.0527 J-0.0158
G03 X1.457 Y0.8528 I0.0142 J0.0029
G01 X1.5905
G02 X1.5798 Y0.8705 I0.0355 J0.0337
G01 X1.4722 Y1.1814
G02 X1.4692 Y1.1918 I0.0963 J0.0333
X1.4686 Y1.1963 I0.0233 J0.0054
G03 X1.4674 Y1.1977 I-0.0024 J-0.0009
G01 X1.4647 Y1.1994
X1.3665
X1.3629 Y1.197
G03 X1.362 Y1.1957 I0.0012 J-0.0018
G02 X1.3588 Y1.1821 I-0.0492 J0.0042
G00 Z0.1
X1.3845 Y1.0963
G01 Z-0.05 F5.
X1.3528 Y0.9994 F10.
X1.4147
X1.3845 Y1.0963
G00 Z0.1
X1.6416 Y1.1799
G01 Z-0.05 F5.
Y0.8692 F10.
G02 X1.6381 Y0.8528 I-0.0369 J-0.0007
G01 X1.7529
G02 X1.7483 Y0.8692 I0.0341 J0.0184
G01 Y0.9728
X1.7742
G03 X1.8074 Y0.9746 I0. J0.3069
X1.8242 Y0.9774 I-0.016 J0.1472
X1.867 Y0.9962 I-0.0273 J0.1205
X1.8994 Y1.0369 I-0.0507 J0.0735
X1.9063 Y1.0627 I-0.1116 J0.044
X1.908 Y1.0997 I-0.1711 J0.0263
X1.9052 Y1.1208 I-0.1543 J-0.0096
X1.8969 Y1.1457 I-0.1033 J-0.0209
X1.8683 Y1.1789 I-0.0768 J-0.0371
X1.8293 Y1.1956 I-0.0613 J-0.0893
X1.7843 Y1.1994 I-0.0411 J-0.2183
G01 X1.6381
G02 X1.6407 Y1.1913 I-0.026 J-0.0128
X1.6416 Y1.1799 I-0.0694 J-0.0113
G00 Z0.1
X1.7483 Y1.1461
G01 Z-0.05 F5.
Y1.0261 F10.
X1.7568
G03 X1.7775 Y1.0288 I0.0014 J0.0701
X1.7903 Y1.0363 I-0.0082 J0.0289
X1.7954 Y1.0439 I-0.0193 J0.0182
X1.7992 Y1.0563 I-0.0514 J0.0225
X1.8016 Y1.0867 I-0.1504 J0.0275
X1.7996 Y1.1123 I-0.1366 J0.0019
X1.7959 Y1.125 I-0.0613 J-0.0108
X1.7929 Y1.1307 I-0.0314 J-0.0128
X1.778 Y1.1427 I-0.026 J-0.0169
X1.7583 Y1.1461 I-0.0183 J-0.0479
G01 X1.7483
G00 Z0.1
X1.9884 Y1.1799
G01 Z-0.05 F5.
Y0.8709 F10.
G02 X1.9873 Y0.8596 I-0.055 J0.
X1.9849 Y0.8528 I-0.0278 J0.0058
G01 X2.2151
Y0.9082
G02 X2.205 Y0.9066 I-0.0146 J0.0597
X2.1913 Y0.9061 I-0.0136 J0.1874
G01 X2.0951
Y0.9994
X2.1938
G02 X2.2151 Y0.9974 I0.0026 J-0.0829
G01 Y1.0546
G02 X2.1932 Y1.0528 I-0.0195 J0.0988
G01 X2.0951
Y1.1461
X2.1947
G02 X2.2151 Y1.144 I0. J-0.1011
G01 Y1.1994
X1.9849
G02 X1.9875 Y1.1911 I-0.0274 J-0.0132
X1.9884 Y1.1799 I-0.0684 J-0.0112
G00 Z0.1
X2.5323 Y0.9703
G01 Z-0.05 F5.
G03 X2.5365 Y1.0242 I-0.29 J0.0497 F10.
X2.5336 Y1.0719 I-0.3473 J0.003
X2.5284 Y1.0971 I-0.1753 J-0.0227
X2.5205 Y1.1169 I-0.0979 J-0.0276
X2.5086 Y1.1323 I-0.0489 J-0.0257
X2.488 Y1.1435 I-0.0343 J-0.0382
X2.462 Y1.1458 I-0.019 J-0.0685
X2.4421 Y1.1402 I0.0059 J-0.0596
X2.4228 Y1.1234 I0.0235 J-0.0464
X2.414 Y1.1065 I0.0637 J-0.044
X2.4073 Y1.0819 I0.1267 J-0.0475
X2.4031 Y1.0282 I0.2885 J-0.0495
X2.406 Y0.9811 I0.3425 J-0.0028
X2.4112 Y0.9557 I0.1805 J0.0235
X2.4183 Y0.9369 I0.1044 J0.0292
X2.4362 Y0.9154 I0.049 J0.0225
X2.4518 Y0.9083 I0.0283 J0.0417
X2.47 Y0.9061 I0.0175 J0.067
X2.4975 Y0.912 I0.0012 J0.0613
X2.5168 Y0.9288 I-0.0235 J0.0464
X2.5256 Y0.9457 I-0.0636 J0.0439
X2.5323 Y0.9703 I-0.1269 J0.0475
G00 Z0.1
X2.7336 Y1.1816
G01 Z-0.05 F5.
Y0.8703 F10.
G02 X2.7324 Y0.8593 I-0.0528 J0.
X2.73 Y0.8528 I-0.0245 J0.0053
G01 X2.8438
G02 X2.8412 Y0.8604 I0.0237 J0.0124
X2.8402 Y0.8706 I0.0562 J0.0102
G01 Y0.9957
X2.8869 Y0.8703
G02 X2.8913 Y0.8528 I-0.0541 J-0.0228
G01 X3.0282
G02 X3.0165 Y0.8702 I0.0557 J0.0498
G01 X2.9265 Y1.0578
X3.0006 Y1.1831
G02 X3.014 Y1.1994 I0.0596 J-0.0353
G01 X2.9265
G02 X2.9193 Y1.1816 I-0.0674 J0.0168
G01 X2.8402 Y1.0442
Y1.1819
G02 X2.8414 Y1.1929 I0.0528 J0.
X2.8438 Y1.1994 I0.0245 J-0.0053
G01 X2.73
G02 X2.7327 Y1.1919 I-0.0226 J-0.0121
X2.7336 Y1.1816 I-0.057 J-0.0103
G00 Z0.1
X3.3291 Y0.9703
G01 Z-0.05 F5.
G03 X3.3332 Y1.0242 I-0.29 J0.0497 F10.
X3.3304 Y1.0719 I-0.3473 J0.003
X3.3252 Y1.0971 I-0.1753 J-0.0227
X3.3173 Y1.1169 I-0.0979 J-0.0276
X3.3053 Y1.1323 I-0.0489 J-0.0257
X3.2848 Y1.1435 I-0.0343 J-0.0382
X3.2587 Y1.1458 I-0.019 J-0.0685
X3.2388 Y1.1402 I0.0059 J-0.0596
X3.2195 Y1.1234 I0.0235 J-0.0464
X3.2108 Y1.1065 I0.0637 J-0.044
X3.2041 Y1.0819 I0.1267 J-0.0475
X3.1999 Y1.0282 I0.2885 J-0.0495
X3.2028 Y0.9811 I0.3425 J-0.0028
X3.208 Y0.9557 I0.1805 J0.0235
X3.2151 Y0.9369 I0.1044 J0.0292
X3.233 Y0.9154 I0.049 J0.0225
X3.2486 Y0.9083 I0.0283 J0.0417
X3.2668 Y0.9061 I0.0175 J0.067
X3.2943 Y0.912 I0.0012 J0.0613
X3.3136 Y0.9288 I-0.0235 J0.0464
X3.3224 Y0.9457 I-0.0636 J0.0439
X3.3291 Y0.9703 I-0.1269 J0.0475
G00 Z0.1
G53 Z0
G53 Y0
M05
M09
M30
Sample Emboss Surface:
temporary image hosting
G90 G80 G40 G20 G17
(FEATURE SLICE PLANAR)
(TOOL #2 0.125 Ball End Mill)
T2 M06
M00
S3000 M03
G54 X0. Y1.9993
G00 G43 H2 D2 Z0.1 M08
G01 Z-0.0103 F5.
X0.0007 Y2. Z-0.0101 F20.
Z-0.0055
X0.0141
X0. Y1.9859 Z-0.0119
Y1.9717
Z-0.0172
X0.0141 Y1.9859 Z-0.0072
X0.0283 Y2. Z-0.004
X0.0424
Z-0.0056
X0.0319 Y1.9894 Z-0.005
X0.0212 Y1.9788 Z-0.008
X0.0106 Y1.9682 Z-0.0154
X0. Y1.9576 Z-0.0255
Y1.9434
Z-0.0353
X0.0141 Y1.9576 Z-0.0206
X0.0283 Y1.9717 Z-0.0098
X0.0424 Y1.9858 Z-0.0065
X0.0566 Y2. Z-0.01
X0.0707
Z-0.0152
X0.0619 Y1.9912 Z-0.0105
X0.053 Y1.9823 Z-0.0086
X0.0442 Y1.9735 Z-0.009
X0.0354 Y1.9646 Z-0.0119
X0.0265 Y1.9558 Z-0.0179
X0.0088 Y1.9381 Z-0.0349
X0.0044 Y1.9337 Z-0.0409
X0. Y1.9293 Z-0.049
Y1.9151
Z-0.0642
X0.0141 Y1.9293 Z-0.0397
X0.0283 Y1.9434 Z-0.0251
X0.0424 Y1.9576 Z-0.0143
X0.0566 Y1.9717 Z-0.0108
X0.0707 Y1.9859 Z-0.0134
X0.0849 Y2. Z-0.0229
X0.099
Z-0.0318
X0.0825 Y1.9835 Z-0.0186
X0.0742 Y1.9753 Z-0.0147
X0.066 Y1.967 Z-0.0133
X0.0577 Y1.9588 Z-0.014
X0.0495 Y1.9505 Z-0.0167
X0.0412 Y1.9423 Z-0.0221
X0.0247 Y1.9258 Z-0.0382
X0.0165 Y1.9175 Z-0.0496
X0.0082 Y1.9093 Z-0.0645
X0. Y1.901 Z-0.0847
Y1.8869
X0.0377 Y1.9246 Z-0.0347
X0.0471 Y1.934 Z-0.0261
X0.0566 Y1.9434 Z-0.0195
X0.066 Y1.9529 Z-0.0165
X0.0754 Y1.9623 Z-0.016
X0.0849 Y1.9717 Z-0.0185
X0.0943 Y1.9811 Z-0.0244
X0.1037 Y1.9906 Z-0.0321
X0.1131 Y2. Z-0.0421
X0.1273
Z-0.0548
X0.1193 Y1.992 Z-0.044
X0.1114 Y1.9841 Z-0.0356
X0.0955 Y1.9682 Z-0.0234
X0.0876 Y1.9603 Z-0.0201
X0.0798 Y1.9525 Z-0.0189
X0.0717 Y1.9444 Z-0.0197
X0.0636 Y1.9364 Z-0.0225
X0.0398 Y1.9125 Z-0.0425
X0.0318 Y1.9045 Z-0.0533
X0.0239 Y1.8966 Z-0.0673
X0.0199 Y1.8926 Z-0.0763
X0.0169 Y1.8896 Z-0.0847
X0. Y1.8727
Y1.8586
X0.0243 Y1.8829
X0.0254 Y1.884 Z-0.0841
X0.0265 Y1.8851 Z-0.0809
X0.0309 Y1.8895 Z-0.0705
X0.0442 Y1.9028 Z-0.0487
X0.0619 Y1.9205 Z-0.0311
X0.0707 Y1.9293 Z-0.0251
X0.0794 Y1.938 Z-0.0223
X0.088 Y1.9466 Z-0.022
X0.0971 Y1.9556 Z-0.0241
X0.1061 Y1.9646 Z-0.0289
X0.1149 Y1.9735 Z-0.0353
X0.1237 Y1.9823 Z-0.044
X0.137 Y1.9956 Z-0.0622
X0.1414 Y2. Z-0.0713
X0.1556
Z-0.0847
X0.1531 Y1.9976
X0.1519 Y1.9964 Z-0.0834
X0.1458 Y1.9903 Z-0.0683
X0.1361 Y1.9806 Z-0.0541
X0.1264 Y1.9708 Z-0.0429
X0.1167 Y1.9611 Z-0.0344
X0.1063 Y1.9508 Z-0.0283
X0.096 Y1.9404 Z-0.0254
X0.0869 Y1.9313 Z-0.0255
X0.0778 Y1.9222 Z-0.0284
X0.0681 Y1.9125 Z-0.0352
X0.0583 Y1.9028 Z-0.0443
X0.0486 Y1.8931 Z-0.0554
X0.0389 Y1.8833 Z-0.0718
X0.0328 Y1.8773 Z-0.0847
X0. Y1.8444
Y1.8303
X0.0414 Y1.8717 Z-0.0847
X0.0424 Y1.8727 Z-0.0821
X0.0509 Y1.8812 Z-0.0661
X0.0594 Y1.8897 Z-0.0537
X0.0764 Y1.9067 Z-0.0372
X0.0849 Y1.9151 Z-0.0316
X0.1018 Y1.9321 Z-0.0279
X0.1103 Y1.9406 Z-0.0295
X0.1188 Y1.9491 Z-0.0338
X0.1358 Y1.9661 Z-0.0478
X0.1527 Y1.983 Z-0.0712
X0.1591 Y1.9894 Z-0.0847
X0.1697 Y2.
X0.1838
X0.1655 Y1.9816
X0.1563 Y1.9724 Z-0.0687
X0.1471 Y1.9632 Z-0.0562
X0.1379 Y1.954 Z-0.0466
X0.1287 Y1.9448 Z-0.0393
X0.1195 Y1.9357 Z-0.0344
X0.1103 Y1.9265 Z-0.0315
X0.1011 Y1.9173
X0.0919 Y1.9081 Z-0.0345
X0.0827 Y1.8989 Z-0.0411
X0.0735 Y1.8897 Z-0.0495
X0.0643 Y1.8805 Z-0.0597
X0.0506 Y1.8667 Z-0.083
X0.046 Y1.8621 Z-0.0847
X0. Y1.8162
Y1.802
X0.0297 Y1.8317 Z-0.0839
X0.0648 Y1.8668 Z-0.0699
X0.072 Y1.874 Z-0.0614
X0.0891 Y1.8911 Z-0.0449
X0.099 Y1.901 Z-0.0378
X0.1089 Y1.9109 Z-0.0347
X0.1188 Y1.9208 Z-0.0345
X0.1287 Y1.9307 Z-0.0375
X0.1485 Y1.9505 Z-0.0525
X0.1584 Y1.9604 Z-0.0649
X0.198 Y2. Z-0.0815
Z-0.0664
X0.2121
X0.1768 Y1.9646 Z-0.0525
X0.1414 Y1.9293 Z-0.044
X0.1328 Y1.9206 Z-0.0393
X0.1241 Y1.912 Z-0.0374
X0.1151 Y1.903 Z-0.038
X0.0707 Y1.8586 Z-0.052
X0. Y1.7879 Z-0.0815
Z-0.0588
Y1.7737
X0.0052 Y1.7789 Z-0.0715
X0.0754 Y1.8492 Z-0.0422
X0.0943 Y1.868 Z-0.037
X0.1317 Y1.9054 Z-0.0328
X0.1508 Y1.9246 Z-0.0341
X0.1886 Y1.9623 Z-0.0432
X0.2263 Y2. Z-0.0583
Z-0.0518
X0.2404
X0.2003 Y1.9599 Z-0.0353
X0.1603 Y1.9199 Z-0.0245
X0.1381 Y1.8977 Z-0.023
X0.1202 Y1.8798 Z-0.0241
X0.1002 Y1.8598 Z-0.0275
X0.0801 Y1.8397 Z-0.0333
X0.0177 Y1.7773 Z-0.0594
X0.0133 Y1.7728 Z-0.0602
X0.0088 Y1.7684 Z-0.0511
X0. Y1.7596 Z-0.0402
Z-0.0276
Y1.7454
X0.0135 Y1.7589 Z-0.0415
X0.0202 Y1.7656 Z-0.0519
X0.0219 Y1.7673 Z-0.0535
X0.0727 Y1.8182 Z-0.0317
X0.1091 Y1.8545 Z-0.0202
X0.1273 Y1.8727 Z-0.0172
X0.1455 Y1.8909 Z-0.0162
X0.1818 Y1.9273 Z-0.0204
X0.2182 Y1.9636 Z-0.0321
X0.2546 Y2. Z-0.0479
Z-0.0449
X0.2687
X0.2111 Y1.9424 Z-0.0206
X0.1727 Y1.904 Z-0.0116
X0.1535 Y1.8848 Z-0.0102
X0.1344 Y1.8656 Z-0.0112
X0.1152 Y1.8465 Z-0.0145
X0.0768 Y1.8081 Z-0.0268
X0.0282 Y1.7595 Z-0.0479
X0.0252 Y1.7565 Z-0.0446
X0.0096 Y1.7409 Z-0.0248
X0. Y1.7313 Z-0.0181
Z-0.0109
Y1.7172
X0.0101 Y1.7273 Z-0.0172
X0.0202 Y1.7374 Z-0.0255
X0.0303 Y1.7475 Z-0.0404
X0.0328 Y1.75 Z-0.0434
X0.0808 Y1.798 Z-0.0226
X0.1212 Y1.8384 Z-0.0094
X0.1414 Y1.8586 Z-0.006
X0.1616 Y1.8788 Z-0.005
X0.1818 Y1.899 Z-0.0065
X0.202 Y1.9192 Z-0.0109
X0.2424 Y1.9596 Z-0.0252
X0.2828 Y2. Z-0.0426
X0.297 Z-0.0416
X0.2227 Y1.9258 Z-0.0115
X0.1856 Y1.8886 Z-0.0029
X0.1672 Y1.8702 Z-0.0018
X0.1299 Y1.8329 Z-0.0057
X0.1114 Y1.8144 Z-0.0107
X0.0557 Y1.7587 Z-0.0334
X0.0371 Y1.7401 Z-0.0391
X0.0278 Y1.7309 Z-0.0252
X0.0186 Y1.7216 Z-0.0161
X0.0093 Y1.7123 Z-0.0099
X0. Y1.703 Z-0.006
Z-0.0015
Y1.6889
X0.0097 Y1.6986 Z-0.0052
X0.0194 Y1.7083 Z-0.011
X0.0292 Y1.718 Z-0.0191
X0.0389 Y1.7278 Z-0.0299
X0.0438 Y1.7327 Z-0.038
X0.0511 Y1.7399 Z-0.0368
X0.1167 Y1.8055 Z-0.0097
X0.1361 Y1.825 Z-0.0044
X0.1556 Y1.8444 Z-0.0012
X0.1745 Y1.8633 Z-0.0003
X0.1945 Y1.8833 Z-0.0016
X0.2333 Y1.9222 Z-0.011
X0.3008 Y1.9897 Z-0.0391
X0.3035 Y1.9924
X0.3111 Y2. Z-0.0312
Z-0.022
X0.3253
X0.3138 Y1.9886 Z-0.0303
X0.3067 Y1.9814 Z-0.0389
X0.244 Y1.9187 Z-0.0125
X0.2033 Y1.878 Z-0.0019
X0.1813 Y1.856 Z-0.0004
X0.1626 Y1.8374 Z-0.0014
X0.1423 Y1.817 Z-0.0047
X0.122 Y1.7967 Z-0.0104
X0.0528 Y1.7275 Z-0.0391
X0.0407 Y1.7154 Z-0.0234
X0.0305 Y1.7052 Z-0.0138
X0.0203 Y1.6951 Z-0.0067
X0.0102 Y1.6849 Z-0.0016
X0. Y1.6747 Z-0.0001
Y1.6606
Z-0.0014
X0.0087 Y1.6693 Z-0.0005
X0.0189 Y1.6794 Z-0.0025
X0.0283 Y1.6889 Z-0.007
X0.0471 Y1.7077 Z-0.0231
X0.0566 Y1.7172 Z-0.0359
X0.0589 Y1.7195 Z-0.0402
X0.0613 Y1.7219 Z-0.0403
X0.1131 Y1.7737 Z-0.018
X0.1508 Y1.8114 Z-0.0061
X0.1886 Y1.8492 Z-0.0021
X0.2074 Y1.868 Z-0.0034
X0.2263 Y1.8869 Z-0.0068
X0.264 Y1.9246 Z-0.0193
X0.3113 Y1.9719 Z-0.0397
X0.3144 Y1.975 Z-0.0352
X0.3206 Y1.9811 Z-0.0279
X0.3394 Y2. Z-0.0151
Z-0.01
X0.3536
X0.3437 Y1.9902 Z-0.0144
X0.3339 Y1.9804 Z-0.0212
X0.3143 Y1.9607 Z-0.0412
X0.275 Y1.9214 Z-0.024
X0.2357 Y1.8821 Z-0.011
X0.2161 Y1.8625 Z-0.0067
X0.1768 Y1.8232 Z-0.0064
X0.1571 Y1.8036 Z-0.0096
X0.1179 Y1.7643 Z-0.0221
X0.0685 Y1.7149 Z-0.0436
X0.0653 Y1.7117 Z-0.0394
X0.0589 Y1.7054 Z-0.0293
X0.0491 Y1.6956 Z-0.0186
X0.0393 Y1.6857 Z-0.0108
X0.0289 Y1.6753 Z-0.0045
X0.0185 Y1.665 Z-0.0014
X0.0093 Y1.6557 Z-0.0017
X0. Y1.6464 Z-0.0048
Y1.6323
Z-0.0101
X0.0101 Y1.6424 Z-0.0041
X0.0201 Y1.6524 Z-0.0019
X0.0305 Y1.6628 Z-0.0031
X0.0409 Y1.6732 Z-0.0075
X0.0613 Y1.6936 Z-0.0246
X0.0772 Y1.7095 Z-0.0477
X0.1226 Y1.7549 Z-0.0281
X0.1634 Y1.7957 Z-0.0144
X0.1838 Y1.8162 Z-0.011
X0.2247 Y1.857 Z-0.0115
X0.2656 Y1.8979 Z-0.0228
X0.3226 Y1.9549 Z-0.0456
X0.3268 Y1.9591 Z-0.0377
X0.3371 Y1.9694 Z-0.025
X0.3473 Y1.9796 Z-0.0162
X0.3575 Y1.9898 Z-0.0097
X0.3677 Y2. Z-0.0059
Z-0.0039
X0.3818
X0.3723 Y1.9905 Z-0.0056
X0.3627 Y1.9809 Z-0.0106
X0.3532 Y1.9714 Z-0.0174
X0.3437 Y1.9618 Z-0.027
X0.3327 Y1.9509 Z-0.041
X0.3273 Y1.9454 Z-0.0518
X0.2673 Y1.8854 Z-0.0262
X0.2291 Y1.8473 Z-0.0173
X0.2098 Y1.828 Z-0.0158
X0.1909 Y1.8091 Z-0.0168
X0.1718 Y1.79 Z-0.0201
X0.1527 Y1.7709 Z-0.0255
X0.0868 Y1.7049 Z-0.0529
X0.0764 Y1.6945 Z-0.0363
X0.0668 Y1.685 Z-0.0244
X0.0573 Y1.6754 Z-0.0158
X0.0477 Y1.6659 Z-0.0087
X0.0382 Y1.6563 Z-0.0046
X0.0295 Y1.6476 Z-0.0032
X0.0191 Y1.6373 Z-0.0047
X0.0095 Y1.6277 Z-0.0095
X0. Y1.6182 Z-0.0173
Y1.604
Z-0.0252
X0.0099 Y1.6139 Z-0.0161
X0.0198 Y1.6238 Z-0.0092
X0.0297 Y1.6337 Z-0.0055
X0.0396 Y1.6436 Z-0.0051
X0.0495 Y1.6535 Z-0.0079
X0.0594 Y1.6634 Z-0.0137
X0.0693 Y1.6733 Z-0.0213
X0.0792 Y1.6832 Z-0.0319
X0.0896 Y1.6937 Z-0.0484
X0.0949 Y1.6989 Z-0.0585
X0.1584 Y1.7624 Z-0.0327
X0.1782 Y1.7822 Z-0.0272
X0.198 Y1.802 Z-0.0238
X0.2162 Y1.8202 Z-0.0228
X0.2376 Y1.8416 Z-0.0242
X0.2772 Y1.8812 Z-0.0345
X0.3329 Y1.9369 Z-0.0579
X0.3366 Y1.9406 Z-0.049
X0.3415 Y1.9456 Z-0.0399
X0.3465 Y1.9505 Z-0.0333
X0.3564 Y1.9604 Z-0.0225
X0.3762 Y1.9802 Z-0.0076
X0.3861 Y1.9901 Z-0.0048
X0.396 Y2. Z-0.0052
X0.4101
Z-0.0095
X0.4012 Y1.9911 Z-0.0068
X0.3906 Y1.9805 Z-0.0071
X0.3799 Y1.9697 Z-0.0113
X0.3589 Y1.9487 Z-0.029
X0.3486 Y1.9385 Z-0.0419
X0.3435 Y1.9334 Z-0.0514
X0.3384 Y1.9282 Z-0.0644
X0.3281 Y1.918 Z-0.0622
X0.2871 Y1.877 Z-0.0446
X0.2461 Y1.836 Z-0.0333
X0.2233 Y1.8132 Z-0.0316
X0.2051 Y1.7949 Z-0.0327
X0.1846 Y1.7744 Z-0.0365
X0.164 Y1.7539 Z-0.0426
X0.1051 Y1.695 Z-0.0671
X0.1045 Y1.6943 Z-0.0674
X0.1025 Y1.6924 Z-0.0621
X0.0923 Y1.6822 Z-0.0429
X0.082 Y1.6719 Z-0.0292
X0.0718 Y1.6616 Z-0.0194
X0.0615 Y1.6514 Z-0.0127
X0.0513 Y1.6411 Z-0.0079
X0.041 Y1.6309 Z-0.0068
X0.0308 Y1.6206 Z-0.0093
X0.0205 Y1.6104 Z-0.0156
X0.0103 Y1.6001 Z-0.0244
X0. Y1.5899 Z-0.0361
Y1.5757
Z-0.048
X0.0096 Y1.5854 Z-0.0343
X0.0289 Y1.6047 Z-0.0162
X0.0386 Y1.6143 Z-0.0106
X0.0469 Y1.6226 Z-0.0086
X0.0564 Y1.6321 Z-0.0091
X0.0668 Y1.6425 Z-0.013
X0.0771 Y1.6529 Z-0.0199
X0.0868 Y1.6625 Z-0.0287
X0.0964 Y1.6722 Z-0.0401
X0.1061 Y1.6818 Z-0.0564
X0.1109 Y1.6866 Z-0.0681
X0.1133 Y1.689 Z-0.0769
X0.1157 Y1.6914 Z-0.0772
X0.1543 Y1.73 Z-0.0605
X0.1928 Y1.7686 Z-0.0478
X0.2054 Y1.7811 Z-0.0452
X0.2121 Y1.7879 Z-0.0409
X0.2218 Y1.7975 Z-0.0378
X0.2314 Y1.8072 Z-0.0375
X0.2507 Y1.8264 Z-0.0447
X0.27 Y1.8457 Z-0.0487
X0.3086 Y1.8843 Z-0.0621
X0.3422 Y1.9179 Z-0.0765
X0.3471 Y1.9229 Z-0.0615
X0.3519 Y1.9277 Z-0.0507
X0.3568 Y1.9325 Z-0.0421
X0.3664 Y1.9421 Z-0.0307
X0.3761 Y1.9518 Z-0.0214
X0.3857 Y1.9614 Z-0.0142
X0.395 Y1.9708 Z-0.0099
X0.4044 Y1.9801 Z-0.0086
X0.4143 Y1.9901 Z-0.0105
X0.4243 Y2. Z-0.0153
X0.4384
Z-0.0227
X0.4277 Y1.9893 Z-0.0153
X0.417 Y1.9786 Z-0.0112
X0.4071 Y1.9687 Z-0.0108
X0.3986 Y1.9601 Z-0.0131
X0.3886 Y1.9502 Z-0.0194
X0.3786 Y1.9402 Z-0.0278
X0.3637 Y1.9253 Z-0.0449
X0.3587 Y1.9203 Z-0.0538
X0.3538 Y1.9154 Z-0.0654
X0.3513 Y1.9129 Z-0.0731
X0.3488 Y1.9104 Z-0.0832
X0.339 Y1.9006 Z-0.0847
X0.3289 Y1.8905 Z-0.0831
X0.279 Y1.8406 Z-0.0643
X0.269 Y1.8306 Z-0.0528
X0.2591 Y1.8207 Z-0.0445
X0.2491 Y1.8107 Z-0.0377
X0.2391 Y1.8007 Z-0.0346
X0.2292 Y1.7908
X0.2192 Y1.7808 Z-0.0377
X0.2092 Y1.7708 Z-0.045
X0.1993 Y1.7609 Z-0.0542
X0.1891 Y1.7507 Z-0.0657
X0.142 Y1.7036 Z-0.0843
X0.1214 Y1.683 Z-0.0847
X0.1196 Y1.6812 Z-0.0763
X0.1146 Y1.6762 Z-0.0618
X0.0996 Y1.6612 Z-0.0372
X0.0897 Y1.6513 Z-0.0267
X0.0695 Y1.6311 Z-0.0134
X0.0593 Y1.6209 Z-0.011
X0.0496 Y1.6112 Z-0.0119
X0.0399 Y1.6014 Z-0.016
X0.0299 Y1.5915 Z-0.0233
X0.0199 Y1.5815 Z-0.0329
X0.005 Y1.5666 Z-0.0542
X0. Y1.5616 Z-0.066
Y1.5475
Z-0.0847
X0.0026 Y1.55 Z-0.0841
X0.0051 Y1.5526 Z-0.0741
X0.0103 Y1.5577 Z-0.0601
X0.0154 Y1.5629 Z-0.0511
X0.0309 Y1.5783 Z-0.0318
X0.0411 Y1.5886 Z-0.0228
X0.0515 Y1.599 Z-0.0163
X0.0619 Y1.6094 Z-0.0137
X0.0721 Y1.6196 Z-0.0147
X0.0823 Y1.6297 Z-0.019
X0.0926 Y1.64 Z-0.0259
X0.108 Y1.6554 Z-0.0415
X0.1183 Y1.6657 Z-0.058
X0.1234 Y1.6709 Z-0.0683
X0.1286 Y1.676 Z-0.0847
X0.183 Y1.7305
X0.1982 Y1.7456 Z-0.0603
X0.216 Y1.7634 Z-0.0422
X0.2263 Y1.7737 Z-0.035
X0.2366 Y1.784 Z-0.0317
X0.2468 Y1.7943 Z-0.0316
X0.2571 Y1.8046 Z-0.0352
X0.2674 Y1.8149 Z-0.0425
X0.2777 Y1.8252 Z-0.0516
X0.2931 Y1.8406 Z-0.0728
X0.2983 Y1.8457 Z-0.0837
X0.3548 Y1.9023 Z-0.0847
X0.3561 Y1.9036 Z-0.0846
X0.3574 Y1.9049 Z-0.0785
X0.36 Y1.9074 Z-0.0703
X0.3651 Y1.9126 Z-0.0576
X0.3703 Y1.9177 Z-0.0482
X0.3806 Y1.928 Z-0.0355
X0.4011 Y1.9486 Z-0.0181
X0.4114 Y1.9589 Z-0.014
X0.4217 Y1.9691 Z-0.0135
X0.432 Y1.9794 Z-0.0166
X0.4423 Y1.9897 Z-0.0226
X0.4525 Y2. Z-0.0318
X0.4667
Z-0.0426
X0.457 Y1.9903 Z-0.0317
X0.4472 Y1.9806 Z-0.0239
X0.4375 Y1.9708 Z-0.0191
X0.4278 Y1.9611 Z-0.0166
X0.4181 Y1.9514 Z-0.0173
X0.4084 Y1.9417 Z-0.0213
X0.3986 Y1.9319 Z-0.0279
X0.3889 Y1.9222 Z-0.037
X0.3792 Y1.9125 Z-0.0484
X0.3743 Y1.9076 Z-0.0563
X0.3695 Y1.9028 Z-0.0671
X0.3634 Y1.8967 Z-0.0847
X0.3087 Y1.842
X0.3063 Y1.8396 Z-0.0832
X0.3014 Y1.8347 Z-0.0717
X0.2917 Y1.825 Z-0.0573
X0.282 Y1.8153 Z-0.0456
X0.2626 Y1.7959 Z-0.0311
X0.2529 Y1.7863 Z-0.0282
X0.2431 Y1.7765 Z-0.0285
X0.2333 Y1.7667 Z-0.0318
X0.2236 Y1.7569 Z-0.0385
X0.2042 Y1.7375 Z-0.0585
X0.1896 Y1.7229 Z-0.0847
X0.1349 Y1.6682
X0.1313 Y1.6646 Z-0.0733
X0.1264 Y1.6597 Z-0.0627
X0.1167 Y1.65 Z-0.0466
X0.1069 Y1.6403 Z-0.0354
X0.0972 Y1.6305 Z-0.0265
X0.0875 Y1.6208 Z-0.0203
X0.0778 Y1.6111 Z-0.0165
X0.0681 Y1.6014 Z-0.016
X0.0583 Y1.5916 Z-0.0187
X0.0486 Y1.5819 Z-0.0251
X0.0389 Y1.5722 Z-0.0333
X0.0292 Y1.5625 Z-0.0448
X0.0194 Y1.5528 Z-0.0591
X0.0146 Y1.5479 Z-0.0699
X0.0097 Y1.543 Z-0.0847
X0. Y1.5333
Y1.5192
X0.0175 Y1.5367
X0.025 Y1.5442 Z-0.065
X0.0301 Y1.5492 Z-0.0563
X0.0401 Y1.5592 Z-0.0424
X0.0601 Y1.5793 Z-0.0247
X0.0701 Y1.5893 Z-0.02
X0.0801 Y1.5993 Z-0.0189
X0.0902 Y1.6093 Z-0.0212
X0.1002 Y1.6193 Z-0.0264
X0.1202 Y1.6394 Z-0.0448
X0.1352 Y1.6544 Z-0.0692
X0.1402 Y1.6594 Z-0.0825
X0.1409 Y1.66 Z-0.0847
X0.1953 Y1.7145
X0.2003 Y1.7195 Z-0.0741
X0.2104 Y1.7295 Z-0.0569
X0.2204 Y1.7395 Z-0.045
X0.2304 Y1.7496 Z-0.0355
X0.2404 Y1.7596 Z-0.0285
X0.2495 Y1.7686 Z-0.0256
X0.2585 Y1.7777 Z-0.0255
X0.2695 Y1.7887 Z-0.0289
X0.2805 Y1.7997 Z-0.0352
X0.2905 Y1.8097 Z-0.0443
X0.3055 Y1.8247 Z-0.0635
X0.3105 Y1.8297 Z-0.0726
X0.3155 Y1.8347 Z-0.0847
X0.3706 Y1.8898
X0.3807 Y1.8998 Z-0.0608
X0.3857 Y1.9048 Z-0.0523
X0.3907 Y1.9098 Z-0.0459
X0.4007 Y1.9199 Z-0.0356
X0.4107 Y1.9299 Z-0.0272
X0.4207 Y1.9399 Z-0.0213
X0.4307 Y1.9499 Z-0.0192
X0.4408 Y1.9599 Z-0.0205
X0.4508 Y1.9699 Z-0.0248
X0.4608 Y1.98 Z-0.032
X0.4708 Y1.99 Z-0.0424
X0.4808 Y2. Z-0.0555
X0.495
Z-0.0701
X0.4847 Y1.9897 Z-0.053
X0.4744 Y1.9794 Z-0.0408
X0.464 Y1.9691 Z-0.0318
X0.4537 Y1.9588 Z-0.0255
X0.444 Y1.9491 Z-0.0222
X0.4343 Y1.9394
X0.4234 Y1.9284 Z-0.0261
X0.4125 Y1.9175 Z-0.034
X0.4022 Y1.9072 Z-0.044
X0.3919 Y1.8969 Z-0.0561
X0.3867 Y1.8917 Z-0.0656
X0.379 Y1.884 Z-0.0847
X0.3235 Y1.8286
X0.3222 Y1.8273 Z-0.0821
X0.3145 Y1.8195 Z-0.0634
X0.299 Y1.8041 Z-0.0425
X0.2887 Y1.7938 Z-0.0328
X0.2779 Y1.7829 Z-0.0257
X0.267 Y1.772 Z-0.0222
X0.2572 Y1.7623
X0.2475 Y1.7525 Z-0.0252
X0.2372 Y1.7422 Z-0.0325
X0.2269 Y1.7319 Z-0.0424
X0.2166 Y1.7216 Z-0.055
X0.2062 Y1.7113 Z-0.0733
X0.2011 Y1.7061 Z-0.0847
X0.1469 Y1.652 Z-0.0845
X0.1444 Y1.6494 Z-0.0766
X0.1392 Y1.6442 Z-0.066
X0.1289 Y1.6339 Z-0.0495
X0.1237 Y1.6288 Z-0.0437
X0.1134 Y1.6185 Z-0.0343
X0.1031 Y1.6081 Z-0.027
X0.0928 Y1.5978 Z-0.0228
X0.0825 Y1.5875 Z-0.0221
X0.0722 Y1.5772 Z-0.0249
X0.0619 Y1.5669 Z-0.0318
X0.0516 Y1.5566 Z-0.0405
X0.0464 Y1.5514 Z-0.046
X0.0361 Y1.5411 Z-0.0604
X0.0309 Y1.536 Z-0.0702
X0.0258 Y1.5308 Z-0.0847
X0. Y1.505
Y1.4909
X0.0294 Y1.5203
X0.0343 Y1.5252 Z-0.0835
X0.0392 Y1.53 Z-0.0709
X0.0441 Y1.5349 Z-0.0624
X0.0587 Y1.5496 Z-0.0437
X0.0783 Y1.5692 Z-0.0284
X0.0872 Y1.5781 Z-0.0253
X0.0962 Y1.5871 Z-0.0251
X0.1068 Y1.5977 Z-0.0285
X0.1175 Y1.6084 Z-0.0349
X0.1371 Y1.628 Z-0.0543
X0.1567 Y1.6475 Z-0.0847
X0.2081 Y1.6989
X0.2105 Y1.7014 Z-0.077
X0.2154 Y1.7063 Z-0.0661
X0.2252 Y1.7161 Z-0.0494
X0.2448 Y1.7357 Z-0.0294
X0.2546 Y1.7454 Z-0.0224
X0.2643 Y1.7552 Z-0.0193
X0.2741 Y1.765
X0.2839 Y1.7748 Z-0.0222
X0.2937 Y1.7846 Z-0.0286
X0.3035 Y1.7944 Z-0.0368
X0.3133 Y1.8042 Z-0.0485
X0.3231 Y1.814 Z-0.063
X0.328 Y1.8189 Z-0.075
X0.331 Y1.8219 Z-0.0847
X0.3867 Y1.8776
X0.388 Y1.8788 Z-0.0836
X0.3916 Y1.8825 Z-0.0736
X0.3965 Y1.8874 Z-0.0634
X0.4014 Y1.8923 Z-0.0559
X0.4112 Y1.9021 Z-0.0451
X0.4308 Y1.9217 Z-0.0292
X0.4399 Y1.9308 Z-0.0257
X0.449 Y1.9399 Z-0.0251
X0.4595 Y1.9504 Z-0.0281
X0.47 Y1.9608 Z-0.0341
X0.4797 Y1.9706 Z-0.0423
X0.4895 Y1.9804 Z-0.0536
X0.5091 Y2. Z-0.0847
X0.5233
X0.5132 Y1.9899
X0.5082 Y1.9849 Z-0.0745
X0.4931 Y1.9698 Z-0.0528
X0.483 Y1.9597 Z-0.0422
X0.4722 Y1.949 Z-0.0338
X0.4615 Y1.9382 Z-0.0291
X0.4513 Y1.928 Z-0.0281
X0.4428 Y1.9195 Z-0.0299
X0.4327 Y1.9094 Z-0.0354
X0.4226 Y1.8994 Z-0.044
X0.4075 Y1.8843 Z-0.0605
X0.4025 Y1.8792 Z-0.0687
X0.3975 Y1.8742 Z-0.0799
X0.3962 Y1.873 Z-0.0833
X0.395 Y1.8717 Z-0.0847
X0.339 Y1.8157
X0.3371 Y1.8138 Z-0.0783
X0.3321 Y1.8088 Z-0.0646
X0.327 Y1.8038 Z-0.0551
X0.3119 Y1.7887 Z-0.0353
X0.3019 Y1.7786 Z-0.0264
X0.2918 Y1.7686 Z-0.0204
X0.2818 Y1.7585 Z-0.0167
X0.2717 Y1.7484 Z-0.0163
X0.2616 Y1.7384 Z-0.0194
X0.2516 Y1.7283 Z-0.0267
X0.2415 Y1.7182 Z-0.0363
X0.2314 Y1.7082 Z-0.0482
X0.2214 Y1.6981 Z-0.0657
X0.2163 Y1.6931 Z-0.0777
X0.2145 Y1.6912 Z-0.0847
X0.161 Y1.6377 Z-0.0847
X0.1409 Y1.6176 Z-0.0534
X0.1308 Y1.6076 Z-0.043
X0.1208 Y1.5975 Z-0.0354
X0.1103 Y1.587 Z-0.0301
X0.0998 Y1.5765 Z-0.0282
X0.0901 Y1.5669 Z-0.0297
X0.0805 Y1.5572 Z-0.0348
X0.0704 Y1.5472 Z-0.0424
X0.0604 Y1.5371 Z-0.0528
X0.0503 Y1.5271 Z-0.0669
X0.0453 Y1.522 Z-0.0763
X0.0428 Y1.5195 Z-0.083
X0.0403 Y1.517 Z-0.0847
X0. Y1.4767
Y1.4626
X0.0491 Y1.5117
X0.0504 Y1.513 Z-0.084
X0.0517 Y1.5143 Z-0.0807
X0.0568 Y1.5194 Z-0.0709
X0.0723 Y1.5349 Z-0.0508
X0.0827 Y1.5453 Z-0.0415
X0.0935 Y1.5561 Z-0.0346
X0.1042 Y1.5668 Z-0.0316
X0.1141 Y1.5767 Z-0.0324
X0.124 Y1.5866 Z-0.0369
X0.1344 Y1.5969 Z-0.0435
X0.1499 Y1.6125 Z-0.059
X0.1654 Y1.628 Z-0.0847
X0.2209 Y1.6835
X0.2222 Y1.6848 Z-0.0789
X0.2248 Y1.6874 Z-0.0708
X0.2274 Y1.69 Z-0.0648
X0.2377 Y1.7003 Z-0.0465
X0.248 Y1.7106 Z-0.0339
X0.2584 Y1.721 Z-0.0241
X0.2687 Y1.7313 Z-0.0169
X0.279 Y1.7416 Z-0.0137
X0.2894 Y1.752 Z-0.0137
X0.2997 Y1.7623 Z-0.0173
X0.31 Y1.7726 Z-0.0245
X0.3204 Y1.783 Z-0.0338
X0.3359 Y1.7985 Z-0.0551
X0.341 Y1.8036 Z-0.0662
X0.3462 Y1.8088 Z-0.0823
X0.3475 Y1.8101 Z-0.0847
X0.4031 Y1.8656
X0.4134 Y1.876 Z-0.0654
X0.4237 Y1.8863 Z-0.0527
X0.4444 Y1.907 Z-0.0356
X0.4547 Y1.9173 Z-0.0318
X0.4651 Y1.9277 Z-0.0317
X0.4754 Y1.938 Z-0.0351
X0.4857 Y1.9483 Z-0.0415
X0.4961 Y1.9587 Z-0.0512
X0.5064 Y1.969 Z-0.0636
X0.5193 Y1.9819 Z-0.0847
X0.5374 Y2.
Z-0.0787
X0.5515
X0.5121 Y1.9606 Z-0.0647
X0.5023 Y1.9508 Z-0.053
X0.4924 Y1.9409 Z-0.0444
X0.4826 Y1.9311 Z-0.0385
X0.4728 Y1.9212 Z-0.0352
X0.4629 Y1.9114 Z-0.0351
X0.4531 Y1.9015 Z-0.0384
X0.4432 Y1.8917 Z-0.0446
X0.4205 Y1.869 Z-0.0669
X0.3735 Y1.822 Z-0.0847
X0.3546 Y1.803 Z-0.0842
X0.3496 Y1.7981 Z-0.068
X0.3447 Y1.7932 Z-0.0555
X0.3349 Y1.7833 Z-0.0409
X0.325 Y1.7735 Z-0.0288
X0.3152 Y1.7636 Z-0.0206
X0.3054 Y1.7538 Z-0.014
X0.2956 Y1.744 Z-0.0109
X0.2857 Y1.7341 Z-0.0112
X0.2758 Y1.7242 Z-0.0142
X0.2659 Y1.7144 Z-0.0211
X0.2561 Y1.7045 Z-0.0303
X0.2462 Y1.6947 Z-0.0416
X0.2364 Y1.6848 Z-0.0583
X0.2319 Y1.6803 Z-0.0678
X0.2296 Y1.6781 Z-0.0747
X0.2274 Y1.6758 Z-0.0847
X0.2184 Y1.6668
X0.2077 Y1.6561 Z-0.0833
X0.1576 Y1.606 Z-0.0628
X0.1379 Y1.5863 Z-0.0434
X0.128 Y1.5765 Z-0.0377
X0.1182 Y1.5666 Z-0.0345
X0.1083 Y1.5568 Z-0.0347
X0.0985 Y1.5469 Z-0.0382
X0.0788 Y1.5272 Z-0.0541
X0.0694 Y1.5178 Z-0.066
X0.0197 Y1.4682 Z-0.0847
X0. Y1.4485
Z-0.0823
Y1.4343
X0.0404 Y1.4747 Z-0.0648
X0.101 Y1.5353 Z-0.0443
X0.1111 Y1.5454 Z-0.0389
X0.1212 Y1.5555 Z-0.0373
X0.1313 Y1.5656 Z-0.0392
X0.1414 Y1.5757 Z-0.0441
X0.1818 Y1.6161 Z-0.0548
X0.2311 Y1.6654 Z-0.0757
X0.2355 Y1.6698 Z-0.0769
X0.2368 Y1.6711 Z-0.0718
X0.2396 Y1.6739 Z-0.0636
X0.2424 Y1.6768 Z-0.0575
X0.2525 Y1.6869 Z-0.0401
X0.2626 Y1.697 Z-0.0285
X0.2727 Y1.7071 Z-0.0189
X0.2828 Y1.7172 Z-0.0118
X0.2919 Y1.7262 Z-0.0089
X0.3022 Y1.7365
X0.3127 Y1.747 Z-0.0121
X0.3232 Y1.7576 Z-0.0188
X0.3334 Y1.7677 Z-0.0277
X0.3485 Y1.7828 Z-0.0472
X0.3536 Y1.7879 Z-0.0567
X0.3611 Y1.7954 Z-0.0788
X0.3637 Y1.798 Z-0.078
X0.4041 Y1.8384 Z-0.0605
X0.4445 Y1.8788 Z-0.0477
X0.4647 Y1.899 Z-0.0391
X0.4753 Y1.9096 Z-0.0375
X0.4849 Y1.9192 Z-0.0393
X0.495 Y1.9293 Z-0.0441
X0.5253 Y1.9596 Z-0.0514
X0.5657 Y2. Z-0.067
Z-0.0579
X0.5798
X0.5384 Y1.9586 Z-0.041
X0.5177 Y1.9379 Z-0.0354
X0.497 Y1.9172 Z-0.0324
X0.4756 Y1.8957 Z-0.0319
X0.4556 Y1.8758 Z-0.0346
X0.4142 Y1.8343 Z-0.047
X0.3676 Y1.7877 Z-0.0666
X0.365 Y1.7852 Z-0.0664
X0.3624 Y1.7826 Z-0.0594
X0.3572 Y1.7774 Z-0.048
X0.3417 Y1.7619 Z-0.0268
X0.3313 Y1.7515 Z-0.0177
X0.3208 Y1.741 Z-0.0103
X0.3103 Y1.7305 Z-0.0068
X0.3001 Y1.7203 Z-0.0069
X0.2899 Y1.7101 Z-0.0101
X0.2796 Y1.6997 Z-0.0173
X0.2692 Y1.6894 Z-0.027
X0.2589 Y1.679 Z-0.0393
X0.2485 Y1.6687 Z-0.0577
X0.2459 Y1.666 Z-0.064
X0.2433 Y1.6635 Z-0.0649
X0.2381 Y1.6583 Z-0.0633
X0.2071 Y1.6273 Z-0.0494
X0.1657 Y1.5858 Z-0.0357
X0.145 Y1.5651 Z-0.0324
X0.1242 Y1.5444 Z-0.0319
X0.1035 Y1.5237 Z-0.0342
X0.0828 Y1.503 Z-0.0392
X0.0414 Y1.4616 Z-0.0546
X0.0046 Y1.4248 Z-0.0703
X0. Y1.4202 Z-0.0623
Z-0.0404
Y1.406
X0.0081 Y1.4141 Z-0.0523
X0.0121 Y1.4181 Z-0.0609
X0.0161 Y1.4222 Z-0.0599
X0.0792 Y1.4852 Z-0.0336
X0.099 Y1.505 Z-0.0278
X0.1188 Y1.5248 Z-0.0242
X0.1385 Y1.5445 Z-0.023
X0.1584 Y1.5644 Z-0.0244
X0.1782 Y1.5842 Z-0.0282
X0.198 Y1.604 Z-0.0341
X0.2475 Y1.6535 Z-0.0551
X0.2524 Y1.6585 Z-0.0567
X0.2549 Y1.6609 Z-0.0571
X0.2673 Y1.6733 Z-0.0353
X0.2772 Y1.6832 Z-0.0241
X0.2871 Y1.6931 Z-0.0148
X0.297 Y1.703 Z-0.0081
X0.3069 Y1.7129 Z-0.0051
X0.3168 Y1.7228 Z-0.0048
X0.3267 Y1.7327 Z-0.0079
X0.3366 Y1.7426 Z-0.0145
X0.3465 Y1.7525 Z-0.0227
X0.3564 Y1.7624 Z-0.0348
X0.3657 Y1.7717 Z-0.0487
X0.3704 Y1.7764 Z-0.0594
X0.4356 Y1.8416 Z-0.0325
X0.4554 Y1.8614 Z-0.0271
X0.4752 Y1.8812 Z-0.0238
X0.4948 Y1.9008 Z-0.0231
X0.5148 Y1.9208 Z-0.0249
X0.5346 Y1.9406 Z-0.029
X0.5544 Y1.9604 Z-0.0353
X0.594 Y2. Z-0.0518
Z-0.0479
X0.6081
X0.5676 Y1.9595 Z-0.0304
X0.527 Y1.9189 Z-0.0187
X0.5066 Y1.8985 Z-0.0162
X0.4865 Y1.8784 Z-0.0164
X0.4662 Y1.8581 Z-0.0192
X0.4459 Y1.8378 Z-0.0244
X0.3757 Y1.7676 Z-0.0533
X0.3711 Y1.763 Z-0.0439
X0.3547 Y1.7466 Z-0.0224
X0.3446 Y1.7365 Z-0.0135
X0.3345 Y1.7263 Z-0.0071
X0.3243 Y1.7162 Z-0.0039
X0.3142 Y1.7061 Z-0.0035
X0.3041 Y1.6959 Z-0.0065
X0.2939 Y1.6858 Z-0.0134
X0.2771 Y1.669 Z-0.0301
X0.2637 Y1.6556 Z-0.0517
X0.2027 Y1.5946 Z-0.0263
X0.1824 Y1.5743 Z-0.0204
X0.1622 Y1.5541 Z-0.0169
X0.142 Y1.5339 Z-0.016
X0.1216 Y1.5135 Z-0.0178
X0.1014 Y1.4932 Z-0.022
X0.0811 Y1.473 Z-0.0284
X0.0239 Y1.4158 Z-0.0528
X0.0192 Y1.411 Z-0.0522
X0.0144 Y1.4063 Z-0.0433
X0.0072 Y1.3991 Z-0.0341
X0. Y1.3919 Z-0.0284
Z-0.0181
Y1.3777
X0.0207 Y1.3985 Z-0.0378
X0.0254 Y1.4031 Z-0.0453
X0.0265 Y1.4043 Z-0.0477
X0.0277 Y1.4054 Z-0.048
X0.083 Y1.4607 Z-0.0243
X0.1245 Y1.5022 Z-0.0125
X0.1373 Y1.5151 Z-0.0108
X0.1659 Y1.5437 Z-0.0107
X0.1867 Y1.5644 Z-0.0138
X0.2074 Y1.5852 Z-0.0193
X0.2735 Y1.6512 Z-0.046
X0.2791 Y1.6568 Z-0.036
X0.2847 Y1.6625 Z-0.028
X0.3008 Y1.6785 Z-0.0124
X0.3111 Y1.6889 Z-0.0052
X0.3215 Y1.6992 Z-0.0022
X0.3319 Y1.7096 Z-0.0027
X0.3422 Y1.72 Z-0.0066
X0.3526 Y1.7304 Z-0.0129
X0.363 Y1.7407 Z-0.0222
X0.3734 Y1.7511 Z-0.0355
X0.3813 Y1.7591 Z-0.0478
X0.4356 Y1.8133 Z-0.0248
X0.4563 Y1.8341 Z-0.0183
X0.4978 Y1.8755 Z-0.0103
X0.5393 Y1.917 Z-0.0141
X0.5808 Y1.9585 Z-0.0267
X0.6223 Y2. Z-0.0448
Z-0.0432
X0.6364
X0.5966 Y1.9602 Z-0.0257
X0.5568 Y1.9205 Z-0.0117
X0.537 Y1.9006 Z-0.0074
X0.5171 Y1.8807 Z-0.0056
X0.4972 Y1.8608 Z-0.0063
X0.4773 Y1.8409 Z-0.0095
X0.4375 Y1.8011 Z-0.0221
X0.387 Y1.7506 Z-0.0436
X0.3679 Y1.7315 Z-0.0192
X0.358 Y1.7216 Z-0.0109
X0.3481 Y1.7117 Z-0.0043
X0.3382 Y1.7018 Z-0.0013
X0.3282 Y1.6918 Z-0.0014
X0.3182 Y1.6818 Z-0.0044
X0.3083 Y1.6719 Z-0.0111
X0.2784 Y1.642 Z-0.041
X0.2188 Y1.5824 Z-0.0164
X0.1989 Y1.5625 Z-0.0105
X0.179 Y1.5426 Z-0.0068
X0.1591 Y1.5227 Z-0.0055
X0.1392 Y1.5028 Z-0.0067
X0.1193 Y1.4829 Z-0.0104
X0.0795 Y1.4432 Z-0.0238
X0.0336 Y1.3972 Z-0.0438
X0.0323 Y1.3959 Z-0.0428
X0.0298 Y1.3934 Z-0.0387
X0.0199 Y1.3835 Z-0.0263
X0.0099 Y1.3735 Z-0.0166
X0. Y1.3636 Z-0.0111
Z-0.0055
Y1.3495
X0.0102 Y1.3596 Z-0.0101
X0.0203 Y1.3698 Z-0.0177
X0.0407 Y1.3901 Z-0.0401
X0.0813 Y1.4308 Z-0.0226
X0.122 Y1.4714 Z-0.0081
X0.1423 Y1.4918 Z-0.0037
X0.1626 Y1.5121 Z-0.002
X0.183 Y1.5324 Z-0.003
X0.2033 Y1.5528 Z-0.0062
X0.244 Y1.5934 Z-0.0194
X0.2878 Y1.6373 Z-0.0385
X0.2896 Y1.639 Z-0.0391
X0.2913 Y1.6408 Z-0.0377
X0.2948 Y1.6442 Z-0.0319
X0.3049 Y1.6544 Z-0.0202
X0.3151 Y1.6646 Z-0.0106
X0.3253 Y1.6747 Z-0.0037
X0.3343 Y1.6837 Z-0.0009
X0.3444 Y1.6938
X0.3552 Y1.7046 Z-0.0042
X0.3659 Y1.7154 Z-0.0108
X0.3761 Y1.7256 Z-0.0197
X0.3923 Y1.7417 Z-0.0407
X0.4472 Y1.7967 Z-0.0176
X0.4879 Y1.8374 Z-0.0054
X0.5082 Y1.8577 Z-0.0024
X0.5286 Y1.878 Z-0.0023
X0.5489 Y1.8984 Z-0.0046
X0.5692 Y1.9187 Z-0.0094
X0.6099 Y1.9593 Z-0.0246
X0.6505 Y2. Z-0.042
Z-0.0332
X0.6647
X0.6566 Y1.992 Z-0.0398
X0.5816 Y1.9169 Z-0.0095
X0.5608 Y1.8961 Z-0.004
X0.5401 Y1.8754 Z-0.0009
X0.5192 Y1.8546 Z-0.0005
X0.4985 Y1.8338 Z-0.0028
X0.4777 Y1.8131 Z-0.0075
X0.457 Y1.7923 Z-0.0145
X0.3998 Y1.7352 Z-0.0387
X0.3947 Y1.73 Z-0.0337
X0.3843 Y1.7196 Z-0.0204
X0.3739 Y1.7092 Z-0.0111
X0.3624 Y1.6977 Z-0.0044
X0.3509 Y1.6862 Z-0.0006
X0.3416 Y1.6769
X0.3323 Y1.6677 Z-0.0034
X0.322 Y1.6573 Z-0.0105
X0.3116 Y1.6469 Z-0.0204
X0.3012 Y1.6365 Z-0.0325
X0.2986 Y1.6339 Z-0.037
X0.296 Y1.6313 Z-0.0371
X0.2493 Y1.5846 Z-0.0168
X0.2077 Y1.543 Z-0.0039
X0.1869 Y1.5223 Z-0.0008
X0.1662 Y1.5015 Z-0.0005
X0.1454 Y1.4807 Z-0.0026
X0.1246 Y1.4599 Z-0.0076
X0.0831 Y1.4184 Z-0.0227
X0.0519 Y1.3872 Z-0.0366
X0.0442 Y1.3796 Z-0.0381
X0.0312 Y1.3665 Z-0.0209
X0.0208 Y1.3561 Z-0.0115
X0.0104 Y1.3457 Z-0.0049
X0. Y1.3353 Z-0.0011
Y1.3212 Z-0.0001
X0.01 Y1.3312 Z-0.0013
X0.02 Y1.3411 Z-0.0059
X0.0399 Y1.3611 Z-0.0228
X0.0504 Y1.3716 Z-0.0368
X0.053 Y1.3742 Z-0.0391
X0.1198 Y1.441 Z-0.0111
X0.1398 Y1.4609 Z-0.0053
X0.1597 Y1.4809 Z-0.0015
X0.18 Y1.5012 Z-0.0002
X0.1997 Y1.5208 Z-0.0015
X0.2396 Y1.5608 Z-0.0107
X0.3042 Y1.6253 Z-0.0375
X0.3053 Y1.6264 Z-0.0377
X0.3107 Y1.6319 Z-0.029
X0.3294 Y1.6506 Z-0.0102
X0.3394 Y1.6606 Z-0.0034
X0.3494 Y1.6706 Z-0.0005
X0.3594 Y1.6806 Z-0.0008
X0.3694 Y1.6905 Z-0.0043
X0.3793 Y1.7005 Z-0.01
X0.3893 Y1.7105 Z-0.0185
X0.4048 Y1.726 Z-0.038
X0.4193 Y1.7405 Z-0.0337
X0.4792 Y1.8003 Z-0.0093
X0.4991 Y1.8203 Z-0.004
X0.5191 Y1.8403 Z-0.0009
X0.5391 Y1.8603 Z-0.0003
X0.559 Y1.8802 Z-0.0023
X0.599 Y1.9201 Z-0.0129
X0.6585 Y1.9797 Z-0.038
X0.661 Y1.9822 Z-0.0387
X0.6687 Y1.9898 Z-0.0306
X0.6788 Y2. Z-0.022
Z-0.0155
X0.693
X0.6828 Y1.9898 Z-0.0207
X0.6726 Y1.9796 Z-0.0306
X0.668 Y1.975 Z-0.0373
X0.6656 Y1.9727 Z-0.0396
X0.6114 Y1.9185 Z-0.0162
X0.5911 Y1.8981 Z-0.0093
X0.5707 Y1.8777 Z-0.0045
X0.5513 Y1.8583 Z-0.0022
X0.5299 Y1.8369 Z-0.0021
X0.5095 Y1.8166 Z-0.005
X0.4892 Y1.7962 Z-0.0101
X0.4131 Y1.7201 Z-0.0402
X0.3974 Y1.7045 Z-0.0197
X0.3872 Y1.6943 Z-0.0109
X0.3771 Y1.6841 Z-0.0049
X0.3669 Y1.6739 Z-0.0012
X0.3567 Y1.6637 Z-0.0008
X0.3465 Y1.6535 Z-0.0037
X0.3363 Y1.6433 Z-0.0107
X0.3173 Y1.6244 Z-0.03
X0.3118 Y1.6189 Z-0.0389
X0.3107 Y1.6178 Z-0.0389
X0.2446 Y1.5516 Z-0.0115
X0.2242 Y1.5312 Z-0.0059
X0.2038 Y1.5108 Z-0.0027
X0.1848 Y1.4919 Z-0.0018
X0.1631 Y1.4701 Z-0.0035
X0.1223 Y1.4293 Z-0.0144
X0.061 Y1.368 Z-0.0403
X0.0595 Y1.3666
X0.0581 Y1.3651 Z-0.038
X0.0465 Y1.3536 Z-0.0226
X0.0306 Y1.3376 Z-0.0088
X0.0204 Y1.3274 Z-0.0027
X0.0092 Y1.3162 Z-0.0004
X0. Y1.307 Z-0.0016
Y1.2929
Z-0.0052
X0.0099 Y1.3028 Z-0.0017
X0.0197 Y1.3126 Z-0.0014
X0.0307 Y1.3236 Z-0.0049
X0.0416 Y1.3345 Z-0.0122
X0.052 Y1.3449 Z-0.0215
X0.0676 Y1.3605 Z-0.0427
X0.0728 Y1.3657 Z-0.0416
X0.1248 Y1.4177 Z-0.0194
X0.1664 Y1.4593 Z-0.0075
X0.188 Y1.4809 Z-0.0052
X0.208 Y1.5009 Z-0.0056
X0.2288 Y1.5217 Z-0.0086
X0.2496 Y1.5425 Z-0.0141
X0.3173 Y1.6102 Z-0.0421
X0.3233 Y1.6162 Z-0.0322
X0.3328 Y1.6256 Z-0.0214
X0.3432 Y1.636 Z-0.0115
X0.3536 Y1.6464 Z-0.0043
X0.364 Y1.6568 Z-0.0013
X0.3744 Y1.6672 Z-0.0016
X0.3847 Y1.6776 Z-0.0051
X0.3951 Y1.688 Z-0.0121
X0.4055 Y1.6984 Z-0.0214
X0.4212 Y1.7141 Z-0.0427
X0.4991 Y1.792 Z-0.0124
X0.5199 Y1.8128 Z-0.0075
X0.5407 Y1.8336 Z-0.0052
X0.5615 Y1.8544 Z-0.0057
X0.5823 Y1.8752 Z-0.0088
X0.6239 Y1.9168 Z-0.0219
X0.671 Y1.9639 Z-0.0424
X0.6759 Y1.9688 Z-0.0342
X0.6863 Y1.9792 Z-0.022
X0.6967 Y1.9896 Z-0.0147
X0.7071 Y2. Z-0.0103
Z-0.0062
X0.7212
X0.7112 Y1.99 Z-0.0096
X0.7012 Y1.98 Z-0.0155
X0.6912 Y1.9699 Z-0.0245
X0.6862 Y1.9649 Z-0.0301
X0.6773 Y1.9561 Z-0.0449
X0.6742 Y1.953 Z-0.0459
X0.6411 Y1.9199 Z-0.0314
X0.601 Y1.8798 Z-0.0167
X0.581 Y1.8598 Z-0.0123
X0.561 Y1.8397 Z-0.0101
X0.5409 Y1.8197 Z-0.0107
X0.5209 Y1.7997 Z-0.0136
X0.4808 Y1.7596 Z-0.0261
X0.4317 Y1.7104 Z-0.0474
X0.4298 Y1.7086 Z-0.0467
X0.428 Y1.7068 Z-0.0432
X0.4107 Y1.6895 Z-0.0206
X0.4007 Y1.6794 Z-0.012
X0.3906 Y1.6693 Z-0.0053
X0.3804 Y1.6592 Z-0.0022
X0.3705 Y1.6493 Z-0.0023
X0.3606 Y1.6394 Z-0.0053
X0.3506 Y1.6294 Z-0.0121
X0.3406 Y1.6193 Z-0.0215
X0.3206 Y1.5993 Z-0.0457
X0.2805 Y1.5592 Z-0.0284
X0.2404 Y1.5192 Z-0.0146
X0.2204 Y1.4991 Z-0.0111
X0.2003 Y1.4791 Z-0.01
X0.1803 Y1.4591 Z-0.0115
X0.1603 Y1.439 Z-0.0152
X0.1402 Y1.419 Z-0.0212
X0.0776 Y1.3564 Z-0.0476
X0.0751 Y1.3539 Z-0.0446
X0.0701 Y1.3489 Z-0.0367
X0.0601 Y1.3389 Z-0.0236
X0.0501 Y1.3288 Z-0.0143
X0.0401 Y1.3188 Z-0.0073
X0.0305 Y1.3093 Z-0.0032
X0.0209 Y1.2997 Z-0.0022
X0.0105 Y1.2892 Z-0.0046
X0. Y1.2788 Z-0.0102
Y1.2646
Z-0.0171
X0.0113 Y1.2759 Z-0.0089
X0.0225 Y1.2871 Z-0.0041
X0.0325 Y1.2971 Z-0.0034
X0.0409 Y1.3055 Z-0.0053
X0.0511 Y1.3157 Z-0.0111
X0.0613 Y1.3259 Z-0.0194
X0.0715 Y1.3361 Z-0.0303
X0.0817 Y1.3463 Z-0.0449
X0.0852 Y1.3498 Z-0.0521
X0.0919 Y1.3565 Z-0.0505
X0.1226 Y1.3872 Z-0.0373
X0.1634 Y1.428 Z-0.0224
X0.1838 Y1.4485 Z-0.0179
X0.2043 Y1.4689 Z-0.0161
X0.2247 Y1.4893 Z-0.0169
X0.2451 Y1.5097 Z-0.0202
X0.2656 Y1.5302 Z-0.0259
X0.3268 Y1.5914 Z-0.0512
X0.3371 Y1.6017 Z-0.0352
X0.3473 Y1.6119 Z-0.0232
X0.3575 Y1.6221 Z-0.0136
X0.3677 Y1.6323 Z-0.0066
X0.3778 Y1.6424 Z-0.0036
X0.3879 Y1.6525 Z-0.0034
X0.3982 Y1.6628 Z-0.0068
X0.4086 Y1.6732 Z-0.0138
X0.4188 Y1.6834 Z-0.0227
X0.429 Y1.6936 Z-0.0357
X0.4366 Y1.7012 Z-0.0474
X0.4384 Y1.7031 Z-0.0514
X0.4394 Y1.704 Z-0.0531
X0.4903 Y1.7549 Z-0.0314
X0.5311 Y1.7957 Z-0.0191
X0.5518 Y1.8164 Z-0.0164
X0.572 Y1.8366
X0.5924 Y1.857 Z-0.019
X0.6128 Y1.8774 Z-0.024
X0.6806 Y1.9453 Z-0.0515
X0.6826 Y1.9472 Z-0.0489
X0.6945 Y1.9591 Z-0.0298
X0.7047 Y1.9694 Z-0.0193
X0.715 Y1.9796 Z-0.0112
X0.7252 Y1.9898 Z-0.0064
X0.7354 Y2. Z-0.0045
X0.7495 Z-0.0054
X0.7391 Y1.9896 Z-0.005
X0.7287 Y1.9792 Z-0.0079
X0.7183 Y1.9688 Z-0.0149
X0.7004 Y1.9509 Z-0.033
X0.6854 Y1.9359 Z-0.0575
X0.6246 Y1.8751 Z-0.0324
X0.6038 Y1.8543 Z-0.0267
X0.583 Y1.8334 Z-0.0235
X0.5616 Y1.812 Z-0.023
X0.5413 Y1.7918 Z-0.0253
X0.5205 Y1.771 Z-0.0304
X0.458 Y1.7085 Z-0.0554
X0.4476 Y1.6981 Z-0.0582
X0.4424 Y1.6929 Z-0.0464
X0.4268 Y1.6773 Z-0.0251
X0.4164 Y1.6669 Z-0.0159
X0.4057 Y1.6562 Z-0.0085
X0.395 Y1.6454 Z-0.005
X0.3837 Y1.6341 Z-0.0051
X0.3748 Y1.6252 Z-0.008
X0.3644 Y1.6148 Z-0.0153
X0.3539 Y1.6044 Z-0.0252
X0.3435 Y1.594 Z-0.0374
X0.3331 Y1.5836 Z-0.0558
X0.3264 Y1.5769 Z-0.0554
X0.2707 Y1.5211 Z-0.0321
X0.2498 Y1.5003 Z-0.0265
X0.229 Y1.4795 Z-0.0233
X0.2082 Y1.4587 Z-0.023
X0.1874 Y1.4379 Z-0.0254
X0.1666 Y1.417 Z-0.0304
X0.1249 Y1.3754 Z-0.046
X0.0945 Y1.345 Z-0.0595
X0.0902 Y1.3407 Z-0.0493
X0.0833 Y1.3337 Z-0.0384
X0.0729 Y1.3233 Z-0.025
X0.0625 Y1.3129 Z-0.0156
X0.0521 Y1.3025 Z-0.0085
X0.0416 Y1.2921 Z-0.005
X0.0312 Y1.2817 Z-0.0051
X0.0208 Y1.2713 Z-0.0089
X0.0104 Y1.2609 Z-0.0159
X0. Y1.2505 Z-0.0254
Y1.2363
Z-0.0351
X0.01 Y1.2464 Z-0.0242
X0.0201 Y1.2564 Z-0.0156
X0.0301 Y1.2665 Z-0.0096
X0.0402 Y1.2765 Z-0.0066
X0.0502 Y1.2866 Z-0.0071
X0.0603 Y1.2966 Z-0.011
X0.0703 Y1.3067 Z-0.0181
X0.0804 Y1.3167 Z-0.0273
X0.0955 Y1.3318 Z-0.048
X0.1005 Y1.3368 Z-0.0589
X0.103 Y1.3393 Z-0.0656
X0.1043 Y1.3406 Z-0.0681
X0.1608 Y1.3971 Z-0.0443
X0.1809 Y1.4172 Z-0.038
X0.201 Y1.4373 Z-0.0339
X0.2213 Y1.4576 Z-0.0324
X0.2412 Y1.4775 Z-0.0336
X0.2613 Y1.4976 Z-0.0373
X0.2814 Y1.5177 Z-0.0431
X0.3316 Y1.5679 Z-0.0643
X0.3366 Y1.5729 Z-0.0659
X0.3416 Y1.578 Z-0.055
X0.3517 Y1.588 Z-0.0378
X0.3617 Y1.5981 Z-0.0263
X0.3718 Y1.6081 Z-0.0168
X0.3818 Y1.6182 Z-0.0098
X0.3919 Y1.6282 Z-0.0068
X0.4019 Y1.6383 Z-0.0067
X0.412 Y1.6483 Z-0.0099
X0.422 Y1.6584 Z-0.0166
X0.4321 Y1.6684 Z-0.0254
X0.4478 Y1.6841 Z-0.0455
X0.4534 Y1.6897 Z-0.0567
X0.4562 Y1.6925 Z-0.0646
X0.4576 Y1.6939 Z-0.0678
X0.5225 Y1.7588 Z-0.0415
X0.5426 Y1.7789 Z-0.0361
X0.5627 Y1.799 Z-0.033
X0.5824 Y1.8188 Z-0.0325
X0.6029 Y1.8392 Z-0.0346
X0.623 Y1.8593 Z-0.0392
X0.6431 Y1.8794 Z-0.0458
X0.6833 Y1.9196 Z-0.0632
X0.7235 Y1.9598 Z-0.0188
X0.7336 Y1.9699 Z-0.0108
X0.7437 Y1.98 Z-0.007
X0.7549 Y1.9912 Z-0.0066
X0.7637 Y2. Z-0.009
X0.7778
Z-0.0151
X0.7676 Y1.9897 Z-0.0099
X0.7573 Y1.9795 Z-0.0085
X0.7471 Y1.9693 Z-0.01
X0.7369 Y1.9591 Z-0.0153
X0.7164 Y1.9386 Z-0.0344
X0.7113 Y1.9335 Z-0.0415
X0.7011 Y1.9232 Z-0.0596
X0.6985 Y1.9207 Z-0.0656
X0.6952 Y1.9174 Z-0.0764
X0.6945 Y1.9167 Z-0.0761
X0.6903 Y1.9125 Z-0.0739
X0.6345 Y1.8567 Z-0.0515
X0.6038 Y1.826 Z-0.0442
X0.5831 Y1.8053 Z-0.0375
X0.5731 Y1.7953 Z-0.0383
X0.5627 Y1.7849 Z-0.0429
X0.5322 Y1.7544 Z-0.0514
X0.4698 Y1.692 Z-0.0769
X0.4665 Y1.6887 Z-0.0775
X0.4633 Y1.6855 Z-0.0665
X0.4568 Y1.679 Z-0.0512
X0.4401 Y1.6623 Z-0.0284
X0.4298 Y1.652 Z-0.0192
X0.4196 Y1.6418 Z-0.0123
X0.4094 Y1.6316 Z-0.0088
X0.3991 Y1.6213 Z-0.0089
X0.3889 Y1.6111 Z-0.0119
X0.3787 Y1.6009 Z-0.019
X0.3684 Y1.5906 Z-0.0286
X0.3582 Y1.5804 Z-0.041
X0.348 Y1.5702 Z-0.0588
X0.3412 Y1.5634 Z-0.0758
X0.2866 Y1.5087 Z-0.0533
X0.2456 Y1.4678 Z-0.0433
X0.2359 Y1.4581 Z-0.0391
X0.2263 Y1.4484 Z-0.0377
X0.2155 Y1.4377 Z-0.0399
X0.2047 Y1.4269 Z-0.0449
X0.1638 Y1.3859 Z-0.0566
X0.1228 Y1.345 Z-0.0743
X0.1126 Y1.3348 Z-0.077
X0.1075 Y1.3296 Z-0.0605
X0.1023 Y1.3245 Z-0.0494
X0.0921 Y1.3143 Z-0.0348
X0.0819 Y1.3041 Z-0.0243
X0.0716 Y1.2938 Z-0.0159
X0.0614 Y1.2836 Z-0.0103
X0.0502 Y1.2724 Z-0.0085
X0.0409 Y1.2631 Z-0.0102
X0.0307 Y1.2529 Z-0.0153
X0.0205 Y1.2427 Z-0.0232
X0.0102 Y1.2324 Z-0.0332
X0.0051 Y1.2273 Z-0.0397
X0. Y1.2222 Z-0.0488
Y1.208
Z-0.064
X0.0104 Y1.2185 Z-0.0451
X0.0156 Y1.2237 Z-0.0376
X0.0313 Y1.2393 Z-0.0226
X0.0417 Y1.2497 Z-0.0153
X0.0516 Y1.2596 Z-0.0114
X0.0615 Y1.2696 Z-0.0109
X0.0725 Y1.2805 Z-0.0143
X0.0834 Y1.2914 Z-0.0217
X0.0938 Y1.3018 Z-0.031
X0.1094 Y1.3175 Z-0.0519
X0.1146 Y1.3227 Z-0.0634
X0.1211 Y1.3292 Z-0.0841
X0.1224 Y1.3305 Z-0.0847
X0.1459 Y1.3539
X0.1864 Y1.3944 Z-0.0691
X0.1904 Y1.3984 Z-0.0652
X0.1944 Y1.4024 Z-0.0595
X0.2084 Y1.4165 Z-0.0456
X0.2193 Y1.4273 Z-0.0383
X0.2302 Y1.4382 Z-0.0349
X0.2401 Y1.4482 Z-0.0353
X0.2501 Y1.4581 Z-0.039
X0.2605 Y1.4686 Z-0.0458
X0.2804 Y1.4884 Z-0.0669
X0.3282 Y1.5363 Z-0.0847
X0.3465 Y1.5545
X0.3478 Y1.5558 Z-0.0842
X0.3491 Y1.5571 Z-0.0778
X0.3517 Y1.5597 Z-0.0691
X0.3543 Y1.5623 Z-0.063
X0.3647 Y1.5728 Z-0.0444
X0.3699 Y1.578 Z-0.037
X0.3856 Y1.5936 Z-0.0217
X0.396 Y1.604 Z-0.0141
X0.4064 Y1.6144 Z-0.011
X0.4168 Y1.6249 Z-0.0116
X0.4272 Y1.6353 Z-0.0157
X0.4377 Y1.6457 Z-0.0222
X0.4481 Y1.6561 Z-0.0317
X0.4585 Y1.6665 Z-0.0453
X0.4637 Y1.6718 Z-0.0535
X0.4689 Y1.677 Z-0.0652
X0.4741 Y1.6822 Z-0.0818
X0.4754 Y1.6835 Z-0.0847
X0.5002 Y1.7082
X0.5419 Y1.7499 Z-0.0668
X0.5523 Y1.7603 Z-0.0544
X0.5731 Y1.7812 Z-0.0378
X0.5835 Y1.7916 Z-0.0345
X0.594 Y1.802 Z-0.0349
X0.6044 Y1.8124 Z-0.0389
X0.6148 Y1.8229 Z-0.0461
X0.6358 Y1.8439 Z-0.0676
X0.6784 Y1.8865 Z-0.0842
X0.6993 Y1.9073 Z-0.0847
X0.7086 Y1.9166 Z-0.0612
X0.719 Y1.9271 Z-0.043
X0.7294 Y1.9375 Z-0.031
X0.7399 Y1.9479 Z-0.0216
X0.7503 Y1.9583 Z-0.0146
X0.76 Y1.9681 Z-0.0112
X0.7698 Y1.9778 Z-0.011
X0.7809 Y1.9889 Z-0.0149
X0.792 Y2. Z-0.0227
X0.8061
Z-0.0316
X0.796 Y1.9899 Z-0.023
X0.7859 Y1.9798 Z-0.0164
X0.7759 Y1.9698 Z-0.0135
X0.7658 Y1.9597 Z-0.0139
X0.7557 Y1.9496 Z-0.0172
X0.7456 Y1.9395 Z-0.0246
X0.7356 Y1.9295 Z-0.0343
X0.7255 Y1.9194 Z-0.0467
X0.7154 Y1.9093 Z-0.0645
X0.7129 Y1.9068 Z-0.0704
X0.7104 Y1.9043 Z-0.0783
X0.7091 Y1.903 Z-0.0838
X0.7079 Y1.9018 Z-0.0847
X0.655 Y1.8489
X0.6398 Y1.8337 Z-0.0622
X0.6247 Y1.8186 Z-0.0454
X0.6147 Y1.8086 Z-0.0379
X0.6046 Y1.7985 Z-0.0336
X0.5954 Y1.7893 Z-0.0319
X0.5844 Y1.7783 Z-0.0337
X0.5743 Y1.7682 Z-0.0391
X0.5643 Y1.7582 Z-0.047
X0.5492 Y1.7431 Z-0.0633
X0.5441 Y1.738 Z-0.0715
X0.5378 Y1.7317 Z-0.0847
X0.4811 Y1.675 Z-0.0845
X0.4736 Y1.6675 Z-0.0615
X0.4685 Y1.6624 Z-0.0518
X0.4534 Y1.6473 Z-0.0323
X0.4434 Y1.6373 Z-0.0237
X0.4331 Y1.627 Z-0.0168
G53 Z0
G53 Y0
M05
M09
M30
Shapeoko.zip
(5.37 KiB) Downloaded 291 times
Al DePoalo
866-408-3226 X147
BobCAD CAM, Inc.
Re: G-code format
Post by cvoinescu » Sat Sep 22, 2012 8:40 pm
If you really cared about ShapeOko beyond its forum as a vehicle for your advertising, and had read at least a little of the forum and/or the wiki, you'd know that people use a variety of controllers, from GRBL (on Arduino Uno) to various RepRap firmwares (usually on Arduino Mega) to Azteeg G1 to TinyG to LinuxCNC to Mach3. Each of them is well documented as to what subset of G-code it accepts. RTFM!
aldepoalo
Re: G-code format
Post by aldepoalo » Sat Sep 22, 2012 11:54 pm
I ve worked with mach3 and linux/emc before. The sample above programs will run on mach 3. The other ones I haven t heard of before. It would be really nice if I could write just onw post but it looks like I may need to write more than one....
Al DePoalo
866-408-3226 X147
BobCAD CAM, Inc.
aldepoalo
Re: G-code format
Post by aldepoalo » Sun Sep 23, 2012 12:17 am
Just spent some time on wiki and I do not see supported g codes listed. Maybe I just didn t look hard enough...
It does have a good 2d and 3d work flow with heekscam, but I didn t see anything about supported g code. There was a list of cad and cam packages and I guess I link for writing code by hand... maybe I am just lazy but having some members posting samples that are know to run makes it easier on me to create the post.
RTFM, if I had one I would read the x manull, well maybe.... I might just post a question in a forum to find my answers ;-)
Al DePoalo
866-408-3226 X147
BobCAD CAM, Inc.
Re: G-code format
Post by cvoinescu » Sun Sep 23, 2012 1:25 am
Well, as I said, there is no "ShapeOko controller". Many people use GRBL, which can be found on github. The FAQ lists the supported G-codes, right at the bottom. Some people use TinyG by synthetos, of which you can read more here, including G-code support. The best starting point for the various RepRap firmwares is reprap.org, for instance this page; that said, very few ShapeOko owners use those. LinuxCNC and Mach3 you said you were familiar with. Edward probably knows better, but if I had to guess, I would say GRBL was the most popular, followed by LinuxCNC.
gazorp
Re: G-code format
Post by gazorp » Sun Sep 23, 2012 3:02 am
My shapeoko uses grbl via arduino and the reactive substance stepper shield. In addition, I have created my own intermediate shield which i currently use for endstop switches and will eventually adapt for spindle control and monitoring. I have found that grbl is implemented with standard gcode definitions, no proprietary codes, and is very easy to modify and compile is so desired.
I anticipate as the community and diversity of our machines grow, grbl may begin to inflate in size and scope and require a more advance micro contoller such as the Arduino mega solutions.
I think a perfect example of "compatible" grbl gcode is the hello world file created by Ed with CamBam:
( Made using CamBam - http://www.cambam.co.uk )
( coaster 8/15/2012 12:48:26 PM )
( T0 : 0.125 )
G20 G90 G64 G40
G0 Z0.125
( T0 : 0.125 )
T0 M6
( Pocket1 )
G17
M3 S1000
G0 X2.5464 Y2.1839
G1 F8.0 Z-0.1
G3 F20.0 X2.495 Y2.2756 I-0.9907 J-0.4953
Writes "Shapeoko"
G2 X0.6982 Y1.6826 I1.0708 J0.6221
G3 Y1.6834 I-0.0625 J0.0005
G2 X0.8068 Y2.176 I1.1471 J0.0055
G3 X0.8071 Y2.1766 I-0.0566 J0.0265
G2 X1.1207 Y2.5643 I0.909 J-0.4148
G3 X1.146 Y2.6147 I-0.0372 J0.0502
( Engrave1 )
S1000
G0 Z0.125
G0 X3.3125 Y1.75
G1 F8.0 Z-0.05
G3 F20.0 X0.9688 Y3.1032 I-1.5625 J0.0
G3 X0.9687 Y0.3968 I0.7813 J-1.3532
G3 X3.3125 Y1.75 I0.7813 J1.3532
( Profile1 )
S1000
G0 Z0.125
G0 X3.5625
G1 F8.0 Z-0.1
G3 F20.0 X0.8438 Y3.3197 I-1.8125 J0.0
G3 X0.8437 Y0.1803 I0.9062 J-1.5697
G3 X3.5625 Y1.75 I0.9063 J1.5697
G1 F8.0 Z-0.2
G1 F8.0 Z-0.24
G0 Z0.125
M5
M30
aldepoalo
Re: G-code format
Post by aldepoalo » Mon Sep 24, 2012 8:46 pm
This code looks very straight forward, which is good news. Writing a post will be very easy. I do have a question about cutting 3D arcs.
XY Example:
(PROGRAM NAME: MILLBOBCAD4.NC)
(DATE: MON. 09/24/2012)
(TIME: 04:40PM)
G90 G80 G40 G20 G17
(FEATURE PROFILE)
(TOOL #1 0.5 ENDMILL ROUGH)
T1 M06
M00
S3880 M03
G00 X0.75 Y0.
G00 Z2.1
G17 G03 X-0.2318 Y0.7133 Z1.9688 I-0.75 J0.
G17 G03 X-0.6068 Y-0.4408 Z1.9375 I0.2318 J-0.7133
G17 G03 X0.75 Y0. I0.6068 J0.6845
G17 G03 X-0.2318 Y0.7133 Z1.875 I-0.75 J0.
G17 G03 X-0.6068 Y-0.4408 Z1.8125 I0.2318 J-0.7133
G17 G03 X-0.2318 Y0.7133 Z1.75 I-0.75 J0.
G17 G03 X-0.6068 Y-0.4408 Z1.6875 I0.2318 J-0.7133
G17 G03 X-0.2318 Y0.7133 Z1.625 I-0.75 J0.
G17 G03 X-0.6068 Y-0.4408 Z1.5625 I0.2318 J-0.7133
G17 G03 X-0.2318 Y0.7133 Z1.5313 I-0.75 J0. F89.2592
G17 G03 X-0.6068 Y-0.4408 Z1.5 I0.2318 J-0.7133
G00 Z2.1
M05
M30
Y Z Sample :
(TIME: 04:43PM)
G90 G80 G40 G20 G17
(TOOL #1 0.25 ENDMILL ROUGH)
T1 M06
M00
S7761 M03
G00 X-0.045 Y-0.117
G00 Z1.6
G01 Z1.5 F89.2592
G01 Y-0.1034 F178.5184
G19 G02 Y1.1032 Z1.5 J0.6033 K-0.1246
G01 Y1.117
G01 X0.055 Y1.125
G01 Y1.1119
G19 G03 Y-0.112 Z1.5 J-0.6119 K-0.1246
G01 Y-0.125
G01 X0.155
G01 Y-0.112
G19 G02 Y1.1119 Z1.5 J0.6119 K-0.1247
G01 Y1.125
G01 X0.255
G01 Y1.1119
G01 Y-0.125
G01 X0.355
G01 Y-0.112
G01 Y1.125
G01 X0.455
G01 Y1.1119
G01 Y-0.125
G01 X0.555
G01 Y-0.112
G01 Y1.125
G01 X0.655
G01 Y1.1119
G01 Y-0.125
G01 X0.755
G01 Y-0.112
G01 Y1.125
G01 X0.855
G01 Y1.1119
G01 Y-0.125
G01 X0.955
G01 Y-0.112
G01 Y1.125
G01 X1.055 Y1.1125
G01 Y1.0986
G19 G03 Y-0.0981 Z1.5051 J-0.5989 K-0.1245
G01 Y-0.099 Z1.5
G01 Y-0.1125
G00 Z2.1
M05
M30
Al DePoalo
866-408-3226 X147
BobCAD CAM, Inc.
aldepoalo
GRBL Beta Post for V24 Software
Post by aldepoalo » Mon Sep 24, 2012 9:00 pm
Attached is the post I created for the grbl . This post can be used with BobCAD CAM V24 software.
Grbl.zip
This is a post processor for the V24 BobCAD CAM software, Save this file in C:\BobCAD-CAM Data\BobCAD-CAM V24\Posts\Mill
(5.39 KiB) Downloaded 271 times
Al DePoalo
866-408-3226 X147
BobCAD CAM, Inc.
aldepoalo
Re: G-code format
Post by aldepoalo » Mon Nov 12, 2012 10:21 pm
It looks like we are getting some errors when using the above post:
photo uploader
From this error message I am not sure what G-code are causing the problem.
I am thinking I can loose the safety line and tool change and the program stop.
G90 G80 G40 G20 G17 Would be the safety line
T1 M06 Would be the tool change line
M00 Program Stop.
Al DePoalo
866-408-3226 X147
BobCAD CAM, Inc.
aldepoalo
Re: G-code format
Post by aldepoalo » Mon Nov 12, 2012 10:30 pm
Here is the new sample code, and I have also attached the updated post processor.
(PROGRAM NAME: SHAPEOKO NAME PLATE.NC)
(DATE: MON. 11/12/2012)
(TIME: 05:23PM)
(TOOL #1 0.125 ENDMILL ROUGH)
S5011 M03
G00 X0.2523 Y3.526
G00 Z0.1
G01 Z-0.1252 F40.0918
G01 X0.474 Y3.7477 F78.1789
G01 X0.5894 Y3.75 Z-0.1254
G01 X0.25 Y3.4106 Z-0.125
G01 Y3.2975
G01 X0.3734 Y3.4209 Z-0.1252
G01 X0.394 Y3.4414 Z-0.1306
G01 X0.4043 Y3.4517 Z-0.1366
G01 X0.4146 Y3.462 Z-0.1457
G01 X0.4197 Y3.4672 Z-0.1523
G01 X0.4248 Y3.4723 Z-0.1614
G01 X0.4274 Y3.4749 Z-0.168
G01 X0.4287 Y3.4762 Z-0.1724
G01 X0.43 Y3.4774 Z-0.1793
G01 X0.4306 Y3.4781 Z-0.3144
G01 X0.4326 Y3.48 Z-0.3172
G01 X0.4351 Y3.4826 Z-0.3231
G01 X0.4358 Y3.4832 Z-0.3254
G01 X0.4364 Y3.4839 Z-0.4035
G01 X0.4557 Y3.5032 Z-0.3935
G01 X0.5071 Y3.5546 Z-0.3761
G01 X0.5148 Y3.5623 Z-0.375
G01 X0.5161 Y3.5636 Z-0.3746
G01 X0.5168 Y3.5642 Z-0.297
G01 X0.5174 Y3.5649 Z-0.2946
G01 X0.52 Y3.5674 Z-0.2888
G01 X0.5219 Y3.5694 Z-0.286
G01 X0.5226 Y3.57 Z-0.1793
G01 X0.5238 Y3.5713 Z-0.1724
G01 X0.5251 Y3.5726 Z-0.168
G01 X0.5277 Y3.5752 Z-0.1614
G01 X0.5328 Y3.5803 Z-0.1523
G01 X0.538 Y3.5854 Z-0.1457
G01 X0.5483 Y3.5957 Z-0.1366
G01 X0.5586 Y3.606 Z-0.1306
G01 X0.5791 Y3.6266 Z-0.1252
G01 X0.7025 Y3.75 Z-0.1254
G01 X0.8157
G01 X0.6945 Y3.6288 Z-0.1251
G01 X0.6743 Y3.6086 Z-0.1295
G01 X0.6642 Y3.5985 Z-0.1347
G01 X0.6541 Y3.5884 Z-0.1427
G01 X0.644 Y3.5783 Z-0.1555
G01 X0.6389 Y3.5732 Z-0.1661
G01 X0.6364 Y3.5707 Z-0.1751
G01 X0.6358 Y3.5701 Z-0.1787
G01 X0.6351 Y3.5694 Z-0.3545
G01 X0.6339 Y3.5682 Z-0.3586
G01 X0.6326 Y3.5669 Z-0.3642
G01 X0.632 Y3.5663 Z-0.3688
G01 X0.6313 Y3.5656 Z-0.408
G01 X0.5935 Y3.5278 Z-0.3989
G01 X0.5809 Y3.5152 Z-0.3976
G01 X0.5732 Y3.5076 Z-0.3987
G01 X0.5328 Y3.4672 Z-0.4102
G01 X0.4924 Y3.4268 Z-0.4283
G01 X0.452 Y3.3863 Z-0.4427
G01 X0.4419 Y3.3762 Z-0.4476
G01 X0.4344 Y3.3687 Z-0.4501
G01 X0.4337 Y3.368 Z-0.3688
G01 X0.4331 Y3.3674 Z-0.3642
G01 X0.4318 Y3.3661 Z-0.3586
G01 X0.4306 Y3.3649 Z-0.3545
G01 X0.4299 Y3.3642 Z-0.1787
G01 X0.4293 Y3.3636 Z-0.1751
G01 X0.4268 Y3.3611 Z-0.1661
G01 X0.4217 Y3.356 Z-0.1555
G01 X0.4116 Y3.3459 Z-0.1427
G01 X0.4015 Y3.3358 Z-0.1347
G01 X0.3914 Y3.3257 Z-0.1295
G01 X0.3712 Y3.3055 Z-0.1251
M05
M30
Grbl_2.zip
(5.37 KiB) Downloaded 1027 times
Al DePoalo
866-408-3226 X147
BobCAD CAM, Inc.
