Another Laser Diode Engraving Thread
AnonymousPerson
Re: Another Laser Diode Engraving Thread
Post by AnonymousPerson » Thu Mar 24, 2016 9:58 am
Ahhh, cool, thanks. The 2nd one is more interesting.
Asking because someone mentioned in a video on lost PLA casting, than sugar burns out cleanly at high temperatures.
So, the idea of mixing extremely fine sugar with (say) aluminium or titanium powder, then seeing how well they bind together when lasered (sintering like).
The caramelization process seems like it would keep things bound together pretty well initially.
Then from there, putting the resulting object into a furnace for burning out the sugar, to complete the sintering process.
Might be time for to invest in a cheapo laser diode after all, and do some experimentation. :D
Shapeoko 3 #516
picengravertoo
Post by picengravertoo » Tue Apr 19, 2016 4:36 pm
200IPM, 30% Feed Rate Change, .007" Pixel Resolution, Min 20/Max 255 (full) laser power, 10"X10" engraved size and 2,053,505 lines of gcode streamed with PicSender. 2:14:00 total time to engrave on Birch Ply with our 6W LD
Original image that was resized, edited and cropped in PEP5.
https://upload.wikimedia.org/wikipedia/ ... lamour.jpg
https://www.picengrave.com
picengravertoo
Post by picengravertoo » Fri Jun 03, 2016 4:13 pm
Laser engraved on 8X10 .08 Brown/Gray Chipboard.
picengravertoo
Post by picengravertoo » Tue Jul 19, 2016 5:53 pm
Laser engraved on Brown/Gray Chipboard.
On Brown Chipboard.
Original image. https://upload.wikimedia.org/wikipedia/ ... e_shay.jpg
picengravertoo
Post by picengravertoo » Tue Aug 30, 2016 6:40 pm
This was done with Mach3 & J-Tech's PicConvert DAC for modulating a M140 2W 445nm laser diode on Poplar. The PicEngrave Pro 5 settings were A.000 Min & A-.0255 Max, 70IPM, 25% Feed Rate Change and .006 Pixel Resolution at a 45D angle using the Ellipse feature.
https://jtechphotonics.com/?product=dac ... rter-board
The size is 4.75" X 5.75" with 600,229 lines of gcode and it took 1:36:46 in time to engrave.
picengravertoo
Post by picengravertoo » Sat Oct 01, 2016 6:09 pm
New Multimode grbl 1.0c for Spindle & Laser use now available for download.
https://discuss.inventables.com/t/j-tec ... 1-0c/28493
picengravertoo
Post by picengravertoo » Tue Oct 18, 2016 8:54 pm
Laser engraved on 12"X12"X.125" piece of Birch Ply with our 6W Shapeoko 2 using Larry's MultiMode grbl 1.0c that can be downloaded from here..
https://discuss.inventables.com/t/xcarv ... -fix/28943
The 1,237,164 lines of gcode was generated with PicEngrave Pro 5 and streamed with PicSender. After the engraving was finished, I used the Manual Move menu in PicSender to cut it out with the laser.
picengravertoo
Post by picengravertoo » Thu Dec 15, 2016 6:19 pm
picengravertoo
Post by picengravertoo » Sun Mar 05, 2017 2:01 am
Mirror laser diode engraving.
picengravertoo
Post by picengravertoo » Thu Jun 15, 2017 7:03 pm
B&W TTL (pulse on/off) Laser engraving on Poplar.
TTL Map Engraving.jpg (587.07 KiB) Viewed 1077 times
