Vectric Aspire Post Processor
dataway
Re: Vectric Aspire Post Processor
Post by dataway » Wed Feb 26, 2014 5:18 pm
Shapeoko/GRBL Post Processor Files for Aspire/Vcarve
ShapeokoPP.zip
(1.7 KiB) Downloaded 1007 times
dataway
Post by dataway » Wed Feb 26, 2014 5:23 pm
I got the files to upload after compressing them so you were correct it was the extension causing me issues.
I also updated the wiki page to point to this forum post to download the alternate post processors.
cchristianson
Post by cchristianson » Thu Feb 27, 2014 1:37 am
Thanks! will try
littledrumer
Post by littledrumer » Thu Sep 03, 2015 6:02 pm
Hi. I tried you post processor in Vcarve pro and it does not seem to work. The software does not recognize the file at all. I have been comparing your post processor to the shopbot post processor and they seem to be the same until the "begin HEADER". I would really like this post processor to work for Vcarve and I am considering writing my own. I am still new to CNC so any advice would help greatly.
jarretl
Post by jarretl » Thu Sep 03, 2015 6:21 pm
Have you already tried the post processor that inventables created? That is what I have been using and it has worked correctly.
It was also mentioned back on page 1 of this thread, but the link has changed.
https://www.inventables.com/technologies/vcarve-pro
Shapeoko 2 #4043; DW660
littledrumer
Post by littledrumer » Thu Sep 03, 2015 9:25 pm
I will try that. I could not find the new link since the old one is not working. Thanks for sharing.
EDIT: I think I figured out why its not working for me. I have VCarve Pro Shopbot edition and its not seeing post processors from other machines.
RobCee
Post by RobCee » Fri Sep 04, 2015 8:51 am
Vcarve has two PostP folders and if you put any post processor files in the 'My_PostP' folder, then it will only show you those post processors. If you want the full list, move any post processor files from the My_PostP folder and you should see the whole list from the PostP folder.
