Cutting plexiglas with standard Dremmel
Elie
Re: Cutting plexiglas with standard Dremmel
Post by Elie » Tue Mar 03, 2015 2:09 pm
So, what is rpm value which 350-380 feed and 100 plunge for this material. My spindle as max 10 000 rpm.
HPGreyling
Post by HPGreyling » Tue Mar 03, 2015 6:42 pm
I' ve got no idea as rpm. On my manual speed controller , I set the speed between 25% and 50%. I have the quiet spindle so speed is according to notes around 12000. So 25% of that is around 3000.
Georgei
Post by Georgei » Tue Mar 03, 2015 7:00 pm
The notches in the speed in Dremels are not linear. The first notch is the minimum speed that the Dremel will work and not the Maximum speed / number of notches.
My Dremel has max speed 33000 rpm and 7 notches. The speed on the first notch is about 12000 rpm. However you cannot cut anything on first and second notch because the torque is non existence. So I guess you are cutting at about 18000 rpm.
Georgei
Post by Georgei » Fri Mar 13, 2015 4:47 pm
After a lot of unsuccessful attempts I have order Kyocera 3mm cutters from drillman on ebay.
First trial today and success. Very nice clean lines. What a difference a cutter makes
After I finished cutting my wife told me that when she order the "Plexiglas" they told her that they will sent acrylic!!!! So it is extruded acrylic and not Plexiglas. I wish I new before I will attempt cutting it.
Below are the settings:
Cutter: 3mm 2 flute carbide Kyocera cutter
Spindle speed: 13800RPM (the lower I can get from my router).
Pass depth: 0.5mm
Feed rate: 1200 mm/min
Plunge rate: 300 mm/min
Post by cvoinescu » Fri Mar 13, 2015 6:54 pm
But Plexiglass is acrylic.
Try polycarbonate. It costs twice as much, but it's nicer in every way.
Georgei
Post by Georgei » Sun Mar 15, 2015 9:22 am
cvoinescu wrote:But Plexiglass is acrylic.
I wanted to wright polycarbonate but I wrote plexiglass.
I agree that polycarbonate is much easier to cut.
