help with settings on shapeoko 2
CNC_Mike
Post by CNC_Mike » Fri Apr 11, 2014 2:32 am
I'm sure this topic has been addressed already but after two days I've seen my machine shake I need help with the settings for the tiny G and shapeoko 2 I have set it up according to the wiki but so far just shaking and crashingthe help you guys could give me would be appreciated thank you for your time helping me
Mike
selektha
Re: help with settings on shapeoko 2
Post by selektha » Fri Apr 11, 2014 7:10 am
It would be easier if you posted your TinyG conf here($$ via a terminal window) and the specifications of your stepper motors etc.
PsyKo
Post by PsyKo » Fri Apr 11, 2014 8:55 am
What do you mean shaking and crashing ?
Does it only happen when running GCode file ?
Simple motions like G0 X100 works ?
Are your motor properly wired ? make sure there is no loose wire (it can cause the motor to vibrate and not move when trying to move)
Are your speed and feed settings correct ?
I'm using TinyG, and it works like a charm.
Shapeoko #736
CNC_Mike
Post by CNC_Mike » Fri Apr 11, 2014 3:56 pm
my settings are
[fb] firmware build 412.01
[fv] firmware version 0.97
[hp] hardware platform 1.00
[hv] hardware version 8.00
[id] TinyG ID 2X2660-GPY
[ja] junction acceleration 2000000 mm
[ct] chordal tolerance 0.001 mm
[sl] soft limit enable 0
[st] switch type 0 [0=NO,1=NC]
[mt] motor idle timeout 2.00 Sec
[ej] enable json mode 0 [0=text,1=JSON]
[jv] json verbosity 3 [0=silent,1=footer,2=messages,3=configs,4=linenum,5=verbose]
[js] json serialize style 1 [0=relaxed,1=strict]
[tv] text verbosity 0 [0=silent,1=verbose]
[qv] queue report verbosity 0 [0=off,1=single,2=triple]
[sv] status report verbosity 1 [0=off,1=filtered,2=verbose]
[si] status interval 100 ms
[ec] expand LF to CRLF on TX 0 [0=off,1=on]
[ee] enable echo 0 [0=off,1=on]
[ex] enable flow control 2 [0=off,1=XON/XOFF, 2=RTS/CTS]
[baud] USB baud rate 5 [1=9600,2=19200,3=38400,4=57600,5=115200,6=230400]
[net] network mode 0 [0=master]
[gpl] default gcode plane 0 [0=G17,1=G18,2=G19]
[gun] default gcode units mode 1 [0=G20,1=G21]
[gco] default gcode coord system 1 [1-6 (G54-G59)]
[gpa] default gcode path control 2 [0=G61,1=G61.1,2=G64]
[gdi] default gcode distance mode 0 [0=G90,1=G91]
[1ma] m1 map to axis 0 [0=X,1=Y,2=Z...]
[1sa] m1 step angle 1.800 deg
[1tr] m1 travel per revolution 36.5400 mm
[1mi] m1 microsteps 8 [1,2,4,8]
[1po] m1 polarity 0 [0=normal,1=reverse]
[1pm] m1 power management 0 [0=remain powered,1=power down when idle]
[1mp] m1 motor power level 1.000 [0.000=minimum, 1.000=maximum]
[2ma] m2 map to axis 1 [0=X,1=Y,2=Z...]
[2sa] m2 step angle 1.800 deg
[2tr] m2 travel per revolution 36.5400 mm
[2mi] m2 microsteps 8 [1,2,4,8]
[2po] m2 polarity 0 [0=normal,1=reverse]
[2pm] m2 power management 0 [0=remain powered,1=power down when idle]
[2mp] m2 motor power level 1.000 [0.000=minimum, 1.000=maximum]
[3ma] m3 map to axis 2 [0=X,1=Y,2=Z...]
[3sa] m3 step angle 1.800 deg
[3tr] m3 travel per revolution 1.2500 mm
[3mi] m3 microsteps 4 [1,2,4,8]
[3po] m3 polarity 1 [0=normal,1=reverse]
[3pm] m3 power management 0 [0=remain powered,1=power down when idle]
[3mp] m3 motor power level 1.000 [0.000=minimum, 1.000=maximum]
[4ma] m4 map to axis 3 [0=X,1=Y,2=Z...]
[4sa] m4 step angle 1.800 deg
[4tr] m4 travel per revolution 360.0000 mm
[4mi] m4 microsteps 8 [1,2,4,8]
[4po] m4 polarity 0 [0=normal,1=reverse]
[4pm] m4 power management 0 [0=remain powered,1=power down when idle]
[4mp] m4 motor power level 1.000 [0.000=minimum, 1.000=maximum]
[xam] x axis mode 1 [standard]
[xvm] x velocity maximum 16000.000 mm/min
[xfr] x feedrate maximum 16000.000 mm/min
[xtn] x travel minimum 0.000 mm
[xtm] x travel maximum 300.000 mm
[xjm] x jerk maximum 5000 mm/min^3 * 1 million
[xjh] x jerk homing 10000 mm/min^3 * 1 million
[xjd] x junction deviation 0.0100 mm (larger is faster)
[xsn] x switch min 0 [0=off,1=homing,2=limit,3=limit+homing]
[xsx] x switch max 0 [0=off,1=homing,2=limit,3=limit+homing]
[xsv] x search velocity 500.000 mm/min
[xlv] x latch velocity 100.000 mm/min
[xlb] x latch backoff 20.000 mm
[xzb] x zero backoff 5.000 mm
[yam] y axis mode 1 [standard]
[yvm] y velocity maximum 16000.000 mm/min
[yfr] y feedrate maximum 16000.000 mm/min
[ytn] y travel minimum 0.000 mm
[ytm] y travel maximum 300.000 mm
[yjm] y jerk maximum 5 mm/min^3 * 1 million
[yjh] y jerk homing 10000 mm/min^3 * 1 million
[yjd] y junction deviation 0.0100 mm (larger is faster)
[ysn] y switch min 3 [0=off,1=homing,2=limit,3=limit+homing]
[ysx] y switch max 2 [0=off,1=homing,2=limit,3=limit+homing]
[ysv] y search velocity 500.000 mm/min
[ylv] y latch velocity 100.000 mm/min
[ylb] y latch backoff 20.000 mm
[yzb] y zero backoff 3.000 mm
[zam] z axis mode 1 [standard]
[zvm] z velocity maximum 800.000 mm/min
[zfr] z feedrate maximum 800.000 mm/min
[ztn] z travel minimum 0.000 mm
[ztm] z travel maximum 3.000 mm
[zjm] z jerk maximum 20 mm/min^3 * 1 million
[zjh] z jerk homing 20 mm/min^3 * 1 million
[zjd] z junction deviation 0.0100 mm (larger is faster)
[zsn] z switch min 0 [0=off,1=homing,2=limit,3=limit+homing]
[zsx] z switch max 3 [0=off,1=homing,2=limit,3=limit+homing]
[zsv] z search velocity 200.000 mm/min
[zlv] z latch velocity 100.000 mm/min
[zlb] z latch backoff 20.000 mm
[zzb] z zero backoff 1.000 mm
[aam] a axis mode 1 [standard]
[avm] a velocity maximum 172800.000 deg/min
[afr] a feedrate maximum 172800.000 deg/min
[atn] a travel minimum -1.000 deg
[atm] a travel maximum -1.000 deg
[ajm] a jerk maximum 5760 deg/min^3 * 1 million
[ajh] a jerk homing 5760 deg/min^3 * 1 million
[ajd] a junction deviation 0.0500 deg (larger is faster)
[ara] a radius value 0.1989 deg
[asn] a switch min 1 [0=off,1=homing,2=limit,3=limit+homing]
[asx] a switch max 0 [0=off,1=homing,2=limit,3=limit+homing]
[asv] a search velocity 600.000 deg/min
[alv] a latch velocity 100.000 deg/min
[alb] a latch backoff 5.000 deg
[azb] a zero backoff 2.000 deg
[bam] b axis mode 0 [disabled]
[bvm] b velocity maximum 3600.000 deg/min
[bfr] b feedrate maximum 3600.000 deg/min
[btn] b travel minimum -1.000 deg
[btm] b travel maximum -1.000 deg
[bjm] b jerk maximum 20 deg/min^3 * 1 million
[bjd] b junction deviation 0.0500 deg (larger is faster)
[bra] b radius value 1.0000 deg
[cam] c axis mode 0 [disabled]
[cvm] c velocity maximum 3600.000 deg/min
[cfr] c feedrate maximum 3600.000 deg/min
[ctn] c travel minimum -1.000 deg
[ctm] c travel maximum -1.000 deg
[cjm] c jerk maximum 20 deg/min^3 * 1 million
[cjd] c junction deviation 0.0500 deg (larger is faster)
[cra] c radius value 1.0000 deg
[p1frq] pwm frequency 100.000 Hz
[p1csl] pwm cw speed lo 1000.000 RPM
[p1csh] pwm cw speed hi 2000.000 RPM
[p1cpl] pwm cw phase lo 0.125 [0..1]
[p1cph] pwm cw phase hi 0.200 [0..1]
[p1wsl] pwm ccw speed lo 1000.000 RPM
[p1wsh] pwm ccw speed hi 2000.000 RPM
[p1wpl] pwm ccw phase lo 0.125 [0..1]
[p1wph] pwm ccw phase hi 0.200 [0..1]
[p1pof] pwm phase off 0.100 [0..1]
[g54x] g54 x offset 0.000 mm
[g54y] g54 y offset 0.000 mm
[g54z] g54 z offset 0.000 mm
[g54a] g54 a offset 0.000 deg
[g54b] g54 b offset 0.000 deg
[g54c] g54 c offset 0.000 deg
[g55x] g55 x offset 75.000 mm
[g55y] g55 y offset 75.000 mm
[g55z] g55 z offset 0.000 mm
[g55a] g55 a offset 0.000 deg
[g55b] g55 b offset 0.000 deg
[g55c] g55 c offset 0.000 deg
[g56x] g56 x offset 0.000 mm
[g56y] g56 y offset 0.000 mm
[g56z] g56 z offset 0.000 mm
[g56a] g56 a offset 0.000 deg
[g56b] g56 b offset 0.000 deg
[g56c] g56 c offset 0.000 deg
[g57x] g57 x offset 0.000 mm
[g57y] g57 y offset 0.000 mm
[g57z] g57 z offset 0.000 mm
[g57a] g57 a offset 0.000 deg
[g57b] g57 b offset 0.000 deg
[g57c] g57 c offset 0.000 deg
[g58x] g58 x offset 0.000 mm
[g58y] g58 y offset 0.000 mm
[g58z] g58 z offset 0.000 mm
[g58a] g58 a offset 0.000 deg
[g58b] g58 b offset 0.000 deg
[g58c] g58 c offset 0.000 deg
[g59x] g59 x offset 0.000 mm
[g59y] g59 y offset 0.000 mm
[g59z] g59 z offset 0.000 mm
[g59a] g59 a offset 0.000 deg
[g59b] g59 b offset 0.000 deg
[g59c] g59 c offset 0.000 deg
[g92x] g92 x offset 0.000 mm
[g92y] g92 y offset 0.000 mm
[g92z] g92 z offset 0.000 mm
[g92a] g92 a offset 0.000 deg
[g92b] g92 b offset 0.000 deg
[g92c] g92 c offset 0.000 deg
[g28x] g28 x position 0.000 mm
[g28y] g28 y position 0.000 mm
[g28z] g28 z position 0.000 mm
[g28a] g28 a position 0.000 deg
[g28b] g28 b position 0.000 deg
[g28c] g28 c position 0.000 deg
[g30x] g30 x position 0.000 mm
[g30y] g30 y position 0.000 mm
[g30z] g30 z position 0.000 mm
[g30a] g30 a position 0.000 deg
[g30b] g30 b position 0.000 deg
[g30c] g30 c position 0.000 deg
motor information is
Nema 17 60 oz/in
Smart Automation PN: SM42HT47-1684B
I'm going to rewire the first chance I get just make sure
thanks
mike
aldenhart
Post by aldenhart » Sun Apr 13, 2014 2:37 pm
Here is a page that should get you started.
https://github.com/synthetos/TinyG/wiki ... eoko-Setup
I just updated this. Let me know if you have any questions or spot anything that should be changed.
