PCB Auto-Leveller for ShapeOko / TinyG
scott216
Re: PCB Auto-Leveller for ShapeOko / TinyG
Post by scott216 » Sun Oct 19, 2014 9:13 pm
Dan211 wrote:Hello, I am new to CNC machining and i have bought a Shapoko 2, my plan is to soon etch pcbs using it. I am trying to figure out how to use this autoleveler with a GRBL controlled machine and I am having problems. So when I try to do a test probe using the chilipeppr.com/grbl autoleveller my machine moves and when I connect a wire from pin 11 (z limit) to ground grbl just locks up and says "ALARM: Hard/Soft Limit [Reset to continue]". I have to manually send $X to it for it to reset, the data is also not collected and the probing is not continued after I reset. Am I doing something wrong or is the problem somewhere else? Thanks for your help in advance.
Pin D11 is the wrong pin for probing, you should be using pin A5.
See: https://github.com/grbl/grbl/wiki/Connecting-Grbl
Shapeoko 2 with DW660
grbl v0.9g
PCB Toolchain: Cadsoft Eagle > pcb-gcode > Chilipeppr or GRBL Panel
Other Toolchain: Fusion 360 > Chilipeppr or GRBL Panel
My Build Log
Dan211
Post by Dan211 » Sun Oct 19, 2014 9:22 pm
Thanks. It turns out I was using an outdated source for the pinout, it works perfectly now. I hope to make some pcbs soon :D, Also anyone know where would I be able to put suggestions for chillipeppr because I have a few ideas to improve the workspace if they want to hear them.
jlauer
Post by jlauer » Sun Oct 19, 2014 9:46 pm
I would say the best spot is on the ChiliPeppr Google+ Community page because it can create discussion. However, if you want to file bugs you can do it on the Github page, but I think that Google+ is a better spot these days.
https://plus.google.com/u/0/communities ... 037?cfem=1
Google Groups
https://groups.google.com/forum/#!forum/chilipeppr
Github Issues (No Grbl one yet)
https://github.com/chilipeppr/tinyg
jlauer
Post by jlauer » Sun Oct 19, 2014 9:49 pm
BTW, you can always fork a workspace and create your own to do modifications. Then post to the Google+ community and I can get changes into the main workspace for you if people like the changes. I agree there's lots of cool things that could be done. Somebody created an mjpeg streaming viewer the other day by forking the webcam WebRTC widget so I'm going to add that to the main workspace. There's also a mobile version of the Grbl workspace that Dat Chu created so you can watch over your ChiliPeppr job from your phone that I'm going to post soon to the main workspace list.
ArtFaks
Post by ArtFaks » Fri Feb 05, 2016 12:23 am
So, Pin A5 and SCL Pin with UNO R3 Board !!!
Shapeoko2 - Homemade CNC Control box - 400W/48V Chinese Spindle - Protoneer V3 Shield + DRV8825
Process - Illustrator > Makercam > UGCS
