Cheap Chinese Lasers (CCL)
Re: Cheap Chinese Lasers (CCL)
Post by WillAdams » Tue Dec 08, 2015 4:43 pm
Whether or no there's a standard vector format for pasting depends on the OS.
NeXT/OPENstep allowed Bezier curves in EPS format between apps, Mac OS had a de facto standard of AI-style Beziers, Mac OS X uses PDF, and Windows should pass WEMF, but that's a lousy format.
Agree that import is a better, more reliable option, esp. on Windows.
xfredericox
Post by xfredericox » Tue Dec 08, 2015 6:43 pm
i'll try it tomorrow
but this is the first time i ever had this issue copying a vector from one application to another. And mind you i have a graphic design background...
I guess it shows you're never too old to learn.
But hey,it is a crappy chinese plugin, i shouldn't be too surprised... :D
http://www.manmademayhem.com
Defy
Post by Defy » Thu Dec 10, 2015 3:15 am
What fans are folks using for exhaust? I was stupid and threw away the one that came with it because it looked shady. I bought a 6 inch inline one piped it all up and it doesn't move enough air kinda works but i want something more hard core. For testing and light engraving it was fine but cuts in wood too much smoke.
Defy
Post by Defy » Thu Dec 10, 2015 3:17 am
O didint post first real cut
AnonymousPerson
Post by AnonymousPerson » Thu Dec 10, 2015 8:30 am
Heh Heh Heh, that's cute. :)
Defy
Post by Defy » Sat Dec 12, 2015 1:59 am
Where is a good place for the 3mm baltic birch?
Jimf
Post by Jimf » Sat Dec 12, 2015 3:41 am
Defy wrote:Where is a good place for the 3mm baltic birch?
1/8" X 12" X 12" Baltic Birch Plywood Great for Laser, Cnc, and Scroll Saw. 45pc Woodpeckers® by Woodpeckers 1/8" X 12" X 12" Baltic Birch Plywood Great for Laser, Cnc, and Scroll Saw. 45pc Woodpeckers®
by Woodpeckers
Link: http://amzn.com/B013NT3OAC
I just received this yesterday.
45sq feet for $50 free shipping. This is the cheapest I could find via mail order. All the other places I looked at cost more when shipping is added.
Real Baltic birch comes in 5'x5' size. If your lucky, you can find it locally for under $20 a sheet. This will be cheaper per square foot. No one local to me stocks it so I would have to special order it with a minimum order so it wasn't worth the trouble.
Defy
Post by Defy » Sat Dec 12, 2015 5:10 am
Sweet! What settings do you use to cut 1/8 birch? I think i am going to make a dial gauge to on the power knob so i can start keeping track of my settings.
Jimf
Post by Jimf » Sat Dec 12, 2015 5:28 am
Defy wrote:Sweet! What settings do you use to cut 1/8 birch? I think i am going to make a dial gauge to on the power knob so i can start keeping track of my settings.
Funny you should ask!!! I made a video this morning cutting some of the ply. Darth Vader snowflake.
I used 8mm/sec at 10ma. Single pass with air on.
http://youtu.be/4ePNL-PLmdg
At 10mm/sec the parts didn't alway fall off cleanly so I reduced the speed to 8mm/sec. I could increase laser power but I figure I can best prolong the tube life by keeping it 10ma and under.
xfredericox
Post by xfredericox » Sat Dec 12, 2015 6:20 pm
did some modding today.
first was enlarging the workspace by trimming the air vent.
second more courageous bit was cutting a hole that allows larger stock to be cut.
It needs a hole in the case as well as in the alu X-rail profile. It was scary to do but in the end i don't think i compromised the integrity of the frame.
But needsto be done with care!
and last was replacing the ventilator by my own. It is about as powerful as the stockone, but is sealed and prettier at least. And i have a 20x larger vent lying around which i may eventually also use.
next up is adding the water and air circuits to the main power button, and making a custom pin bed instead of that spring-loaded atrocity. :twisted:
