Stepper driver options for LinuxCNC
Discussion of linuxCNC (formerly knows as EMC2)
magno32
Re: Stepper driver options for LinuxCNC
Post by magno32 » Thu Jun 13, 2013 1:19 am
Rhynier,
I purchased the same Wantai kit that you seem to have. I really like it (nice packaged drivers) minus the lack of documentation and support. I seem to be having heat issues with my motors/drivers as during a longer running job, the motors and drivers are very hot to the touch and the different depth passes begin to shift.
What power settings are you using with your drivers, and have you had any issues like this?
Enraged
Post by Enraged » Sun Sep 29, 2013 6:02 pm
Not exactly a stepper driver, but this may be a new option since it's getting harder to find computers with parallel ports: Using a Beaglebone Black as an embedded controller.
Bart has a good writeup of the board and his adapter: http://www.buildlog.net/blog/2013/09/cn ... eaglebone/
I ordered a Beaglebone from http://www.adafruit.com/products/703 and a parallel port breakout from http://www.ebay.ca/itm/DB25-Parallel-Po ... 183&_uhb=1 to do a breadboard setup. I'm going to try getting my Shapeoko running with it, connected to one of the eBay TB6560 boards. Total cost will be under $200 for everything if it works out.
I was also reading about connecting a tablet with USB to control the beaglebone through ssh. I have a Google Nexus 7.
calica
Post by calica » Thu Oct 03, 2013 9:37 am
Be sure to post how it works. It looks to have a lot of promise. Much more so than the RaspPI. Has a lot more IO too. Its pretty easy to run up against the limits of the parallel port.
Why do you need USB on the tablet?
Enraged
Post by Enraged » Thu Oct 03, 2013 5:28 pm
From what I read, you can control the Beaglebone over USB or a network connection via ssh. I was planning to use USB to make it a standalone system, no wifi required.
calica
Post by calica » Fri Oct 04, 2013 6:59 am
Ok. But if you use WiFi, its wireless. :)
Check out: http://www.youtube.com/watch?v=WVj8JvKpqW0
Its using HippoRemote on iOS to create a custom keyboard that connects to the LinuxCNC machine via VNC. There should be a similar app for Android. Its a pretty neat setup.
Enraged
Post by Enraged » Fri Oct 04, 2013 10:36 pm
That is awesome. I have a wifi dongle from my raspberry pi, might give that a shot.
