Another Laser Diode Engraving Thread
picengravertoo
Re: Another Laser Diode Engraving Thread
Post by picengravertoo » Sun Oct 25, 2015 9:08 pm
It took some digging through this old thread on another forum to find the reference of our settings. It was done with Mach3 and our analog modulated dual 445nm 9mm Nichia laser diode build with 5W of total output burning power. You will have to adjust your settings to compensate for the output difference of the J-Tech laser.
http://hobbycncart.com/forum/63-236-10
https://www.picengrave.com
mogwild
Post by mogwild » Sun Oct 25, 2015 9:52 pm
Getting there!
20151025_154517 - Copy.jpg (102.64 KiB) Viewed 3075 times
Shook
Post by Shook » Sun Nov 15, 2015 10:18 pm
I was looking into the j-Tech photonics laser kit as a potential add-on to the Shapeoko 3. [I haven't even got the machine and I'm already looking to add on to it!].
Engraving looks nice and I'm impressed with the quality of the photos here. I was hoping to be able to cut acrylic/plastics and thin wood with it for boxes, or to replace paper components in board games for example.
Does anyone know what I can realistically expect to be able to do with a 2W solid-state laser? Is this something that's only available once you get to the 40W CO2 models?
Shapeoko 3 (#1107)
picengravertoo
Post by picengravertoo » Sun Nov 15, 2015 11:02 pm
I recommend the 2.8W or 3.8W J-Tech laser kit over the 2W. There is some information of there capabilities on this page: http://jtechphotonics.com/?page_id=1177
picengravertoo
Post by picengravertoo » Tue Dec 22, 2015 9:52 pm
A new version of PicEngrave Pro 5 is now available for download. Unlimited user named Profile settings are now able to be Saved/Opened for different engraved materials, Pre/PostCodes and CNC machines has been added.
http://www.picengrave.com/PicEngraver%2 ... 0Laser.htm
picengravertoo
Post by picengravertoo » Thu Dec 24, 2015 12:41 pm
happy holidays.jpg (302.24 KiB) Viewed 2741 times
picengravertoo
Post by picengravertoo » Thu Dec 31, 2015 6:26 pm
picengravertoo
Post by picengravertoo » Wed Jan 06, 2016 10:42 pm
We needed a new 2016 Calendar for the office, so we decided to laser engrave one on 1/8" Birch Ply.
2016 Calendar.jpg (402.48 KiB) Viewed 2632 times
picengravertoo
Post by picengravertoo » Wed Feb 17, 2016 8:58 pm
We have been doing some extensive testing with a pre-released version of PicSender. This was engraved on Birch Ply with our 6W 450nm laser diode on our Shapeoko 2. A variable feedrate was set between 200 IPM (white) and 150 IPM (black) using our Feed Rate Change feature in PicEngrave Pro 5.
The laser's power range was set at a Min S15 and Max S255 and there were 1,507,509 total X,Y,S & F command lines in the gcode file. It was streamed to the J-Tech PWM 9g grbl firmware.
6W 200IPM.jpg (338.93 KiB) Viewed 2536 times
picengravertoo
Post by picengravertoo » Mon Feb 29, 2016 8:30 pm
Our new PicSender v2.3.0 is now available for download.
http://www.picengrave.com/PicSender.htm
Added Features:
• Pause/Resume for Spindle & Laser. PWM off/on control.
• Change Feed Rate During Gcode Streaming.
• Gcode Editor.
• Tool Position Setting Menu.
• 45 Degree X&Y Jog Buttons Added.
• Increased Streaming Performance.
Just finished this engraving with our 6W LD on Birch Ply. The feedrate was set at 180IPM with a 25% FRC. The size is 11" X 8.1" and it took a total time of 2:00:44 to stream the 1,826,605 lines of X,Y,S & F gcode commands to laser engrave the image. The J-Tech PWM grbl 9g firmware was used.
Ship 6W.jpg (367.99 KiB) Viewed 2475 times
