Dwell
Re: Dwell
Post by edwardrford » Sat Jul 14, 2012 11:24 pm
AtomSoft wrote:I like the typo on :
-Edwar
Man... that's embarrassing! I suppose I've been called worse though :-)
AtomSoft
Re: Dwell
Post by AtomSoft » Sat Jul 14, 2012 11:40 pm
:) not embarrassing... more like... about time it happened :)
Blog / Store
Live to Love, Not to Hate.
Temmink
Re: Dwell
Post by Temmink » Mon Sep 03, 2012 8:40 pm
hi,
I'm trying to "pause" my machine so I can change the tool.
I'm using GRBL version 0.8A with Motor lock enhancement from Atomsoft.
My machine doesn't shows any difference with using the G04 code. (I think that's the DWELL command code?
for eg.:
X50 Y50 ---> machine goes 5 cm to the right and back.
Z30 ---> Move the Z 30 mm up.
G4 ---> DWELL/PAUSE
Z0 ---> Lower the Z 30 down.
X0 Y0 ---> go back to home position.
In the above example my machine seems to skip the G4 command, but doesn't show any errors.
I don't know whats wrong, if anybody knows please help
voor een betere toekomst:
http://www.verdini.eu
Temmink
Re: Dwell
Post by Temmink » Mon Sep 03, 2012 8:50 pm
ah, Found it.
It was just a matter of beter reading this thread ;-)
the machine works with the following g-code file:
G4 = P120 ---> 2 minutes pause
It even works with this g-code file:
! ----> Stops the shapeoko until it receives the ~ keystroke.
Now I have to find out, how to easy re-home the Z-as, after a tool change.
