What config settings do I change to calibrate xyz?
cmcgrath5035
Re: What config settings do I change to calibrate xyz?
Post by cmcgrath5035 » Wed Jan 27, 2016 11:36 am
Parameters look good.
If after check of wiring problems with X motor continue, try connecting X motor to motor2 driver and Y motor to motor 1 driver and changed parameters accordingly.
f the problemems stay with motor driver 1, you might have a defective tinyG. If problems follow the X motor(when connected to motor driver 2), then stepper or wiring are in question.
ShapeOko (V1) SN 1462
jininjin
Post by jininjin » Wed Jan 27, 2016 1:55 pm
Thanks again. I check these shortly. I do have a spare tinyg g.
Forgot to mention I use Chilipeppr
Shapeoko 2
X,Y,Z Nema 23's 140 in-oz, ACME Z Axis, Quiet Cut Spindle 400w
ChiliPeppr, TinyG V8
jininjin
Post by jininjin » Tue Feb 02, 2016 3:05 am
cmcgrath5035 wrote:Parameters look good.
A quick update. I swapped the motors via config file and wiring. The Y motor works fine as before using other driver but the X motor still behaves odd.. The X now moves in one direction only and jerks in the other direction without moving.
Is there any reason for this or should I replace my stepper motor?
I was thinking it could be that the x motor is hitting false limits in GCode. So it thinks it cannot go in one direction since it triggers a limit. I currently do not have limit switches so that is not set up in the config file. Is that possible or should I just pickup a new motor?
Edit: Changed wording in last sentence.
Shapeoko 2
cmcgrath5035
Post by cmcgrath5035 » Tue Feb 02, 2016 4:07 am
You should run tests with limits disabled just to be sure.
Perhaps run without belts to see if motors will free rotate first.
Sounds to me like a stepper motor issue
jininjin
Post by jininjin » Tue Feb 02, 2016 4:56 am
Thanks for all your help! You are probably right the problem follows the motor. I switched it back and it doesn't do anything except make noise. I will replace and try again soon.
Shapeoko 2
