tinyG Vectric Aspire Post Processor
Hello All,
I am thinking of making the move from GRBL to tinyG as my GRBL shield has been giving me issues. I wanted to see if anyone is using tinyG with tool paths generated from Vectric Aspire as this is the software I use for my workflow.
Thanks for any input...
John
John
Re: tinyG Vectric Aspire Post Processor
I have located the post processors for tinyG that function under Vectric Aspire so all is good in the world and looking forward to making to jump from GRBL to tinyG....
Hi John,
Just to let you know that I made the move from GRBL to TinyG quite few months ago now and I've not looked back. I saw your post on the TinyG forum, so I know you have some custom posts (which also support tool changers) already, but I've actually just been using the standard GCode mm post provided with Aspire and this works pretty well straight out of the box too.
I'd be interested to hear how you get on.
Cheers
Edward
Cheers
Edward
Hi Edward,
Thanks for the update I will give them both a try. The tinyG should be here on Tuesday, I am hoping for an easy transition as I have quite a few CNC jobs backed up at the moment, but it has given me the time to put together a dust collection system
I will update this post with my adventure ....
I will be using Vectric as well, where did you find the right post processors to use with TinyG?
I only have the ones to use with my Shark CNC machine.
@briankb - I have actually been using the post processor that comes with Vectric Aspire and is the Standard GCode mm Post processor and it has been working very well but I did make a minor modification to introduce the M3 and M5 S8000 commands to control my spindle start, stop and speak, at the beginning and ending of the post processor. I do have the tiny post processors also if you need them send me an PM and I can get them over to you.
Regards,
John
Regards,
John
What's the difference between the "arc" and "no_arc" file? I'm about to upgrade to tinyG and I was going to just use my Shapeoko PP in Aspire. Will that not work?
At a guess the no_arc file approximates curves w/ lots of little straight lines.
See this: http://mae.engr.ucdavis.edu/~farouki/ijmtm99a.pdf for a discussion of why that's bad.
