Need software recommendation for vector laser cutting
HoneyBadger
Post by HoneyBadger » Fri Mar 13, 2015 7:38 pm
Hey there, folks. I Need software that can be used for converting images into vectors for my laser cutter. I tried using the JTech Inkscape plug in but it's throwing Python errors that I'd rather not spend time debugging.
Can anyone recommend a good program for creating GRBL out of images? It doesn't need to be freeware - it just needs to work.
Thanks for your help!
Shapeoko 2, 1.7W 445nm Laser Diode (JTech)
PicSender
PicEngrave Pro 5
32° AASR
Re: Need software recommendation for vector laser cutting
Post by WillAdams » Fri Mar 13, 2015 7:45 pm
What I've found thus far is on the wiki:
http://www.shapeoko.com/wiki/index.php/ ... achines.29
Not familiar w/ the JTech Inkscape plug-in --- link?
Also, one of the recent laser projects has done software specific to laser use which they're selling commercially --- not tracking commercial software as well as I might, since I'm not going to use any.
HoneyBadger
Post by HoneyBadger » Fri Mar 13, 2015 8:07 pm
Thanks, Will! I'll check those out.
WillAdams wrote: Not familiar w/ the JTech Inkscape plug-in --- link?
http://jtechphotonics.com/?page_id=2012
The guys at JTech make a great product and provide excellent customer service. I know that they stop by here now and then, so here's the error code I'm getting, in case they want to see it:
Code: Select all
Traceback (most recent call last):
  File "laser.py", line 3173, in <module>
    e.affect()
  File "C:\Program Files (x86)\Inkscape\share\extensions\inkex.py", line 215, in affect
    self.effect()
  File "laser.py", line 3157, in effect
    self.orientation( self.layers[min(0,len(self.layers)-1)] )
  File "laser.py", line 3086, in orientation
    doc_height = self.unittouu(self.document.getroot().get('height'))
AttributeError: laser_gcode instance has no attribute 'unittouu'
It looks like it's unable to detect the size of the vector toolpath area.
PicSender
PicEngrave Pro 5
32° AASR
HoneyBadger
Post by HoneyBadger » Fri Mar 13, 2015 8:40 pm
FWIW, I followed the link for the "laser-code" project but there's nothing downloadable on the destination site:
https://code.google.com/p/laser-code/
Perhaps this is an abandoned project?
PicSender
PicEngrave Pro 5
32° AASR
Post by WillAdams » Fri Mar 13, 2015 9:18 pm
The SVN checkout command doesn't work?
I see code here: http://code.google.com/p/laser-code/sou ... 253Dclosed
cozmicray
Post by cozmicray » Fri Mar 13, 2015 9:31 pm
Check out Laser Imaging Editor
More of a raster engraver.
http://happycoders.com/release/laser/
With GRBL 8C laser or GRBL 9g laser
This will control pin 11 on arduino to PWM laser
It can use the spindle speed commands to control laser
M3 SXXX Laser ON S 0-255 for power adjust
M5 Laser OFF
Software still in development
Another solution
Connect up a micro switch to apply 12V to trigger Laser ON
when Z is commanded below the point the micro switch closes
You may use 12V from fan port on Laser driver to supply 12V to micro switch
Then use inkscape - makercam - UGS to burn with vectors
JTechPhotonics
Post by JTechPhotonics » Thu Mar 26, 2015 3:20 pm
HoneyBadger wrote:Thanks, Will! I'll check those out.
The new version of inkscape is throwing some errors now and then. Sorry you have found one... We have updated the software on the website for download here to fix many of these bugs: http://jtechphotonics.com/?page_id=1980
You can check to see if this fixes the problem. First, open laser.py to make the change.
on line 3086:
Code: Select all
It should be changed to this:
Code: Select all
  doc_height = self.unittouu(self.document.getroot().xpath('@height', namespaces=inkex.NSS)[0])
If this solves your problem then let me know and we can update the released version.
Jay
J Tech Photonics, Inc.
Laser Upgrade your Shapeoko: http://jtechphotonics.com/?page_id=1100
