Can't see detailed enough, but am curious about this, do you release component "airborne" or "landed" ?
That is a great idea. Thanks!Karl wrote:If you haven't got the advice before, try to place the parts on a double sided tape, that will emulate how the paste will hold the component when you placing it on a real board.
I connected the vacuum solenoid transistor to Arduino D12 (GRBL Spindle Enable). For G-codes: M3 turns it on, M5 turns it off.Karl wrote:For vacuum, which pin on the arduino did you connect it to and which G-codes controls it?
Also need to figure out a good position for the Z-axis limit switch.
