0.8 kw spindle vendor
Postby blueshorts » Tue Apr 21, 2015 6:50 pm
So I'm going to get a water cooled spindle because air cooled spindles add too much noise to my machine. Does anyone have an opinion about where to buy a good 0.8 kW water cooled spindle?
I was thinking of laying down the money for a water cooled spindle setup from Ugra-CNC:
http://ugracnc.com/WATER-COOLED-SPINDLES/GMT-Water-Cooled-CNC-Spindle-0.75-kW-220V-R.html
http://ugracnc.com/CNC-SPINDLES/Delta-VFD-/-Inverter-0.75kW-110V.html
But after I buy the spindle, VFD, collets, and cooling pumps/setup from Ugra CNC I'm looking at ~$650-$750 without shipping added.
Then I see on ali express that I can get everything I need for $351.00 shipped:
http://www.aliexpress.com/store/product ... 22361.html
I generally live by the adage of you get what you pay for, so with only a small amount of education on spindle quality I'm leaning towards the Ugra CNC setup, but is there any reason I should go with a different brand of spindle (more or less expensive)?
Shapeoko 2 #3217 with an acme threaded rod and belt drive z axis, proxxon IBS\E spindle, NEMA23 motors on all axes, and a tiny g controller.
blueshorts
Re: 0.8 kw spindle vendor
Postby Hans » Tue Apr 21, 2015 7:23 pm
From what I've seen of people posting on this forum, random ebay spindles have runout that's worse than specified but still decent. Support is non-existent.
Ugra is the only hobby-level spindle retailer I've seen, but I think you're right to go for something the seller stands behind, especially if you are doing production work. If you're just having fun with the machine, I suppose you can't beat the China price and if it turns out that the collets are terrible you can replace them with something better as needed.
Shapeoko #1,123
Hans
Postby Jimf » Wed Apr 22, 2015 2:42 am
Another place you can get spindles other than ebay is
http://www.automationtechnologiesinc.com
Contact address says based in Illinois. The only thing I've ever ordered from them is stepper motors. The arrived quick and well packaged, no issues.
The 2.2kw spindle/vfd I have was purchased from ebay for about $350. Still working great since July 2013. Runout was within spec.
Jimf
Postby blueshorts » Wed Apr 22, 2015 2:42 am
Thanks for the input. I "feel" better about the Ugra cnc spindle, they guarantee the amount of runout (<0.02 mm or<0.001in) at least. It's a big investment, but I think it will pay off. I use my machine for a lot of different things- my PhD research, children's toys, household necessities, gifts, maybe someday a business. My wife recently deemed my shapeoko necessary for the house and suggested we make it larger, so I guess it's going to be around for a while.
blueshorts
Postby blueshorts » Wed Apr 22, 2015 2:46 am
Jimf
I hadn't seen the automation technologies website, If I see something I like I'll send them an email and see if they respond.
Can a shapeoko support a 2.2kw spindle well?
blueshorts
Postby Jimf » Wed Apr 22, 2015 2:56 am
blueshorts wrote:Jimf
For what it's worth, Automation tech has been around for awhile. I think I got some steppers atleast 5 years ago from them. I recently ordered some nema 17s last December. That's all I know about them. They do have good prices on steppers.
My 2.2kw spindle is on a much bigger gantry router in my basement. It would be too heavy for a Shapeoko.
Jimf
Postby Jimf » Wed Apr 22, 2015 3:12 am
Oh by the way I bought my er collets off ebay. I just found the cheapest seller. No problems and work just fine.
The water pump I got was one from surplus place electronic goldmine. $15 or so very high quality wash down pump made by flojet. You don't need high flow rate . I believe it was a 12-24volt pump but I run it off a 6volt phone charger. At 6 volts there was plenty of water flow to keep the spindle cool and the pump runs quieter.
Jimf
Postby WillAdams » Wed Apr 22, 2015 10:42 am
blueshorts wrote:Can a shapeoko support a 2.2kw spindle well?
Under Weight Concerns: http://www.shapeoko.com/wiki/index.php/ ... s#Concerns
Weight Moving to a larger spindle can require that one (re)adjust the machine as noted in Fine Tuning --- Motor Current. Two kilograms is, if not past the upper limit of weight, very close to it.[http://www.shapeoko.com/forum/viewtopic.php?f=5&t=3305&p=24845#p24845]
Postby blueshorts » Wed Apr 22, 2015 4:17 pm
That makes sense, I thought you had a Frankenstein of a shapeoko for a second.
I had never seen electronic goldmine before. The number of websites I haven't found amazes me because I do hours of searching for parts usually. Thanks for the heads up on those sources.
Thanks Will.
blueshorts
Postby Jimf » Wed Apr 22, 2015 4:55 pm
Ya electronic goldmine has been around forever, 20 years or more maybe. We probably order stuff from them once a month for all the different projects we do. You never know what cool stuff they have so I check their website weekly.
Another place I use is
http://www.mpja.com/mobile/
Jimf
Return to Mini Spindles - Purchased
Who is online
