Instructions / Template for posting Project on the wiki
Posted: Fri Dec 13, 2013 5:15 pm
by WillAdams
Here:
- if you don't have an account, make one: http://www.shapeoko.com/wiki/index.php? ... =Main_Page
- upload any graphics you'll want to show off: http://www.shapeoko.com/wiki/index.php/Special:Upload (this is hidden away under the ``Toolbox'' link in the wiki sidebar) --- fill in all the information you want and provide a sensible filename and summary.
- Once you've got the file uploaded, you'll be at a page which will present you with all the information about the graphic --- make note of the filename (it will be needed below)
- go to the page where you'd like your information to be accessed from (in this case the Projects page): http://www.shapeoko.com/wiki/index.php/Projects
- Click on the ``Edit'' link for the section you want to update, Gallery in this instance
- Duplicate one of the lines you want to use, or re-type it or paste in the below w/in the <Gallery/> block:
Image:FILENAME.jpg|[[User:USERNAMEHERE|SHORTUSERNAMEHERE's]] - [[BRIEF PROJECT DESCRIPTION]].
Replace the filename, username and brief project description w/ yours.
- click the Preview link
- you should see your project in the gallery --- the link to your User page and a page for the project will be in red --- you can create a user page or no --- <ctrl>-click on the project's name in red to go to a new empty page where you can fill in information about your project
- create that page using something like this:
BRIEF DESCRIPTION.
[[File:FILENAMEHERE.jpg|x800px|DESCRIPTION HERE]]
MORE NOTES ON CONSTRUCTION.
[http://LINK.TO.YOUR.PROJECT.FILES/PATH/FILENAME DESCRIPTION]
- Save page, then close this tab
- Save your edit of the Gallery page
