Grbl with Synthetos Grblshield
alpha
Post by alpha » Sat May 19, 2012 2:55 pm
The info from our wiki:
Notes on using Grbl with Synthetos Grblshield
There are no changes required to the github distributed versions of grbl operate a Synthetos grblshield.
Grblshield is compatible with grbl version 0.7x and later releases. Synthetos Grblshield
Grblshield is compatible with grbl version 0.6 using a special, patched release.
Grblshield is not compatible with grbl version 0.5
I did install grbl_v0_8a_edge_328p_16mhz_9600_build20120310, that was maybe not so smart - however I guess it should work and the steppers on my table are rotating...
Now I want to modify the Grbl settings, the wiki tells me to change the Z to 1x stepping - but as far as I can tell this is not an option on the Synthetos Grblshield. I did see DrRob's online calculator http://noblesque.org.uk/ShapeOko/grblcalc/ but if I change the Z to 8x stepping it gives me this warning: Greater than 30kHz! Less than 2x step pulse width! - from the sound and the looks I don't think I can ignore this (if I use the calculated settings)?
Does anybody has a Synthetos grblshield with a ShapeOko, if so please post your working settings; thank you!
DrRob
Re: Grbl with Synthetos Grblshield
Post by DrRob » Sat May 19, 2012 4:57 pm
alpha wrote:Now I want to modify the Grbl settings, the wiki tells me to change the Z to 1x stepping
I found the z-axis to be quite noisy at low speeds with 1x stepping, so I've switched to 4x microstepping for Z, and 8x for X and Y. I changed the step pulse width to 20us to avoid the warning, although I'm sure it would still work with 30us - making it 20us just evens out the mark/space ratio when running at max speed. Maybe I should change the calculator so the warning only shows if the mark or space get really small (but how small?).
Enraged cut a trace on his Grblshield to achieve a different microstepping setting for the Z-axis - see: http://shapeoko.com/forum/viewtopic.php ... race#p1665
Rob.
alpha
Post by alpha » Sun May 20, 2012 4:01 pm
Here is my guess:
http://old.alpharesearch.de/pics/IMG_20 ... 092747.jpg
http://old.alpharesearch.de/pics/IMG_20 ... 092627.jpg
I did send a PM to user Wilafau to verify if all this is right... so I will wait until I cut and solder.
Now the big question is should I select 1/2 step like Wilafau or 1/4 step like DrRob??? With 1/2 speed I could theoretically do a higher seek rate, but I don't know if this is true?
aldenhart
Post by aldenhart » Mon May 21, 2012 1:35 pm
I submitted a length response to Wilafau's over in Electronics discussing these issues. Rather than reposting, here it is:
http://www.shapeoko.com/forum/viewtopic.php?f=4&t=221
-- Alden
DrRob
Post by DrRob » Mon May 21, 2012 2:42 pm
alpha wrote:Now the big question is should I select 1/2 step like Wilafau or 1/4 step like DrRob??? With 1/2 speed I could theoretically do a higher seek rate, but I don't know if this is true?
I don't know if this will help, but I uploaded some video of my Z-axis running in full-step, 1/2 step and 1/4 step modes, in an attempt to show the difference in noise:
Not sure how clear it is. In reality, the noise of the Z-axis motor is nothing compared to the noise of the cutting tool, and there's no problem at all with resolution on the Z-axis, so any step mode is ok.
I've haven't done any experiments to determine the max seek speed possible on the Z-axis.
Rob.
alpha
Post by alpha » Mon May 21, 2012 5:46 pm
Rob,
I guess you are still using the stepper motors you posted on the wiki page http://www.shapeoko.com/wiki/index.php/User:DrRob with 400 rev?
DrRob wrote:... I don't know if this will help, but I uploaded some video of my Z-axis running in full-step, 1/2 step and 1/4 step modes, in an attempt to show the difference in noise...
Thanks for the Videos! Yes, it was interesting to hear the difference... I guess everything lower than 8x stepping will work...
DrRob
Post by DrRob » Mon May 21, 2012 7:52 pm
alpha wrote:I guess you are still using the stepper motors you posted on the wiki page http://www.shapeoko.com/wiki/index.php/User:DrRob with 400 rev?
I am, yes.
alpha wrote:I guess everything lower than 8x stepping will work...
I think so, yes.
Rob.
AtomSoft
Post by AtomSoft » Wed Jun 27, 2012 7:10 pm
Rob.
Hey Rob if you change the warning would you please update us... Also i can update the grbl calc i made using your original code.
Blog / Store
Live to Love, Not to Hate.
aldenhart
Post by aldenhart » Wed Jun 27, 2012 10:24 pm
Here are the details on the Synthetos grblshield Z axis mod.
http://www.synthetos.com/wiki/index.php ... r_Shapeoko
You can do this yourself or ask us to do it if you are ordering a board.
- Alden
