Why GRBL?
Re: Why GRBL?
- easy to use
free
configurable
runs with arduino
Re: Why GRBL?
Same reasons apply to Marlin.
Re: Why GRBL?
Arc support? I thought the reprap firmwares only support linear moves. What about probing? I remember that being on the grbl todo.
Re: Why GRBL?
I'm not advocating Marlin (which supports arcs, as far as I know). I'm just saying that that particular list of reasons applies to Marlin as well as GRBL. I prefer GRBL for milling (and I'd use TinyG if I had the board).
Re: Why GRBL?
Ultimately, many three axis robots are based on early GRBL, including RAMPS and the lasersaur project.
For me, I prefer subtractive tech more than additive. Working through a setup without the problem of parsing out what isn't needed and without the added extruder motor makes sense to me. GRBL on an Arduino UNO is about the simplest and least expensive way to get started with a three axis setup, coming in at about half what a RAMPS driver kit will cost. But if you can get it working with what you have on hand, great! I hope you will post the steps involved on the forums.
As for arcs, you can configure GRBL to cut to divide circles and arcs to lines fractions of a millimeter long. Not as elegant, but as the GRBL site puts is "are you in nanotech?". I've never been able to tell my circles aren't circles, even on small diameter plunges.
~EJ
~EJ
