How to set Z to 5mm manually?
flashonja
Post by flashonja » Sat Dec 13, 2014 3:58 pm
Hey guys (and girls:),
I'm not sure if this is the right topic, but I couldn't find one dedicated to g-code.
I've recently installed a simple Z-touch probe, with grbl 0.9 we can finally easily set the Z origin without jogging! It works like a charm and I almost fell in love with it :))
The thing I was wondering was whether is it possible to set the Z value to something else except 0?
Let me explain...my touch probe is 5mm high and when the drill touches it its Z coordinate is Z=5mm.
Is there a g-code command that could set the Z to 5mm?
Was I clear enough?
What is your workflow to fix this?
Thank you,
matej
SO2 full kit + limit switches
Kress 1050 FME
Win 7 64bit
RobCee
Re: How to set Z to 5mm manually?
Post by RobCee » Sat Dec 13, 2014 4:14 pm
If my memory serves me, you can use G10 P1 L20 Z5 - change the P1 for the coordinate set you are using (P1=G54, P2=G55, etc)
flashonja
Post by flashonja » Sat Dec 13, 2014 8:15 pm
Thank you RobCee!
But can you (or someone else) elaborate a bit please? I'm more of a noobie as far g-code is in question.
cheers
m
Kress 1050 FME
Win 7 64bit
RobCee
Post by RobCee » Sat Dec 13, 2014 10:12 pm
This is how you set your user/work coordinate systems using gcode
For more info check out the Using the Work Coordinate Systems wiki here - look towards the bottom of that page
G10 P1 L20 Z5
G10 - set coordinate system
P1 - first definable coordinate system (G54)
L20 - use an offset value
Z5 - The current Z position is Z=5
flashonja
Post by flashonja » Sun Dec 14, 2014 11:18 am
Thanks I get it now!
cheers
m
Kress 1050 FME
Win 7 64bit
