Seeeduino v3 does not work with grbl 8c
nickscnc
Post by nickscnc » Sun Feb 24, 2013 11:26 pm
My controller using the seeeduino v3 atmega 328 works well with grbl v0.8a but not with v0.8c.
The motors move only in one direction for any pos/neg command.
I used the hex file from the grbl site.
alpha
Re: Seeeduino v3 does not work with grbl 8c
Post by alpha » Mon Feb 25, 2013 9:50 pm
After the upgrade did you set all you parameters again? You may also want to ask this question at the developer github page.
nickscnc
Post by nickscnc » Wed Feb 27, 2013 10:38 pm
Hi,
Yes I reset all the parameters, and still it did not work.
When I manualy type x10 or x-10 the cariage move only in the positive direction
Post by twforeman » Mon Mar 04, 2013 2:33 pm
Are you typing "x10" or "g0x10"?
If it's the first one, that's not a valid G code command and I wouldn't expect the machine to move at all.
alpha
Post by alpha » Mon Mar 04, 2013 5:15 pm
I think it works without G0 or G1 because the mode is modal and you don't need to type it all the time... anyway the issue sound like the direction on the Arduino is not connected to the direction pin on the stepper driver. Looks like this one bit is not toggling. The big question is now is this a hardware issue or firmware issue... have a look in the configuration to see what pin is used for direction... check if this pin toggles (use a LED or voltmeter)
Post by twforeman » Mon Mar 11, 2013 12:51 am
Just as a further note, I bought a USBTiny AVR programmer and flashed my Seeeduino with GRBL 0.8c the other day.
It works great, so I would suggest you are looking at a hardware problem.
