Adding Hardcoded Z Feed Rate to 0.8c possible ?
Kayle
Post by Kayle » Sun Feb 23, 2014 8:28 am
Hello,
First i want to say hello because i am new here. My Name is Kay and i came from Germany. I use an eshapeoko with tb6560 stepper driver and grbl 0.8c.
The well known problem with the same feedrates makes the work with grbl not really fast because i have to use a feedrate of 200 max :(
The new 0.9 have still bugs and so i will try to get the 0.8c work with a hardcoded z feedrate.
Is there anybody on this forum who can help me with this project ?
Greetings
Kay
Re: Adding Hardcoded Z Feed Rate to 0.8c possible ?
Post by WillAdams » Sun Feb 23, 2014 12:30 pm
Some Communication / Control programs can set a hard-coded max. feed rate for the Z-axis --- e.g., Grbl Controller, see ``Z-rate limiting'' here: http://zapmaker.org/projects/grbl-contr ... r-options/
Kayle
Re: AW: Adding Hardcoded Z Feed Rate to 0.8c possible ?
Post by Kayle » Sun Feb 23, 2014 1:42 pm
WillAdams wrote:Some Communication / Control programs can set a hard-coded max. feed rate for the Z-axis --- e.g., Grbl Controller, see ``Z-rate limiting'' here: http://zapmaker.org/projects/grbl-contr ... r-options/
Thank you. I will try it.
Oud
Post by Oud » Mon Feb 24, 2014 7:00 am
I still use 0.8c and have been hesitant to upgrade to 0.9 until it is out in a more stable release. What I've been doing to work around this issue is:
1)Open the gcode file in scite (or any other decent plain text editor)
2)If you have your safety height set for say 0.1" there will be a lot of lines that say "G0 Z0.1"
3)Do a find all and replace of "G0 Z0.1" and replace it with "G1 Z0.1 F6"
If you have a long travel on the x or the y a line or two that has "G1 X..." or "G1 Y..." and add F and your working feedrate to the end of that line. Which will set the feed rate to the working feedrate rather than 6 inches per minute
Always test your g code afterwards just to be safe. I've found if you have the .nc/.gcode file open to edit when your bring it into openscam it glitches it out. So make sure you close the text editor before opening the file in openscam =]
Hope that helps.
Stock Shapeoko2, First pre-order batch.
Llamas
Post by Llamas » Tue Mar 04, 2014 11:54 pm
I do approximately the same thing. I generate my gcode normally, then open it in Notepad++ and run a search and replace for the regex 'G00Z([\d\.]+)' with 'G01Z\1F200'. This depends a little bit on the way my gcode is generated. (I already limit Z feed to between 200-260 mm/min, and each command includes an explicit G00/G01 mode command, and each G01 command includes an explicit Fnnnn feed rate, so changing a Z line does not affect the speed of other lines.) The thing that bit me when I first tried this was that F speed commands are ignored for G00 mode movements...
