GRBL 0.9i
m_itko
GRBL 0.9i
Post by m_itko » Mon Jun 08, 2015 5:27 am
Hello,I change electronic on my shapeoko.With the old electronics from Shapeoko(Arduino and gShield) made laser engraving machine.
When use grbl 0.8,machine working fine,not any problems.If upload grbl 0.9i(SO2 default) for use Laser engraving software macine stopped and not moving.
Where is my error?I use GRBL controller from zapmaer.org.
Gadgetman!
Re: GRBL 0.9i
Post by Gadgetman! » Mon Jun 08, 2015 7:31 am
What's the serial port setting?
GRBL 0.8 defaulted to 9600, but 0.9 uses 115200.
m_itko
Re: GRBL 0.9i
Post by m_itko » Mon Jun 08, 2015 8:26 am
Hello,
Serial port setting for 0.9 - 115200.As back again 0.8,no problem.If upload 0.9i machine freeze and no moving.
Re: GRBL 0.9i
Post by WillAdams » Mon Jun 08, 2015 11:59 am
Did you clear the EEPROM?
Make note of the old settings and manually restore them?
http://www.shapeoko.com/wiki/index.php/Grbl#Upgrading
chamnit
Re: GRBL 0.9i
Post by chamnit » Mon Jun 08, 2015 3:26 pm
The spindle enable pin D12 and z-limit pin D11 have switched places in v0.9i. Make sure you account for that.
m_itko
Re: GRBL 0.9i
Post by m_itko » Mon Jun 08, 2015 6:53 pm
Everything is checked,but the machine is not mooving.I will clear EEPROM and manually restore setting(thanks WillAdams)
Is it necessary to insert or change value of startup block?When i try to manually mooving,GRBL controller send error
there is no set value for default feed [G0 G54 G17 G21 G90 G94 M0 M5 M9 T0 F0. S0]
Re: GRBL 0.9i
Post by WillAdams » Mon Jun 08, 2015 7:11 pm
Re: GRBL 0.9i
Post by cvoinescu » Mon Jun 08, 2015 7:34 pm
You get that error from GRBL if your host software tries to use G1 moves to jog, but does not set the F parameter (speed). This used to work in GRBL 0.8, because there was a default value, but GRBL 0.9 follows the standard more closely, and forbids G1/G2/G3 without having set a speed. The state parameters confirm this.
Try using a different host program (G-code sender), or try upgrading to a version that supports GRBL 0.9 correctly.
Or, enter something like F200 (if in mm mode) and try jogging again.
ggbusmgr
Re: GRBL 0.9i
Post by ggbusmgr » Sun Aug 09, 2015 2:40 pm
Hi all, another newbie here. I'm trying to upgrade to the latest GRBL on my Shapeoko2 from .8 to .9j using Xloader. I'm upgrading so I can upload the Objectworks Laser software. I have Xloader v1.00 on my computer. I downloaded the hex file, set com3, baud 115,200 and the device UNO. When I hit upload, it says its uploading but I get the attached message. I've tried it with the board both powered and not powered. same message from Xloader. Can anyone tell me what I'm doing wrong.
Thanks in advance, Greg
error screen.docx
(12.51 KiB) Downloaded 115 times
ggbusmgr
Re: GRBL 0.9i
Post by ggbusmgr » Sun Aug 09, 2015 4:40 pm
Sorry, that attachment didn't download. Trying again. I get this error message from Xloader
when I hit upload button “unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately. The system canot find the file specified.
error screen.docx
(12.51 KiB) Downloaded 71 times
