DC Spindle (RC Based)
CptanPanic
Re: DC Spindle (RC Based)
Post by CptanPanic » Thu Apr 26, 2012 12:58 pm
What about this motor: http://www.hobbyking.com/hobbyking/stor ... unner.html 36V, 2200W for $36. 6mm shaft. They also sell a rpm sensor, that I might be able to connect to linuxcnc, to do closed loop speed control.
CptanPanic
Post by CptanPanic » Thu Apr 26, 2012 1:09 pm
Actually thinking about this, the problem will be with the power supply. I will cost too much to provide that much power. So I think this idea will only work for small spindles.
calica
Post by calica » Fri Apr 27, 2012 2:13 am
Power supply issues are a problem. Luckily, I have a 12V (actually 13.6V) 40A supply from long ago. Maybe putting a marine deep cycle battery parallel will allow it to handle the surges.
This is quickly getting into the price range of: http://www.aliexpress.com/product-fm/52 ... alers.html
hansk1990
Post by hansk1990 » Thu Nov 01, 2012 2:17 am
How's everyone going with this idea? Anyone made any progress? I've been looking around, hobbyking seems a great place to grab some decent watercooled motors and a cheap esc to suit and you can pick up 12V 30A power supplies off ebay for about $30. So it seems like a cheap little idea for a quiet alternative to a dremel.......plus so much smaller! I'm tempted to grab some parts and just go for it but if i could I'd like to learn from other peoples mistakes and observations first :P
- Scott
Shapeoko #? - Cable drag chain management, modified Wolfgang engineering spindle including brushless water-cooled motor and PID speed control, Y axis dual drive, limit switches
galyion
Post by galyion » Tue Feb 19, 2013 9:21 am
My shapeoko is in the mail. I plan on building my own spindle. I am a machinist by trade and have an addiction to rc cars so I already have all the parts. I will keep everyone posted on the progress.
calica
Post by calica » Tue Feb 19, 2013 11:12 am
Looking forward to it.
antomost
Post by antomost » Wed Mar 27, 2013 7:29 pm
I am in progress of building one brushless spindle.
Here it is the first DYI parts.. will host an ER 11 collet and an approximately 300w brushless motor.
I hope to be more quiet than the dremel because I use it inside my apartment.
ThatOtherGuy435
Post by ThatOtherGuy435 » Wed Mar 27, 2013 7:53 pm
Please do document this - I have a DW660 at the moment, but eventually that will die and the more options for spindles the better!
T3PRanch
Post by T3PRanch » Tue Jun 25, 2013 3:30 am
Anyone needing a higher amperage very low cost 12V supply would do good to look at old server power supplies. I just picked up 2 on e-bay for about $22 delivered. 62A output (Dell #N750P-S0).
They do require building a simple jumper to energize the output and a switch to control fan speed (optional).
Thurmond
teddy92
Post by teddy92 » Fri Nov 01, 2013 5:59 pm
Has anyone any updates on DIY spindles? I want to replace my Proxxon LB/E because it hasn't got enough power.
My problem is that I don't know how big the motor should be for heavy wood milling. The Proxxon suffers a lot when do stepdowns above 0.5.
For example what is the difference between this two?
http://www.hobbyking.com/hobbyking/stor ... 2400W.html
http://www.hobbyking.com/hobbyking/stor ... Motor.html
The first is 35$ and the second 80$! I can't see any maior difference in the specs...
And does someone know something about how these motors perform over time?Are the good enough for a 5 our job?
A DIY spindle IMO would be a great improvement because you can replace single parts if the get broken.
