Cd rom motor not working with GRBL
3ddd
Post by 3ddd » Mon Jan 16, 2017 8:37 pm
Hi everyone,
I have a small problem using a cd rom motor for a project and was wondering if it is something one of you guys could maybe help.
I've been trying to control the motor using Universal G-code Sender and GRBL Controller but the motor doesn't move, when I press on any of the commands I see a light blink on the Arduino but nothing else happens.
I can move the motor using the Arduino IDE.
Here is what I am using and the settings:
-flashing arduino with GRBL 0.9 at 115200 baud
-baud rate on UGS is 115200
-motor driver is a EasyDriver
Any help would be greatly appreciated.
Schruminator
Re: Cd rom motor not working with GRBL
Post by Schruminator » Tue Jan 17, 2017 3:19 pm
*Deleted* I didn't see your note about the Easy Driver. My bad.
cozmicray
Post by cozmicray » Tue Jan 17, 2017 4:41 pm
show us your wiring.
What flavor or arduino?
The easy driver should supply voltage to motor
What is the power supply to the easy driver.
GRBL basicly a G-code converter
but GRBL has to know how to setup and command the motor driver.
Have you set up GRBL to use Easy driver on correct pins on Arduino
3ddd
Post by 3ddd » Tue Jan 17, 2017 5:39 pm
Hi cozmicray,
Thank you for your reply. Attached are pictures of the wiring.
I am using a Arduino Uno R3. The power supplied to the Easy Driver (which is not shown in the picture) are 4 AA batteries connected in series, so the voltage going to the easy driver is 6v.
Yellow wire is connected on 8 on Arduino
Green wire is connected on 9 on Arduino
I am not sure if I have set up GRBL to use Easy Driver on the correct pins on Arduino
Universal Gcode Sender.jpg (244.01 KiB) Viewed 998 times
cozmicray
Post by cozmicray » Wed Jan 18, 2017 8:09 pm
see
https://github.com/grbl/grbl/wiki/Connecting-Grbl
for wiring
Wrong pins on arduino?
X Axis pins 2, 5, gnd
3ddd
Post by 3ddd » Wed Jan 18, 2017 11:48 pm
It works ! Thank you so much. Now the steps aren't smooth at all, I can hear all the steps and feel all the steps it performs even in micro steps, what do you think might be the problem ?
It feels like it does a couple of steps instead of the value I input UGS. I tried the values of 157 steps/mm and 53.333 steps/mm and there is no difference in terms of smoothness.
cozmicray
Post by cozmicray » Thu Jan 19, 2017 5:47 pm
You have to get some info on the stepper motor and what signals
are best.
Change the parameters
step pulse
step delay
acceleration
full, half, quarter, eighth step
take notes --- what parameters smooth out the motor
