Commands too long
chamnit
Re: Commands too long
Post by chamnit » Wed Oct 22, 2014 2:42 pm
Grbl v0.9 has a 79 (80-1) character limit. This should cover just about all cases of input that Grbl supports. This 50 or 70 line limit is artificially constrained by your version of UGS. Older ones limited it to 50, because Grbl at the time could only support 50 character. The same for 70. You'll need to update your UGS version, and if you still see a 70 character limit, please ask the UGS or whatever GUI's administrators to update their code.
joedeck868
Post by joedeck868 » Fri Oct 24, 2014 1:47 am
Thanks for the info I found the settings to increase the line length. I can't believe I could not find that it was right in front of my face haha. I am using PCB_Gcode in Eagle which works pretty well. I just made the first circuit today!
Thanks again,
Joe
aiden carter
Long Path Tool
Post by aiden carter » Thu Oct 20, 2016 8:09 pm
The Long path tool is the very best program for error, unlock solution.
Try it and solved your problem.
I used the long path tool and I solved my error, unlocks problem solution.
Schruminator
Post by Schruminator » Fri Oct 28, 2016 12:18 pm
This thread is 2 years old.
