Need Spindle Mount DREMEL
RedOko
Post by RedOko » Thu Apr 12, 2012 7:00 pm
I have a dremel 4000 and was looking if anybody have a plan for the mounting that they have tried or seen.
I found this one for a dremel 300
http://www.cocquerez.com/post/2011/08/3 ... Dremel-300
Luis
aka "RedOko"
Re: Need Spindle Mount DREMEL
Post by edwardrford » Thu Apr 12, 2012 7:04 pm
This one looks nice:
It's from bluumax: http://www.bluumaxcnc.com/index.html
RedOko
Post by RedOko » Thu Apr 12, 2012 8:28 pm
Yes, they are, but did you find the DXF file.
I did something similar with a 1/8 lexan for the bottom part but the bit looks a bit sideways.
Luis
aka "RedOko"
JCPhlux
Post by JCPhlux » Fri Apr 13, 2012 3:44 am
I have a 4000 and a Dremel 220-01 Rotary Tool Work Station http://www.amazon.com/Dremel-220-01-Rot ... B00068P48O
I called the Dremel support center and ordered an extra mount and am working to use it to mount to my shapeOko.
WP_000182 by JCPhlux, on Flickr
WP_000183 by JCPhlux, on Flickr
WP_000184 by JCPhlux, on Flickr
John R Cutburth II
Twitter @JohnCutburth
Sven83
Post by Sven83 » Fri Apr 13, 2012 7:41 am
Hi John,
is that thing stable enough for milling? I have a Dremel 300 over here and that Drill Station too, but it's a little wobbly.
Maybe I just disassemble it to harvest the part as soon as my ShapeOko is here.
ShapeOko No. 283 | TB6560 + LinuxCNC or Buildlog v3 Shield + GRBL
madmanmoe
Post by madmanmoe » Mon Apr 22, 2013 10:34 pm
I'm just wondering if anyone found, or has since drawn up files for a dremel 4000 mount. I'm about to start drawing one up and just wanted to check I wasn't doing it unnecessarily.
MadManMoe's Blog
Post by WillAdams » Mon Apr 22, 2013 11:47 pm
I've been using the stock mounts --- it's a tight fit, but seems to work --- that said, I have been thinking it'd be good to create a set of mount files --- esp. if we could write it up as a tutorial for the wiki.
madmanmoe
Post by madmanmoe » Sat Apr 27, 2013 10:59 pm
My stock mounts work great, although it's always a bit tricky to get the tool perfectly vertical.
Anyway they will never be as good as a set of custom mounts.
At the moment the mounts put pressure on the front and back of the tool, squeezing it far more than I would like.
Also, custom mounts would be able to hold the tool right down at the collar, which has got to be more stable.
I was considering adding a dust shoe as well, but I think my machine's too small to bother.
Anyway it sounds like no one's done any yet, so as soon as I find a new CAD program, that doesn't make me want to tear my haro out, I'll draw some up.
MadManMoe's Blog
