GRBL for RAMPS 1.4
arsi
GRBL for RAMPS 1.4
Post by arsi » Tue Sep 02, 2014 8:48 am
Hi,
I created GRBl port for RAMPS 1.4
Steppers redirected to fastio.h from marlin firmware
min switches remaped to AUX-3, GBRL uses pin change interrupts
simple scheme to allow future porting of next releases
command buttons currently disabled
Ramps pins config moved to ramps.h
cpu_map.h - min switches
added GRBL_RAMPS1_4.ino for arduino IDE
Ramps 1.4 | GRBL | Test
X axis | X axis | OK working
Z axis | Y axis for dual motor Y axis | OK working
Y axis | Z axis | OK working
Ramps AUX-3 pin 3 | min X | not tested
Ramps AUX-3 pin 4 | min Y | not tested
Ramps AUX-3 pin 5 | min Z | not tested
D10 | motor ON | not tested
D9 | motor direction | not tested
D8 | coolant on | not tested
https://sourceforge.net/projects/grblforramps14/
Arsi
Redbarron1992
Re: GRBL for RAMPS 1.4
Post by Redbarron1992 » Sun Oct 05, 2014 9:07 am
Awesome piece of coding!
Have upload it to my Ramps and it worked!
Today is to try and let a program run, and get the endstop to work? Can you explain which pins I should use for de +, - and signal from the endstop?
If only using 1 pin on the aux, how to do that?
Greetings
arsi
Post by arsi » Mon Oct 06, 2014 7:44 am
It was just a warm-up programming ;)
Arsi
end stops
koleo9am
Post by koleo9am » Wed Oct 29, 2014 9:02 pm
Hello,
You have described how to wire the min endstop. Can You advice, how to connect the max endstops?
Thank you in advance.
Ondrej.
arsi
Post by arsi » Thu Oct 30, 2014 8:40 am
Hi,
Probably there must be connected in parallel with min endstops..
But, this should be tested ;)
Arsi
onekk
Post by onekk » Sun Dec 21, 2014 4:58 pm
Hello, I'm buying a RAMPS 1.4 kit with the Arduino Megacontroller and I've intention to build a Shapeoko 2, will your GRBL for RAMPS drive the dual Y axis Motor, i mean using one Controller for one motor?
Thanks in Advance
Post by WillAdams » Sun Dec 21, 2014 5:03 pm
Wiring up two motors to a single stepper driver is a typical configuration for RAMPS, so yes.
Gordon@letu
Post by Gordon@letu » Tue Jun 30, 2015 5:24 pm
Hello,
I am trying to use a ramps board to control a Shapeoko 2. I downloaded the firmware and unzipped it. I opened the sketch from the file folder and tried to upload it.
The Arduino IDE gave me this error message: GRBL_RAMPS1_4.ino:59:20: fatal error: fastio.h: No such file or directory
After that I moved the entire file folder to my arduino sketches folder. Once I did that the error message changed to something about variables being undefined in the #define statements in fastio.h. That was late last night so I gave up and tried again this morning. Now it has lost fastio.h again and I cannot recreate the #define statement errors.
I would really like to get this running on my ramps board. Does anyone have any suggestions for what to try next?
Thanks,
Gordon
DistortedDesign
Post by DistortedDesign » Mon Jul 27, 2015 3:46 pm
Did you ever get your answer?
At the beginning of any of the files where it calls for
<fastio.h>
change to
"fastio.h"
and it should work.
jeyton
Post by jeyton » Fri Jan 08, 2016 8:49 pm
Will this work using the RAMPS 1.4 board on a Duemilanove? RepRap lists everywhere that Duemilanove works with RAMPS 1.4, I had a Mega2560 but it died. I am wanting to use the RAMPS 1.4 on the Duemilanove for simply X,Y,Laser for a laser cnc. I read that I might have to re-route the pins, but I'm not sure if thats a physical re-route or in the firmware?
