Dwell
AtomSoft
Dwell
Post by AtomSoft » Fri Jul 13, 2012 3:21 am
Am i the only one having a issue with DWELL ?
I tried:
G04 3
G4 3
G04 3.0
G4 3.0
but nothing :( do i need to run another command first?
Blog / Store
Live to Love, Not to Hate.
AtomSoft
Re: Dwell
Post by AtomSoft » Fri Jul 13, 2012 3:25 am
hah G04 Px
works :)
Blog / Store
vios
Re: Dwell
Post by vios » Fri Jul 13, 2012 5:08 am
AS,
What's the purpose?
Sorry for noobs question :D
AtomSoft
Re: Dwell
Post by AtomSoft » Fri Jul 13, 2012 1:55 pm
DWELL = DELAY
G04 = Pt
where t = TIME in SECONDS
So if i want to change a bit... I add:
G04 P120
This will pause the entire operation for 2 minutes (120 seconds)
Enough time for be to be thorough when changing bits. :)
Blog / Store
zimmer62
Re: Dwell
Post by zimmer62 » Fri Jul 13, 2012 5:23 pm
yikes the idea of putting my hands in a machine that's paused for an amount of time scares me pretty good...
I think there must be a better way for a tool change. I don't know the GRBL shield process, but that's crazy using dwell for this...
dwell should pause when drilling holes etc, to make sure the hole is clear...
AtomSoft
Re: Dwell
Post by AtomSoft » Fri Jul 13, 2012 6:59 pm
yeah im sure there is but for the time being i use this. I trust the code and understand what its doing so i dont have to worry :)
Blog / Store
Re: Dwell
Post by edwardrford » Fri Jul 13, 2012 9:01 pm
I'm with Zimmer62 on this one. Using dwell for a toolchange gives me a serious case of the shivers. It makes my stomach a little queezy too!
What needs to happen is a feed hold. If you're using v0.8, that's as simple as sending a ! to your arduino. When your tool change is done, you can then send a ~ to resume.
There is also another step that I'm not 100% sure what the best practice is. After you switch bits, you'll need to re-zero your z-axis. Which would require you to lower it back down to the work surface and do a G28 Z0, then resume the job. Again, I'm not sure exactly how that will work with grbl, but it shouldn't be too tough to figure out and document.
-Edwar
AtomSoft
Re: Dwell
Post by AtomSoft » Fri Jul 13, 2012 9:24 pm
I like the typo on :
-Edwar
Makes us sure your human :)
The main reason i use DWELL and LOCK the axis is so i dont have to re-zero anything. I can simply replace the tool and and wait... nothing to worry about at all. But ill be sure to check out that info and post anything i find :)
Thanks guys!
Blog / Store
zimmer62
Re: Dwell
Post by zimmer62 » Fri Jul 13, 2012 9:41 pm
you re-zero, because different tools are different heights... if the tools is in a tool holder set to the same depth, or somehow measures exactly the same, then you would be fine without re-zeroing it.
however, most tools I've got are different, any tool change requires me to have the machine know where it is.
I'm considering using a copper plate, and a wire clipped onto the tool to help automate this process.
here is a video of someone doing an auto zero touch off
[youtube]http://www.youtube.com/watch?feature=pl ... CnZs7A59yg[/youtube]
the idea is that you know the thickness of the plate, and the machine will do the rest.
AtomSoft
Re: Dwell
Post by AtomSoft » Fri Jul 13, 2012 9:49 pm
I know, all my code is calculated for that already. Im not just switching tools in between for fun :) I set my Z to 30 and change the tool... but the z goes back -30 +/- tool difference in code.
So basically
Cut
Cut
Cut
Z30
DWELL (change tool)
Z-29.05 (new tool height is larger)
cut
cut
cut
etc... Its easier for me at the moment... i have a huge head ache and neck pain today... no research for me. If anyone can give me a actual step by step flow ill look into it today if not im sorry but i feel like sh*t and need to rest :(
Thanks to all. You guys are awesome and please keep inspiring me :D
Blog / Store
