Is anyone using J-Tech's version of GRBL with their laser?
I got the 2.8w laser and driver package yesterday. I decided to upgrade my Arduino to J-Tech's GRBL release. Upon doing so I encountered terrible arcs and bad step offsets. After reflashing and having the same issues I jumped to the stock GRBL .9 latest release. My arcs are great now (I'm just trying to cut a rounded corner square), but I'm still getting occasional missed steps and I have yet to successfully cut through a 1/8" piece of birch plywood. Im also confused as to whether S18000 means full power or if it should be S255. Has anyone else experienced these sorts of issues?
Re: Is anyone using J-Tech's version of GRBL with their lase
I am using their version of grbl without any problems.
Their power setting for the laser are 1-255 with 255 being the highest.
Thanks for your reply. I guess I'll flash it again and see what happens. What sorts of materials have you cut with your laser?
Mostly thin stuff. Balsa wood for models, cardboard, plywood.
I use it mostly for laser engraving, if thats the correct word, on wood and acrylic mostly
The J-Tech GRBL is optimized for raster engraving. In order to optimize it, it had to remove the math portion for Arcs.
If you use PicSender for Gcode sending, it allows you to save your GRBL settings and you can reflash the Arduino with any GRBL for the project your are doing.
Some people will use one setup for both CNC and laser, others use two separate setups.
Bottom line, laser GRBL is optimize for raster engraving, standard is for CNC and cutting.
That explains it! Thank you!halfnormal wrote:The J-Tech GRBL is optimized for raster engraving. In order to optimize it, it had to remove the math portion for Arcs.
One more question... Do you know anything about Pic Laser 3D? I'd like to do some 3D relief engravings, but I'm not sure if that's the only software I need. I signed up for their forum, but my account still hasn't been activated.halfnormal wrote:The J-Tech GRBL is optimized for raster engraving. In order to optimize it, it had to remove the math portion for Arcs.
PicLaser 3D is for combining 3D spindle relief gcode & Laser power gcode for shading the spindle relief's contours. This is so the laser's focal point follows the contours with Z axis command moves so the Laser does not go out of focus.etxbkst wrote: One more question... Do you know anything about Pic Laser 3D? I'd like to do some 3D relief engravings, but I'm not sure if that's the only software I need. I signed up for their forum, but my account still hasn't been activated.
I responded to your email yesterday concerning which software generates gcode for 3D Laser Diode engraving.
https://www.picengrave.com
Thanks for your reply! And I apparently missed your email when it came in. Sorry about that.picengravertoo wrote:PicLaser 3D is for combining 3D spindle relief gcode & Laser power gcode for shading the spindle relief's contours. This is so the laser's focal point follows the contours with Z axis command moves so the Laser does not go out of focus.etxbkst wrote: One more question... Do you know anything about Pic Laser 3D? I'd like to do some 3D relief engravings, but I'm not sure if that's the only software I need. I signed up for their forum, but my account still hasn't been activated.
