Grbl 0.9a
getSurreal
Grbl 0.9a
Post by getSurreal » Fri Aug 02, 2013 1:11 am
Anyone tested grbl_v0_9a_edge_328p_16mhz_9600_build20121210.hex yet?
Grbl 0.9a ['$' for help]
$0=250.000 (x, step/mm)
$1=250.000 (y, step/mm)
$2=250.000 (z, step/mm)
$3=500.000 (x v_max, mm/min)
$4=500.000 (y v_max, mm/min)
$5=500.000 (z v_max, mm/min)
$6=10.000 (x accel, mm/sec^2)
$7=10.000 (y accel, mm/sec^2)
$8=10.000 (z accel, mm/sec^2)
$9=10 (step pulse, usec)
$10=250.000 (default feed, mm/min)
$11=192 (step port invert mask, int:11000000)
$12=25 (step idle delay, msec)
$13=0.050 (junction deviation, mm)
$14=0.005 (arc tolerance, mm)
$15=3 (n-decimals, int)
$16=0 (report inches, bool)
$17=1 (auto start, bool)
$18=0 (invert step enable, bool)
$19=0 (hard limits, bool)
$20=0 (homing cycle, bool)
$21=0 (homing dir invert mask, int:00000000)
$22=25.000 (homing feed, mm/min)
$23=250.000 (homing seek, mm/min)
$24=100 (homing debounce, msec)
$25=1.000 (homing pull-off, mm)
ok
Shapeoko 1868F
"The only difference between a madman and me is that I'm not mad" - Salvador Dali
sweetv13
Re: Grbl 0.9a
Post by sweetv13 » Tue Sep 17, 2013 3:51 am
Do you have to change this is you have GRBL 0.9a???????
please answer
bjbsquared
Re: Grbl 0.9a
Post by bjbsquared » Tue Sep 17, 2013 11:00 am
No.
