[FIXED] Getting Homing To Set To Zero
mankyd
Post by mankyd » Thu Feb 18, 2016 3:13 am
Howdy. I've installed my limit switches in the negative direction. I've configured GRBL (see below) and it seems to work well enough. That is except for one catch: When it homes, it leaves the x & y directions zeroed to the back-right corner. I'd like it zeroed to the front-left corner. Is there any way to do this, or must i remember to hit G92 every time I home? I was hoping that homing would automatically set everything to zero.
$0=10 (step pulse, usec)
$3=4 (dir port invert mask:00000100)
$6=0 (probe pin invert, bool)
$10=255 (status report mask:11111111)
$11=0.020 (junction deviation, mm)
$12=0.010 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=1 (soft limits, bool)
$21=1 (hard limits, bool)
$22=1 (homing cycle, bool)
$23=3 (homing dir invert mask:00000011)
$24=100.000 (homing feed, mm/min)
$25=1000.000 (homing seek, mm/min)
$26=25 (homing debounce, msec)
$27=5.000 (homing pull-off, mm)
$100=20.000 (x, step/mm)
$101=20.000 (y, step/mm)
$102=20.000 (z, step/mm)
$110=5000.000 (x max rate, mm/min)
$111=5000.000 (y max rate, mm/min)
$112=5000.000 (z max rate, mm/min)
$120=400.000 (x accel, mm/sec^2)
$121=400.000 (y accel, mm/sec^2)
$122=400.000 (z accel, mm/sec^2)
$130=415.000 (x max travel, mm)
$131=435.000 (y max travel, mm)
$132=80.000 (z max travel, mm)
Shapeoko 3 #147
Headless Controll via Raspberry Pi
SuperPID2
Touch Plate
Hall Effect Limit Switches in the Works
http://ohthehugemanatee.net/
chamnit
Re: Getting Homing to Set To Zero
Post by chamnit » Thu Feb 18, 2016 3:18 am
Yes. But this is a compile-time option, where you'll need to uncomment the HOMING_FORCE_ORIGIN line, re-compile, and flash. This will have Grbl set zero, wherever the homing cycle completes.
mankyd
Post by mankyd » Thu Feb 18, 2016 3:31 am
Interesting. Thanks! I've compiled GRBL once before. Looks like its time to do it again.
Shapeoko 3 #147
SuperPID2
Touch Plate
