PCB Milling - Illumination disk and Limit Switch boards
Anool
Post by Anool » Sat Jun 08, 2013 1:20 pm
I finished my ShapeOko build a while back. I'm using a 300W 48V DC spindle with ER11 collet, bought off eBay (http://www.ebay.com/itm/ws/eBayISAPI.dl ... AQ:US:1123)
I made a couple of boards, and have learnt a lot from the process.
The boards were designed in KiCad. The Gerber code was converted to G-Code using LineGrinder. For engraving, I used these 10 deg engraving bits from eBay (http://www.ebay.in/itm/ws/eBayISAPI.dll ... 4215wt_902)
Illumination disk
Assembled Unit
12 LED's, run from the same power supply as the spindle, at 48V DC. A 500 ohm series resistor limits LED current to 15mA.
Mounted to the Spindle using double sided tape.
Bright enough
The collet throws a bit of a shadow, so I will have to lower the board.
I'll probably insert some spacer disks between the PCB and Spindle, or make some other kind of extension.
If anyone wants the design files - KiCad / Gerber Code - let me know. I'm now working on installing limit switches.
Anool J M : Mumbai, India
team Wyolum (wyolum.com)
Tom Smith
Re: PCB Milling - Illumination disk and Limit Switch boards
Post by Tom Smith » Sat Jun 08, 2013 2:53 pm
Anool wrote: If anyone wants the design files - KiCad / Gerber Code - let me know. I'm now working on installing limit switches.
Nice work, i like this idea, I'd be interested in the design files. One thing you could try to get rid of the shadow is to make a diffuser disk out of plexiglass; scuff one side with sandpaper and the shadows will be lessened somewhat.
Tom
_______________
ShapeOko1 191
Anool
Post by Anool » Sat Jun 08, 2013 3:05 pm
Nice idea for the diffuser. Will test it out next week.
About the files, I'll post a link on Monday. They're all located on my work PC.
bjbsquared
Post by bjbsquared » Sat Jun 08, 2013 6:37 pm
I like the shadows.
Post by WillAdams » Sat Jun 08, 2013 6:39 pm
Scintillating!
(I added Line Grinder to the wiki)
Post by twforeman » Sun Jun 09, 2013 1:59 am
Neat. The shadows remind me of theBulbDial clock. (I have one.)
Anool
Post by Anool » Mon Jun 10, 2013 10:05 am
The design files for the Illuminator board are at this link :
https://www.dropbox.com/sh/9l1yc2f1ttydh4a/bXUF2YmGjJ
Illuminator
It's a KiCad project, with the new file formats (you may need to upgrade KiCad if you have the old version)
The Illum_Gerb sub-folder has the Gerber files for front Cu layer, and Excellon drill file.
I didn't make the edge cuts file, since LineGrinder can only handle square/rectangle edge cuts.
I allowed KiCad to include the Edges on the copper layer. LineGrinder then made a nice isolation cut , which I used to cut the board to size with a shear.
Post by cvoinescu » Mon Jun 10, 2013 1:10 pm
That looks neat, but why the caps? Surely the LEDs don't mind a noisy power supply. Not installing the caps has another, frivolous advantage: it lets you use PWM to power the board, if you feel inclined to vary the brightness at some point in the future.
Anool
Post by Anool » Mon Jun 10, 2013 2:13 pm
The Illuminator is in parallel with the spindle, so I just wanted to be safe. Spindle is 300W, driven from a 450W Meanwell SMPS. Even so, the LED's go Off for an instant when the spindle is turned on. At the moment, there's just a 100nF.
PWM - maybe at a later date. Right now, I'm just keen to get the ShapeOko up and running.
calica
Post by calica » Mon Aug 12, 2013 7:24 pm
How is the board attached to the spindle? Are you happy with the eBay spindle?
