DC Spindle (RC Based)
daveczrn
Re: DC Spindle (RC Based)
Post by daveczrn » Sat Nov 02, 2013 11:54 am
the first motor is shorter in length and diameter. it also has a higher voltage rating. it uses that higher voltage to get the higher power rating. it will also run hotter than the second.
For long running jobs you would want a water cooled motor with some type of water supply to cool the motor. lower Kv would have more torque and less RPM. larger diameter can size will also have more torque. don't forget you need a plan to supply power to run the motor of your choice.
teddy92
Post by teddy92 » Sat Nov 02, 2013 5:51 pm
Thank you for your answer!
So maybe one of this two motors will be good:
http://www.hobbyking.com/hobbyking/stor ... Motor.html
http://www.hobbyking.com/hobbyking/stor ... oled_.html
For the RPM I will choose the right pulleys to get the right max speed.
As ESC I thought this one would be good (it's cheap and they say that it has good heat dissipation):
http://www.hobbyking.com/hobbyking/stor ... duct=18013
There are a lot of power supplies on Ebay and someone said something about server power supplies.
