Enable microstepping
On the PCB-Gcode forum someone recommended I turn on microstepping to reduce low speed vibration. I don't know anything about microstepping. How to I enable it? What config settings do I need to change? I've got a shapeoko 2 with GRBL v0.8c.
Shapeoko v2 with DW660
GRBL v0.9i
GRBL v0.9i
Re: Enable microstepping
If you don't know, you probably have microstepping enabled.
The stepping would be whatever Shapeoko 2 ships with. Here's my config file:cvoinescu wrote:If you don't know, you probably have microstepping enabled.
$0=40.020 (x, step/mm)
$1=40.200 (y, step/mm)
$2=320.000 (z, step/mm)
$3=30 (step pulse, usec)
$4=500.000 (default feed, mm/min)
$5=500.000 (default seek, mm/min)
$6=252 (step port invert mask, int:11111100)
$7=255 (step idle delay, msec)
$8=25.000 (acceleration, mm/sec^2)
$9=0.050 (junction deviation, mm)
$10=0.100 (arc, mm/segment)
$11=25 (n-arc correction, int)
$12=3 (n-decimals, int)
$13=0 (report inches, bool)
$14=1 (auto start, bool)
$15=0 (invert step enable, bool)
$16=0 (hard limits, bool)
$17=1 (homing cycle, bool)
$18=96 (homing dir invert mask, int:01100000)
$19=25.000 (homing feed, mm/min)
$20=250.000 (homing seek, mm/min)
$21=100 (homing debounce, msec)
$22=1.000 (homing pull-off, mm)
GRBL v0.9i
GRBL v0.9i
You have 8x microstepping on the X and Y axes, and 2x microstepping on the Z axis.
Thankscvoinescu wrote:You have 8x microstepping on the X and Y axes, and 2x microstepping on the Z axis.
GRBL v0.9i
GRBL v0.9i
