Can a Raspberry Pi w/ UGS be used to send Gcode to Arduino?
pmap93
Post by pmap93 » Sat Feb 06, 2016 9:29 am
Good Day! I've been looking for a low-cost method of having a mini workstation for my new shapeoko. :D
Thing is, i don't have a spare computer for now, but i have a Raspberry Pi ^^ I know a bit about it though. I've been using Universal GCode Sender for months now with a laptop on Windows, however, I wanted to try to experiment and see if it is possible to connect the Arduino to the Pi and the Pi will be the one responsible for sending Gcode? :?:
Where should I start? :D
Is there a Pi compatible version of UGS? I guess it would be since it is Java right? :D
Is connecting the Arduino as simple as plugging in the USB to the Pi?
Regards,
Paolo
Re: Can a Raspberry Pi w/ UGS be used to send Gcode to Ardui
Post by WillAdams » Sat Feb 06, 2016 10:05 am
Shook
Post by Shook » Sat Feb 06, 2016 6:50 pm
I've been using a Raspberry Pi 2 with universal G-Code Sender. It works swimmingly.
I haven't yet tried an original Raspberry Pi, but I have 2 sitting around. They're 1st and 2nd generation - 512mb and 1gb respectively, both with heat sinks on the CPU.
Shapeoko 3 (#1107)
pmap93
Post by pmap93 » Sat Feb 06, 2016 8:04 pm
I have Model B+, I shall try this ASAP ^^
May I ask if there are any additional packages to be installed?
pmap93
Post by pmap93 » Sat Feb 06, 2016 9:10 pm
I'll put this link here for those who'd need:
instructions to install
http://opensourceecology.org/wiki/Gcode ... spberry_Pi
pmap93
Post by pmap93 » Sat Feb 06, 2016 11:33 pm
It works!
using the 'start.sh' script!
Thanks for al your help!
however the Visualizer window .. it isn't working :(
A whole lot of messages appear with the line "Exception in thread "AWT-EventQueue-0" "in the top.
Any ideas how?
Running the latest fresh copy of Raspbian :)
I found this:
I cant understand it, looks really complex, any simpler step-by-step instructions? :/
https://github.com/winder/Universal-G-C ... /issues/47
Running Latest UGS 1.0.9
pmap93
Post by pmap93 » Sat Feb 06, 2016 11:37 pm
Ouch. Never mind.
Any cnc file i use and press 'Send' Aborts the program.
"A fatal error has been detected by the Java Runtime Environment:
Internal Error (os_linux_zero.cpp:285), pid=1395, tid=2639656032
fatal error: caught unhandled signal 11"
Is there something wrong? Am I missing some steps or packages to be installed? :|
Shook
Post by Shook » Tue Feb 09, 2016 3:46 am
I'm using an OS build from http://wiki.protoneer.co.nz/Raspberry_P ... mmended.5D
I saw the link in a discussion focused on bCNC - https://github.com/vlachoudis/bCNC/issues/12
It's geared towards bCNC, but I had limited success with bCNC. I dropped UGS on there and it worked. As you mentioned, the visualizations failed I think that's a problem with the limited graphics acceleration on the raspi
I'm working with a nightly build of UGS from November (I should probably update it).
Shapeoko 3 (#1107)
