Beagleboneblack and EMC
hippalator
Post by hippalator » Tue Feb 04, 2014 6:09 pm
Anybody using this board as an embedded system?
It looks promising.
I'm not a techie when it comes to linux at all, but the ability to embed the system into the machine is something I'm looking into.
LTMNO
Re: Beagleboneblack and EMC
Post by LTMNO » Wed Feb 05, 2014 1:08 am
Hello hippalator. I have purchase my beaglebone black, the CNC cape, the 4x stepper drivers, the Bluetooth keyboard and mouse, the bridge to extend the cape so hdmi cable fits and a led screen. All just waiting for the time to install. Sorry the delayed response. But I will get there. Happy to fill you in when it's done. Should be straight forward from a few articled I read.
LTMNO
Post by LTMNO » Wed Feb 12, 2014 3:28 pm
Okay, just a quick update... I have got everything configured on the BBB side, meaning that it is all up and running, LinuxCNC is running, Drivers are all set. I just received a package today for the QuickConnect for Power as I did not receive any from CircuitCo. I had to solder 370uF Cap on J18 and 100uF Caps on VMOT/GND on the DRV8825 Drivers. I am almost ready to plug it in, I just need to configure LinuxCNC for ShapeOko instead of the default 3dPrinter Setup.
http://forum.bebopr.info/viewtopic.php? ... rt=10#p490
http://forum.bebopr.info/download/file.php?id=14
http://forum.bebopr.info/download/file.php?id=15
Re: BeBoPr++ Group Order
Post by edwardrford » Sun Mar 02, 2014 4:01 pm
Just as an fyi to everyone: I bypassed ordering the cape and simply wired my grblshield to the BBB via breadboard jumper wires.
It works pretty well. Here are a few pictures of my test rig.
The attachment bbb3.jpg is no longer available
sent from my phone, using tapatalk (then edited in browser to adjust images...)
dataway
Post by dataway » Sun Mar 02, 2014 5:30 pm
Edward what screen are you using in that setup, is that a touch screen interface?
Post by edwardrford » Sun Mar 02, 2014 7:59 pm
That is actually not a touch screen. It's just a plain 7" screen with that I bought off ebay for about $60. In the latest iteration of that project, I upgraded to a 10" screen (touch) and have been working on a custom LinuxCNC 'screen'.
I feel like I've de-railed this topic, so I'm going to move my previous post (and this one) over to this thread: http://www.shapeoko.com/forum/viewtopic ... 580#p19511
unterhausen
Post by unterhausen » Wed Mar 19, 2014 4:49 am
good source of information is Charles Steinkuehler's page http://blog.machinekit.io/
somewhere on there he has a list of all the capes for cnc, there are quite a few
wingrunr21
Post by wingrunr21 » Tue Apr 08, 2014 4:00 am
If anyone is interested in using a BeBoPr++ with the Beaglebone I've got two left:
http://www.shapeoko.com/forum/viewtopic.php?f=12&t=2696
ThatOtherGuy435
Post by ThatOtherGuy435 » Thu May 08, 2014 1:32 pm
I've just had a run of some PCBs based on the Rosetta Bone design from Buildlog (http://www.buildlog.net/blog/2013/09/cn ... eaglebone/). Once I finish testing it (and assuming I didn't mess up the Eagle design), I'll have a few spare boards. So far, all the axis seem to work with a RAMPS 1.4 board, but I still need to check the Buildlog shield (and by proxy, GrblShield) and endstops.
I made a few minor changes - a jumper to join the Y and A axis on RAMPS (or an Uno shield), a 2 pin header for a power switch. I ditched the motor enable jumpers, but kept the 3.3v/5v logic selector.
I put a parallel port on the end of it, but I don't have any parallel port controllers, so I won't be able to test that. Once it tests out I'll toss the LCNC config (based on BeBoPr-Bridge shipped with MachineKit) and the eagle files up somewhere to share.
mauri
Post by mauri » Mon Jun 02, 2014 11:03 am
[quote="edwardrford"]Just as an fyi to everyone: I bypassed ordering the cape and simply wired my grblshield to the BBB via breadboard jumper wires.
Hi Edward
can you describe how do you wirded the BBB with the GShield?
And the configuration you habe done on the LinuxCNC?
thanks
mauri
