Build log: 800W Chinese spindle for Shapeoko 3
Estlcam
Post by Estlcam » Wed Dec 09, 2015 9:51 am
Hi everyone,
the mailman just dropped a little parcel with a 0.8kW spindle and VFD for my new Shapeoko 3 :D
Parts:
  • Spindle mount
  • 1.5kW VFD
  • 0.8kW watercooled spindle with some ER11 collets in front
  • Line filter
I still need to buy a few parts like a small water pump for cooling but for now I'll just start assembling the things I already have.
So let's start with the spindle mount:
spindle_mount 1_xs.jpg (55.65 KiB) Viewed 5030 times
The one I got looks nice and very very sturdy but also a little heavy @ 725g / 1.6lbs...
I'll try to cut it down into 2 much smaller and lighter clamps with a hacksaw and then turn it flat on a lathe - wish me some luck... :?
Christian
Estlcam
Re: Build log: 800W Chinese spindle for Shapeoko 3
Post by Estlcam » Thu Dec 10, 2015 2:36 pm
half way through...
And done... no need to go to the gym today :D
Fortunately I have a lathe so finishing the surface was easy...
Estlcam
Post by Estlcam » Thu Dec 10, 2015 2:44 pm
Drilling and tapping the mounting holes:
The new set of clamps with much more reasonable 265g / 0.6lbs:
And finished:
Next will be wiring...
Christian
Atonwa
Post by Atonwa » Thu Dec 10, 2015 3:24 pm
Thanks for posting the build Christian. I literally had my finger on the button ready to buy one of these yesterday but hesitated. I'm interested to see how the wiring goes. Do you have a link to the one you bought?
I'm now out of the blue being plagued with disconnects after running for over a month with no issues. Thinking having a quiet spindle and getting rid of the disconnects from the router will be worth it.
Shapeoko 3 #109
Routakit HD Beta #001
Estlcam
Post by Estlcam » Thu Dec 10, 2015 5:02 pm
Hi,
Atonwa wrote: Do you have a link to the one you bought?
Mine is from a local German shop: http://www.rc-letmathe.de/
It is basically the same spindle / VFD set you can buy directly from China on eBay but with a better connector including a ground pin.
If you like to buy a spindle make sure it matches your countries line voltage - I'm from Germany so I have the 220V version but in the US you'll need the 110V version.
Atonwa wrote: I'm now out of the blue being plagued with disconnects after running for over a month with no issues.
Have a look at your grounding wires.
Make sure everything is grounded and try to achieve "star" grounding so all ground wires meet at a central grounding connection instead of "chaining" them from device A over to device B and so on...
Christian
Estlcam
Post by Estlcam » Fri Dec 11, 2015 9:14 pm
just wired the line filter, VFD and spindle...
All a bit makeshift at the moment but works very well so far :D
At the moment the spindle can be controlled from the VFDs control panel - next I'll try to hook it up to the carbide motion board so it can be controlled by the computer...
Christian
Estlcam
Post by Estlcam » Sat Dec 12, 2015 2:43 pm
Aaaahhh...
got the stepper motor wires tangled up and almost ripped one off...
So some cable management first:
Estlcam
Post by Estlcam » Sat Dec 12, 2015 2:48 pm
Also slipped some heat shrink tubing over the Y motor cables to protect them from the shrouds sharp edges:
And finally tied down the USB cable so it won't wobble around or even unplug when the gantry moves:
Christian
edwan
Cable Managment
Post by edwan » Sat Dec 12, 2015 5:07 pm
WOW! Well done. I have been thinking of cleaning up my wiring too. Is that split wire loom? Can you recommend a vendor?
Opps, I see you are in Germany, I will find a local source.
S3 #1105
Estlcam
Post by Estlcam » Sat Dec 12, 2015 5:35 pm
its cheap corrugated tube from the local hardware store - costs less than a dollar.
I've used the non-split version - I needed to remove the motor cable connectors anyways for the heat shrink tubing and they are easy to remove and reinstall.
(each contact has a small barb accessible by a small rectangular window - just press it down with a little screwdriver then pull the wire out)
