I started milling my first PCBs last night with my S03 and a 0.1mm, 10deg V bit.
I think I was a little too ambitious for my first time out, however, because the traces I ended up with aren't usable. What sort of cut-width and accuracy should I reasonable expect to get out of my setup?
I don't have pictures to show right now, but I can upload some later.
What Kind of Results Should I Expect?
Shapeoko 3 #147
Headless Controll via Raspberry Pi
SuperPID2
Touch Plate
Hall Effect Limit Switches in the Works
http://ohthehugemanatee.net/
SuperPID2
Touch Plate
Re: What Kind of Results Should I Expect?
Are you doing any depth probing? That can make a big difference when engraving PCBs.
http://www.autoleveller.co.uk
I have not done any probing, but my work area is quite small (maybe an inch square or so) and well clamped.
To phrase my question more precisely: what ideal should I aim for? When should I assume that I've maxed out the performance of my machine with regards to PCBs.
Shapeoko 3 #147
SuperPID2
Touch Plate
SuperPID2
Touch Plate
