laser power adjustment to the speed
felixa4
Post by felixa4 » Tue Mar 29, 2016 7:52 pm
hello dear international friends, I am italian and new in the forum and I ask you to help with a problem of all those who use the CNC laser: during acceleration and deceleration the laser burns too much or pit material; I'm not good in programming and I ask you to change grbl code (dedicated to the laser) to proportion the laser power to speed during acceleration and deceleration, for example starting with P = 1 / k (programmable via $) to speed 0, and P = 100% at full speed. on the contrary for the deceleration ramp. this is my idea.
many thanks for your interest, byyyyyyyyyyyyeeeeeeeeee ;) ;) ;)
AnonymousPerson
Re: laser power adjustment to the speed
Post by AnonymousPerson » Tue Mar 29, 2016 9:23 pm
Ahhhh, this is probably not the "correct" place for the suggestion.
Instead, it would be better here:
https://github.com/grbl/grbl/issues
Are you ok to add it there? :smile:
Post by cvoinescu » Tue Mar 29, 2016 9:27 pm
That's probably not the "correct" place either, because stock GRBL does not support lasers anyway. There are a few forks that do; maybe suggest it to them.
AnonymousPerson
Post by AnonymousPerson » Tue Mar 29, 2016 10:11 pm
cvoinescu wrote:That's probably not the "correct" place either, because stock GRBL does not support lasers anyway. There are a few forks that do; maybe suggest it to them.
Good point. Doing some searching turns up this laser focused :D version of GRBL:
https://github.com/alpharesearch/grbl/tree/laser
It doesn't seem to be receiving updates though. The alpharesearch people themselves might be useful to talk to. :)
AnonymousPerson
Post by AnonymousPerson » Tue Mar 29, 2016 10:19 pm
Another fork with laser support. Also not receiving recent updates:
https://github.com/alsliahona/grbl/tree/LaserMode
picengravertoo
Post by picengravertoo » Wed Mar 30, 2016 1:19 pm
Shapeoko 2 Laser Diode Engraver-Analog/TTL/PWM
PicEngrave Pro 6 Image to Gcode for grbl/Mach3 controllers-Spindle/Laser
PicLaser: Image to Gcode With Editor
PicSender: Streams grbl Raster/Vector Gcodes
https://www.picengrave.com
FargoPhil
Post by FargoPhil » Wed Mar 30, 2016 3:18 pm
It sounds like official laser support is pending. This is discussed in more detail over in the Acceleration thread.
No idea how close it is to becoming real.
chamnit
Post by chamnit » Wed Mar 30, 2016 3:43 pm
Very close. :) I'm generally done, but need to test and optimize the code. However, I keep getting pulled into things that Inventables needs me to do before i can do it.
halfnormal
Post by halfnormal » Wed Mar 30, 2016 4:17 pm
Jtech's version of GRBL is made with laser in mind. Info here http://jtechphotonics.com/?page_id=1100
Download here http://jtechphotonics.com/Downloads/GRB ... J_TECH.zip
He is actually updating it and a newer version will be out shortly.
Also if you use PicEngrave software, it is optimized for laser. All their software is found here http://picengrave.com/
Welcome to the world of lasers and GRBL! I am having fun trying to optimize it for a 40 watt CO2 laser system.
AnonymousPerson
Post by AnonymousPerson » Wed Mar 30, 2016 5:18 pm
chamnit wrote:Very close. :) I'm generally done, but need to test and optimize the code. However, I keep getting pulled into things that Inventables needs me to do before i can do it.
Ahhh, is there a public branch with that in it?
The "test" part of "test and optimize" can probably be helped along just by pointing people at it... ;)
