Grbl v1.1e released!
chamnit
Post by chamnit » Sun Dec 11, 2016 12:55 am
Grbl v1.1e has been officially released! Available here: http://www.github.com/gnea/grbl/
- New real-time override command set for rapids, feed, spindle, spindle stop, and coolant toggle.
- Sweet new laser mode with a dynamic power mode that adjusts power with speed. No more scorching, regardless if your machine isn't fast.
CastIrony
Re: Grbl v1.1e released!
Post by CastIrony » Sun Dec 11, 2016 3:50 am
Congrats! I know you've been working hard on it. :D
Post by twforeman » Mon Dec 12, 2016 3:12 am
Awesome!
How soon until bCNC supports it? :)
RobCee
Post by RobCee » Mon Dec 12, 2016 11:33 am
Great job! Huge thanks for your awesome work!
chamnit
Post by chamnit » Mon Dec 12, 2016 4:24 pm
twforeman wrote:How soon until bCNC supports it? :)
bCNC should support v1.1 now, but it doesn't have any of the override controls buttons yet. Not sure when Vasilis can get to it. It'll require a lot of reshuffling of current layout to support them all.
Hayri
Post by Hayri » Tue Dec 13, 2016 12:34 am
Thanks for your hard work, will try it with my Phoenix CNC Controller board. I also saw the post about the LCD display and want to adapt that to OLED display and make a new controller board with I2C OLED display and grbl 1.1.
cozmicray
Post by cozmicray » Tue Dec 13, 2016 10:04 pm
I am using GRBL 0.8
GRBL0.8 parameters $0 thru $22
GRBL1.1 parameters $0 thru $132
Where are parameter definitions?
Is there a shapeoko 2 setting file?
cozmicray
Post by cozmicray » Tue Dec 13, 2016 10:11 pm
Here is a my attempt at GRBL1.1 parameter set for Shapeoko 2
the parameters are like GRBL0.9 set
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=0
$100=40.020
$101=40.020
$102=320.000
$110=500.000
$111=500.000
$112=500.000
$120=10.000
$121=10.000
$122=10.000
$130=280.000
$131=280.000
$132=90.000
GRBL0.9 parameters
$0=10 (step pulse, usec)
$1=25 (step idle delay, msec)
$3=6 (dir port invert mask:00000110)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$11=0.020 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$23=1 (homing dir invert mask:00000001)
$24=50.000 (homing feed, mm/min)
$25=635.000 (homing seek, mm/min)
$26=250 (homing debounce, msec)
$27=1.000 (homing pull-off, mm)
$100=314.961 (x, step/mm)
$101=314.961 (y, step/mm)
$102=314.961 (z, step/mm)
$110=635.000 (x max rate, mm/min)
$111=635.000 (y max rate, mm/min)
$112=635.000 (z max rate, mm/min)
$120=50.000 (x accel, mm/sec^2)
$121=50.000 (y accel, mm/sec^2)
$122=50.000 (z accel, mm/sec^2)
$130=225.000 (x max travel, mm)
$131=125.000 (y max travel, mm)
$132=170.000 (z max travel, mm)
cozmicray
Post by cozmicray » Tue Dec 13, 2016 10:44 pm
How about a GRBL command set
what do all the $ cmds do?
What is command out of sleep?
What is command in / out laser mode?
chamnit
Post by chamnit » Wed Dec 14, 2016 2:29 am
All of your questions may be answered on the Wiki. https://github.com/gnea/grbl/wiki
I spent all weekend updating everything for v1.1 so it should be current. Including an answer to where the settings descriptions went in the FAQ.
