UGS and grbl controller freeze
GrainGuy
Re: UGS and grbl controller freeze
Post by GrainGuy » Sun Mar 08, 2015 9:21 pm
I changed everything back to my original setup and all is good. I will worry about getting the printed pla setup to work another day. Thanks for everyones insight.
Will Winder
Post by Will Winder » Wed Mar 11, 2015 12:19 pm
Jimf wrote:This could be long shot but if you have a spindle or router that has brushes, please check them. I had a router motor with worn down brushes that was arcing and made lots of emf noise. At the time it caused lots of lost steps and headache.
I also had this problem due to a well used spindle. Mine was a dremel tool and caused enough interference for Grbl to crash randomly. You can try running your job in the air with the spindle off to isolate the problem.
