CAMBAM and TinyG turing arcs into straight lines
psppb
Post by psppb » Fri Jan 23, 2015 3:10 am
Greetings.
It appears more problems are falling through the cracks. I designed a part on CAMBAM and ran it on my SO2. I looked at it with OpenSCAM and saw that it cut all the arcs as per CAMBAM commanded, I looked at the G code and there are in fact arcs inside the code (I, J commands). I then ran it on my machine. Two things happened. It moved the Zero 4 inches left (-X) so I had somehow -4,0 for my origin. THis did not show up on openSCAM and second of all the even more weird part was that it cut nothing but straight lines where it should have been cutting Arcs. VERY WEIRD. Has anyone Seen this? I am attaching three files. The first is the NC code CAMBAM created. The second is the $$ settings dump from the tinyG. PLease tell me there is something wrong with my settings. I am stumped on this one
I have no idea what is causing this? the code looked fine.
Please help!
Bill
tinyg_settins_Jan_22_15.txt
(9.21 KiB) Downloaded 88 times
Crate_two_nest_2.nc
(13.88 KiB) Downloaded 78 times
Bill
22" x 32" Shapeoko NEMA 23, ACME screw upgrade, DW660 Spindle with TinyG controller
AlBorland
Re: CAMBAM and TinyG turing arcs into straight lines
Post by AlBorland » Fri Jan 23, 2015 4:18 pm
Hi,
the chordal tolerance $ct is set to a very high value on your tinyg, pretty sure that is the cause of your second problem. Normal value is 0.01mm, see also https://github.com/synthetos/TinyG/wiki ... -tolerance
The 4 inch offset could have been a WCS offset, but there are no offsets stored in the configuration, nor is there a G55 or something in the gcode. Might want to retest that, and if you have the offset again, look closer on which coordinate system is in effect (G54..G59 and/or G92). Which gcode sender are you using?
psppb
Post by psppb » Sat Jan 24, 2015 12:00 am
I am using TGFX. Thanks for the advice!
The coordinate system is G54 I believe.
Bill
Bill
psppb
Post by psppb » Sat Jan 24, 2015 1:17 am
Correction I'm using G90
Code: Select all
( Made using CamBam - http://www.cambam.co.uk )
( Crate_two 1/22/2015 8:24:42 PM )
( T3 : 0.125 )
G20 G90 G64 G40
G0 Z0.125
( T3 : 0.125 )
T3 M6
( Profile1 )
G17
M3 S1000
G0 X5.4692 Y1.8607
Bill
mristau
Post by mristau » Sun Feb 08, 2015 9:50 pm
Reply deleted. I see now that it was not appropriate in this thread. (Oops)
Build in progress: 1100x1100mm workarea using salvaged 45x45mm extrusions with Openrail, tinyG/435.10/v.0.97, NEMA 23s, belt drive XY, Acme Z, 400W PWM Spindle, lasercut 1/2" acrylic motor/wheel mount plates.
mristau
Post by mristau » Mon Feb 09, 2015 5:31 am
Post by WillAdams » Mon Feb 09, 2015 11:31 am
List of G-codes w/ notes on what's supported or no: http://www.shapeoko.com/wiki/index.php/G-Code
cmcgrath5035
Post by cmcgrath5035 » Mon Feb 09, 2015 12:08 pm
The most current tinyG fw is 438.02, but installing that might compromise your use of tgFX.
Unclear if the issues fixed by 438.02 are relavent here.
You should plan too migrate away from tgFX, future tinyG builds will not be well supported by tgFX and there is not further development planned for tgFX
Why bother generating Gcode to 4 decimal places?
Makes for very large Gcode files, minimum actionable distances for SO2 are likely in the 0.02mm range.
Two decimal palces should be adequate.
I don't use CAMBAM, but understand from others that this precision is settable somewhere?
ShapeOko (V1) SN 1462
Post by cvoinescu » Mon Feb 09, 2015 12:27 pm
cmcgrath5035 wrote:Why bother generating Gcode to 4 decimal places?
You need at least four decimals in inch mode and three in millimeter mode, regardless of the actual accuracy or resolution of the machine, because the "standard" (such as it is) says the arc endpoint for G2 and G3 should be on the circle determined by the current position and the center (I, J, and/or K) to within 0.0002" or 0.002 mm.
cmcgrath5035
Post by cmcgrath5035 » Mon Feb 09, 2015 12:48 pm
Code: Select all
Thanks, did not know that. I generally ony read the standard when something does not work.
Gcode generators that I use (with success) generally are two digits in mm mode.
I'll have to assume tinyG does some sort of best effort.
