USB Com Port Hickup?
mristau
Post by mristau » Sun Mar 08, 2015 7:31 pm
What do I need to adjust?
When sending a .txt setup file to TinyG via CoolTerm, I often get an "unrecognized" error for one or two of the commands. Re-sending the same file a time or two, no errors are reported. Or, no errors are reported and a query of all settings shows that a setting remains the default value (change was not made). Or, sending a short text file like:
(1)
$ja=2000000
$xjm=5000
$xjd=0.01
$xvm=16000
$xfr=16000
$yjm=5000
$yjd=0.01
$yvm=16000
$yfr=16000
reports on only two of the commands sent:
(1)
tinyg [mm] ok>
tinyg [mm] ok>
$ja=2000000
[ja] junction acceleration 2000000 mm <<<<<<<<<
tinyg [mm] ok>
tinyg [mm] ok>
tinyg [mm] ok>
tinyg [mm] ok>
$xjm=5000 <<<<<<<<<<
[xjm] x jerk maximum 5000 mm/min^3 * 1 million
tinyg [mm] ok>
Build in progress: 1100x1100mm workarea using salvaged 45x45mm extrusions with Openrail, tinyG/435.10/v.0.97, NEMA 23s, belt drive XY, Acme Z, 400W PWM Spindle, lasercut 1/2" acrylic motor/wheel mount plates.
cmcgrath5035
Re: USB Com Port Hickup?
Post by cmcgrath5035 » Mon Mar 09, 2015 11:47 am
The answer to your issue is likely forund in this paragraph in the wiki: https://github.com/synthetos/TinyG/wiki ... n-commands
Writes to the tinyG persistent memory (EEPROM) require a finite period of time during which the input I/O is ignored.
If you send a long string of sequential writes such as this, many of the commands will be lost or corrupted.
To be successful, you need to code up an application that will read your file of commands and send them one at a time, waiting for a response from tinyG before sending the next command.
If you are curious how this is done, you can fork the configuretinyg widget in Chilipeppr for a javascript example.
Other folks have created solutions, perhaps they will share.
It is not a trivial task for a non-programmer.
PS
If your footer is correct and you are still running fe 435.10, I suggest a fw update. FW 440.14 is available
ShapeOko (V1) SN 1462
jlauer
Post by jlauer » Mon Mar 09, 2015 5:31 pm
I think this is an easy one. Just wait 40ms after each command that would write to EEPROM. If you send quicker than that you get the error you're talking about.
When you see it work after sending it a few times, what you're seeing is that it doesn't have to write to EEPROM so it skips it thus it doesn't need the 40ms wait.
mristau
Post by mristau » Tue Mar 10, 2015 12:04 am
Thanks for pointers guys.
Use to do some coding but it's all beyond me now.
So, there are no communication settings or commands to add that will slow the sending. I guess "status interval" is just TinyG reporting back to control computer? Where to change to 40ms? I can cut and paste them... I've not used chillipeppr. Is there some Windows utility that will allow such control?
cmcgrath5035
Post by cmcgrath5035 » Tue Mar 10, 2015 10:52 am
Settings that would help? None that I am aware of in Coolterm.
I think what John is suggesting is a Script that would
Code: Select all
Provision the Serial Interface
Read in a line (while not EOF)  //Top of loop
Send line to serial interface
Wait X ms  //Give EEPROM write time to complete
Loop // back to read line in
You might be able to have the script interact with CoolTerm, I have never tried.
Since Speed should not be of huge importance, I would suggest a Wait of 100ms is safer.
I have seen command write response times vairy between 15ms and 80ms when running a list of parameter writes
Status interval?
I assume you mean the tinyG parameter $si ?
When a job (Gcode) is running, tinyG will stream back to the sender (e.g. CoolTerm) machine status reports every $si ms, position+velocity information.
mristau
Post by mristau » Fri Mar 13, 2015 4:17 am
This page on Flow Control and Footers was informative.
https://github.com/synthetos/TinyG/wiki ... nd-Footers
mristau
Post by mristau » Fri Mar 13, 2015 5:37 am
The solution to this problem is right in front of me face!
CoolTerm already has the control needed:
Connection> Options...> Transmit> Use transmit line delay
jlauer
Post by jlauer » Fri Mar 13, 2015 10:17 am
Or send from chilipeppr via a macro with coding a delay using settimeout().
cmcgrath5035
Post by cmcgrath5035 » Sat Mar 14, 2015 3:10 am
Interesting find in CoolTerm, let us know if it works for you.
mristau
Post by mristau » Sat Mar 14, 2015 3:12 am
Works great!
