Cheap Chinese Lasers (CCL)
Defy
Re: Cheap Chinese Lasers (CCL)
Post by Defy » Fri Feb 05, 2016 3:43 am
Anyone know how to get my laser to stop taking two passes per cut? For some reason it always takes two passes.
xfredericox
Post by xfredericox » Fri Feb 05, 2016 8:06 am
i had that too, it was somehow related to my imported vector path .
try drawing a shape within coreldraw and run the laser. If it does 1 pass, it must be a similar problem
http://www.manmademayhem.com
Defy
Post by Defy » Fri Feb 05, 2016 12:16 pm
Ya importing from vetrix vcarve so ill look at that.
Defy
Post by Defy » Sat Feb 06, 2016 9:51 pm
Ok tried just a circle and still did 2 passes. Any other ideas?
Also what is a good acrylic setting? I tried 20mm at 15amp and it took both passes to cut through. Sides are awesome though.
Jimf
Post by Jimf » Sat Feb 06, 2016 10:37 pm
Defy,
This is a long shot but in the the option menu where you can choose the engraving and cutting data type, choose wmf for both. I'm not in front of the computer so I forgot which one I used. I think it was wmf. Anyway when I chose one of the other data types, the laser started to cut two passes so I changed it back.
halfnormal
Post by halfnormal » Sun Feb 07, 2016 1:23 am
Defy wrote:what is a good acrylic setting?
I have been using 4mm/sec @ 10ma with air assist making one pass.
Defy
Post by Defy » Sun Feb 07, 2016 3:13 am
Thanks i'll try that. I have been cutting wood at 10mm and 15ma so i thought i could speed it up for acrylic. Is thay for 1/4 or 1/8?
xfredericox
Post by xfredericox » Sun Feb 07, 2016 8:44 am
does it show adialog box inbetween both passes, or does it just continue automatically with the second pass?
halfnormal
Post by halfnormal » Sun Feb 07, 2016 7:56 pm
Defy wrote: Is thay for 1/4 or 1/8?
3/16 or 6 mm
Defy
Post by Defy » Mon Feb 08, 2016 2:06 pm
xfredericox wrote:does it show adialog box inbetween both passes, or does it just continue automatically with the second pass?
It cuts like 3/4s then goes the other way 100% the finishes the last 1/4 if that makes any sense. I dont have time right now but later this week i'll get a video up.
My current settings anything i should check/uncheck?
