add delay after Z down
jmb47
Re: add delay after Z down
Post by jmb47 » Sat Apr 23, 2016 2:06 pm
hello
i change the shield for another and i put a fan
same problem!
Brian Stone
Post by Brian Stone » Sat Apr 23, 2016 7:35 pm
Just a random thought...
Could the electromagnet that you're using for the pen be creating a pulse that is interfering with the stepper motors some how?
Shapeoko 2 #7353
jmb47
Post by jmb47 » Sun Apr 24, 2016 12:02 pm
i don't think so.
because it works well when I make drawings with text for exemple...
https://www.youtube.com/watch?v=0Lc3-4xFtS0
PsyKo
Post by PsyKo » Mon Apr 25, 2016 11:52 am
Hi again,
Just to be sure, can you post the GCode for your grid pattern ?
Also did you try to run it at slower feedrate, just for the test ?
Shapeoko #736
jmb47
Post by jmb47 » Thu Apr 28, 2016 3:37 pm
hi everybody
i made a test with a slower federate, and another test with 1/4 step. it's the same thing.
you can download an exemple of Gcode here:
https://dl.dropboxusercontent.com/u/19315325/grid_1.ngc
i don't understand what is happening...
