Home cycle trouble
robcop
Home cycle trouble
Post by robcop » Fri Jun 26, 2015 6:20 pm
I have just finished to assembly the Shapeoko.
I have mounted the limith Switch and they all work in JOG Mode (moving the machine with sign).
I have tried to make the home cycle, but the limit switches have not been detected, and break the limith switches. Now changed.
This for me doesn't make sense. If the limit switches works in JOG mode they should work in homing Cycle.
This is my GRBL configuration.
Grbl 0.9g
$0=10 (step pulse, usec)
$1=25 (step idle delay, msec)
$3=4 (dir port invert mask:00000100)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$11=0.020 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$14=1 (auto start, bool)
$20=0 (soft limits, bool)
$21=1 (hard limits, bool)
$22=1 (homing cycle, bool)
$23=1 (homing dir invert mask:00000001)
$24=25.000 (homing feed, mm/min)
$25=500.000 (homing seek, mm/min)
$26=250 (homing debounce, msec)
$27=1.000 (homing pull-off, mm)
$100=250.000 (x, step/mm)
$101=250.000 (y, step/mm)
$102=250.000 (z, step/mm)
$110=500.000 (x max rate, mm/min)
$111=500.000 (y max rate, mm/min)
$112=500.000 (z max rate, mm/min)
$120=10.000 (x accel, mm/sec^2)
$121=10.000 (y accel, mm/sec^2)
$122=10.000 (z accel, mm/sec^2)
$130=800.000 (x max travel, mm)
$131=1800.000 (y max travel, mm)
$132=200.000 (z max travel, mm)
Any suggestion?
Thanks in advance
Roberto
Re: Home cycle trouble
Post by twforeman » Fri Jun 26, 2015 6:32 pm
The config looks okay. First thing I would do is upgrade to Grbl 0.9i and see if it still fails to home properly.
robcop
Post by robcop » Fri Jun 26, 2015 7:22 pm
I have update to GRBL 0.9i, but the problem is not solved. Thanks
Roberto
Post by twforeman » Fri Jun 26, 2015 8:17 pm
So looking at your config again, you have $3 = 4. This means that you have inverted your Z motor direction.
You also have $23 = 1 which means that the X axis will home towards the positive side.
Set them both to 0 unless you have something weird in your machine design.
newtothis
Post by newtothis » Fri Jun 26, 2015 8:46 pm
Since I bought limit switches, this is really helpful info for set up as I wondering how to do this. Thanks.
Too bad there are not limit switch setting adjustments this easy for ex's.
Shapeoko 3 #304
robcop
Post by robcop » Sat Jun 27, 2015 8:14 am
Twforeman
I made the changes but nothing change in Homing cycle.
I have tried to use Universal GCode Sender 1.0.8 but doesn't detect the CNC. 1.0.7 works and is the one I'm using. I don't Know if this means somting.
Roberto
robcop
Post by robcop » Sat Jun 27, 2015 1:40 pm
Solved
If you look ath these scheme, there is a differenze in the Z axis Pin.
Is not more n.11 of arduino board but 12.
With 12 now works.
Maybe somthing changed
Bye
Roberto
x-carve_gShield_schematic.pdf
(472.48 KiB) Downloaded 109 times
Post by twforeman » Sun Jun 28, 2015 7:58 pm
Ah, yes, the Z limit pin changed in Grbl in one of the v0.9 releases. Sorry that I didn't catch that.
